Show your Trek Multitrack!
Old 05-18-20, 06:36 PM
  #426
Korina
Happy banana slug
Korina's Avatar
Quoted: 1530 Post(s)
Liked 1,527 Times in 915 Posts
Originally Posted by rseeker
Now with more rack!
I spray-painted the struts, after sanding and cleaning. I got a pretty good finish match with semi-gloss satin. (The struts are aluminum; Rust-Oleum is just what I had. on hand.)
There's a problem with the struts though. You can see they splay out toward the front, meaning I can't get two of the bolts in at the deck. I may have to make an adapter plate and get a couple more bolts.
More lighting and side reflector panels to come.
Nice bike. BTW, the struts are meant to be bent as needed to make them fit. I wouldn't fold them, but a gentle bend shouldn't cause any problems.
Korina is offline
Likes For Korina:
Old 05-18-20, 07:06 PM
  #427
FREEBIRD1
Quoted: 83 Post(s)
Liked 208 Times in 106 Posts
Another TREK back on the road.
Finished the little 720, new set of Kenda West 700X35's, quick rolling light bicycle, She's running almost dead quiet through the gears and straight as an arrow. My neighbor is now ready for a summer at the bike path across the road from us, she's going to e happy, took it out for about a 3 mile shakedown run and it feels like new.
FREEBIRD1 is offline
Likes For FREEBIRD1:
Old 05-20-20, 08:35 AM
  #428
dmark
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times in 142 Posts
Trek 750 23" non lugged $120, posted last night
https://newjersey.craigslist.org/bik...127092621.html
Last new bike 1991
dmark is offline
Old 05-20-20, 08:44 AM
  #429
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times in 568 Posts
That looks like a '97 model (Inkwell Blue paint). That's a "buy" all day long at that price (assuming the frame is good, not cracked or bent, etc.).
hokiefyd is offline
Old 05-29-20, 08:35 PM
  #430
c0rbin9
Bikes: None
Quoted: 62 Post(s)
Liked 40 Times in 20 Posts
Who picked up the 1990 blue 750 on eBay? Looked to be in great shape!
Does anyone know the widest tires that will fit on the stock Matrix Titan II rims that came on my 1990 750? I'm hoping to fit 43mm GravelKing SKs.
c0rbin9 is offline
Old 05-30-20, 01:30 PM
  #431
Korina
Happy banana slug
Korina's Avatar
You mean that gorgeous intense blue one? My poor husband was drooling over that for days, but he already has a 730 that needs building up, as well as a New Albion Drake to build, and couldn't rationalize the expense.
Korina is offline
Old 05-30-20, 01:34 PM
  #432
c0rbin9
Bikes: None
Quoted: 62 Post(s)
^ Yep, that's the one. It was a 21" 1990 750 in Intense Blue. It was listed at $425 + shipping when it sold so I bet the seller is happy.
c0rbin9 is offline
Likes For c0rbin9:
Old 05-30-20, 03:31 PM
  #433
dmark
Quoted: 184 Post(s)
My 91 750 (Titan Tour) has Schwalbe Delta Cruiser 37 with roughly 1cm or 3/8" either side so good for 43 or fenders maybe both.
Quick measure of outer rim width:
Titan Tour 22.5mm
Titan II 19.5mm (my 1990 750 garage queen)
dmark is offline
Old 05-30-20, 05:11 PM
  #434
c0rbin9
Bikes: None
Quoted: 62 Post(s)
The frame will fit up to 47mm tires I believe, it's the rims I'm worried about.
c0rbin9 is offline
Old 05-31-20, 02:26 AM
  #435
rseeker
rseeker's Avatar
Quoted: 318 Post(s)
Liked 149 Times in 104 Posts
y'all: https://www.bikeforums.net/classic-v...l#post21506944
rseeker is offline
Old 05-31-20, 10:21 AM
  #436
dmark
Quoted: 184 Post(s)
That's pretty wide for what is a basic road type rim but...
I've gone wide on narrow rims but not that big a difference.
dmark is offline
Old 05-31-20, 07:46 PM
  #437
hokiefyd
hokiefyd's Avatar
No worries. I've had 2.1" tires on my Giant Roam's rims before (54mm tires on 19mm rims). Keep proper inflation in them and a 43-45mm tire will be just fine.
hokiefyd is offline
Old 06-01-20, 07:11 AM
  #438
dmark
Quoted: 184 Post(s)
Did the cornering get a little squirmy? That would be my concern; granted it is not a race bike.
BTW: Were you on Odyclub? (Honda Forum) If so I appreciated your transmission saga. My 2001 just got to 94,000 and has a flare between 1-2 now.
Last new bike 1991
dmark is offline
Old 06-01-20, 11:08 AM
  #439
hokiefyd
hokiefyd's Avatar
The lower the pressure, the softer they felt. Of course, that seems obvious, but it's particularly the case for wide tires on narrow rims. I'm about 240 pounds, I ran them at about 30 psi front/50psi rear. I ended up taking them off because I bought a dedicated MTB, so I put 40mm hybrid tires back on it.
Be careful also with tread design. Tires with larger side knobs, especially when run at a lower pressure, can give you some "self steer" as you lean. That is, the tire feels like it wants to keep pulling in the direction you turn. The bike can feel less stable because of that. I have owned a few tires like this, and have started preferring tires with a more rounded profile, with less accentuated side knobs. My MTB currently has 2.1" WTB Nanos. They have a pretty round profile that doesn't seem to self steer much. I can directly compare those with 2.1" Vittoria Mezcal tires on the same wheelset and the same bike. At pressures higher even than I'm running the WTBs, but the side knobs on the Vittorias would stick out and want to grab the ground, creating more of the self steer feeling. I had to run them at a much higher pressure in order to get rid of that feeling.
