Wanted: headset press
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
FOUND: headset press
Ordered something, thank you for looking
Genesis 49:16-17
Genesis 49:16-17
Quoted: 634 Post(s)
Liked 444 Times
Looking for a headset press that can do a threadless tapered headset.
I'm not planning to use it a lot. I would absolutely settle for one of those cheapies that uses a threaded rod, a ball bearing sandwich on one side and a washer on the other. I'd have gotten one of the amazon/ebay ones but you know how shipping from China is going.
If you are desperate and want to go shade tree mechanic on this, I have used a variation of this for a while and it's worked well. https://www.instructables.com/id/How...stall-a-heads/ And mine is even more janky with just two blocks of wood and fender washers.
Bikes: a few that I can't recall
Quoted: 345 Post(s)
Liked 300 Times
You can EASILY make your own from a parts bin at the hardware store.
I will add pics later on.
the secret is to buy the "black" 5/8 threaded rod, not anything galvanized, zinc, or stainless
Disco Infiltrator
Liked 2,105 Times
Thanks guys, I ordered a simple one from a US seller much like the one above
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 634 Post(s)
Liked 444 Times
This is great! What do you call the silver stepped metal pieces in the middle? I wouldn't know where or what to look for at the hardware store to find those.
Quoted: 938 Post(s)
Liked 2,939 Times
Likes For ascherer:
Quoted: 1106 Post(s)
Liked 1,327 Times
A long time ago I bought a press made from all-thread, two washers, and four nuts. Two of the nuts threaded on the rod, two were flanged and large enough to slide on the rod, and the nut portion was ground/filed away on the corners a bit so it would fit in the cups.
When it arrived I realized I could have had it faster and cheaper with bits from the local hardware store.
As for "black" vs. galvanised, that should not matter. It's not like the nuts won't work if there is a wee bit of zinc on the threads.
