Suspension or not?...neck issues...
Bikes: Bachetta Giro 20 recumbent, Brompton folder (I like odd bikes!)
HI! I have a Bachetta Giro 20 with the mesh seat, and large "trekking" smooth tires. I have noticed that lately when I hit cracks in the pavement, the shock goes right up into my shoulder/neck area, and sorta gives me a bit of a headache. My shoulders are contacting the metal rails of the seat. If I lean out of the seat back it's fine. I have tried changing the seat angle to more vertical, and that helps a bit.Thought about a foam pad behind the shoulders..?
Question: Anybody else figure out a solution or experienced this? Is the the other type of Bachetta seat less prone to that? (The narrow foam covered one)
I really don't want to spring for a Streetmachine or a Grasshopper at this point.. : )
Thanks!
Thanks!
Zircon Encrusted Tweezers
Quoted: 260 Post(s)
Liked 129 Times
Thanks!
Thanks!
Quoted: 523 Post(s)
Liked 228 Times
One that I have seen mentioned many times on Bentrideronline is the Ventisit pad. They are model specific and not inexpensive. You might look there as there are some posts about rider's experience like this one from 2016 https://www.bentrideronline.com/mess...d.php?t=128176 Although mostly made for ventilation I guess they also provide some comfort as well.
I used the foam insert on an Haluzak Horizon SWB to increase the comfort of the mesh seat on it, Cheap and effective.
Quoted: 260 Post(s)
Liked 129 Times