I don't think so. I have an '05 MDX and an '09 Ridgeline, both with good transmissions. The MDX has almost 180k on it and the RL has about 140k.
hokiefyd is offline
Old 06-11-20, 11:22 AM
  #440
GeezyRider
GeezyRider's Avatar
Bikes: There is always room for one more.
Quoted: 183 Post(s)
Liked 379 Times in 222 Posts
1996 Trek Multitrack
I took a perfectly good, if slightly beat-up, Multitrack and made a poor man's gravel bike:
Don
GeezyRider is offline
Likes For GeezyRider:
Old 06-11-20, 08:34 PM
  #441
Korina
Happy banana slug
Korina's Avatar
I beg to disagree; you made a gravel bike. Well done.
Korina is offline
Old 06-13-20, 08:11 PM
  #442
dmark
Quoted: 184 Post(s)
Trek 750 $120 posted 40 min ago in NY.
https://hudsonvalley.craigslist.org/...141410752.html
Last new bike 1991
dmark is offline
Old 06-13-20, 10:33 PM
  #443
GeezyRider
GeezyRider's Avatar
Quoted: 183 Post(s)
Looks like they smeared vaseline on their camera lens. Good way to hide any flaws.
Don
Old 06-14-20, 06:29 AM
  #444
dmark
Quoted: 184 Post(s)
Yes it looks rough but there are a few looking for lugged 750's.
Last new bike 1991
dmark is offline
Old 06-14-20, 06:40 AM
  #445
GeezyRider
GeezyRider's Avatar
Quoted: 183 Post(s)
You're right about that. I was happy to find my rough non-lugged 720. A lugged 750 in my size would have been golden.
Don
Old 06-14-20, 06:08 PM
  #446
c0rbin9
Bikes: None
Quoted: 62 Post(s)
There is a lugged 19" Multitrack 750 as part of a lot of bicycles in Galveston, TX on Facebook marketplace. Asking $25
c0rbin9 is offline
Old 06-17-20, 11:46 AM
  #447
Tinypunk
Clydesdale
Bikes: Trek Multitrek 1997 750
Liked 3 Times in 2 Posts
Post Bought Used - 1997 19" 750
New user to Bike Forum and needed to replace my old bike which was only used to tow the kids in the trailer. I am 5'9 and weigh 313, hoping to get out and ride for weight loss.
Saw this Trek 1997 19" 750 used on Craigslist and picked it up.
No cracks in the frame. Has majority of the original parts.
Specs as it is now below:
Frame Construction: TIG-welded
Frame Material: Chromoly, double-butted
Fork: Trek
Fork Material: Chromoly, unicrown crown
Component Group: Shimano STX/Alivio
Brakeset: Shimano Alivio M-System brakes, Generic levers,
Breakpads: Kool stop mtb black/salmon
Shift Levers: SRAM MRX Comp Set Twist Shifter - 7 Speed
Front Derailleur: Shimano STX, top-pull/clamp-on 31.8 mm
Rear Derailleur: Shimano STX
Crankset: Shimano STX, 22/32/42 teeth
Bottom Bracket: Shimano BB-LP26, 110 mm spindle
BB Shell Width: 68mm English
Rear Cogs: Shimano HG-30 7-speed, 11 - 28 teeth
Chain: SRAM PC-830 1/2" x 3/32" 114L fits Shimano Campy
Seatpost: Aluminum micro-adjust, 27.2 mm diameter
Saddle: Bontrager Commuter Gel CRZ+
Handlebars: Flatbar
Headset: 1" Tange-Seiki Passage
Pedals: VP 995a MTB Resin/Steel Platform Pedals
Hubs Front: Shimano Alivio HB-MC12 viam, Rear: Shimano Alivio FH-MC12 viam
Rims: Matrix Vapor, 32-hole
Wheel Size: 700c
Front Tire: Michelin Transworld Sprint Tires - Clincher 42-622 (700x40c)
Rear Tire: Schwalb Marathon Plus Tire (Wire Bead) 47- 622 (28x1.75)
Spokes: DT stainless steel, 2.0mm straight gauge
File Type: jpeg
File Type: jpeg
Tinypunk is offline
Likes For Tinypunk:
Old 06-17-20, 07:52 PM
  #448
hokiefyd
hokiefyd's Avatar
The bike looks great -- I also have a '97 750 in the Inkwell Blue, and it's a wonderful bike to ride. If your bike doesn't have the Silent Clutch rear hub, the hub may have been replaced at some point in the past...or the bike was a very early or late 1997 model that may not have had that component in place at the factory. Does the rear hub have a silent roller clutch hub, or is it a more typical freehub that clicks as the wheel spins forward?
hokiefyd is offline
Old 06-23-20, 07:38 AM
  #449
whewdoggie
Does anyone take their Multitrack on mountain bike trails? I discovered that there are some excellent singletrack trails near my house, nothing too gnarly, but I would rather not take it there if it's just going to damage it.
Am I crazy for wanting to slap some 700c x 47mm tires on this thing and ride trails?
All the time. I have 29"x48mm bontrager XR1 tires on my 1995 730. I get some looks and comments on more gnarly trails and am slower than the dedicated trail bikes but it's a blast.
whewdoggie is offline
Old 06-23-20, 07:54 AM
  #450
whewdoggie
I wouldn't getbet against it. My '97 750 is 28 pounds, and that's fully stock, with the heavy silent clutch rear hub, the relatively heavy STX cranks and running gear, and the fairly sturdy Matrix Vapor wheels. The rear wheel alone is a pig, and newer wheels that are reasonably light could probably shed two pounds right there.
My 95 730 was a bit under 26 pounds before I mods.
