You think it’s accurate that a gravel bike is potentially 20% slower than a road bike
#51
Quoted: 86 Post(s)
Liked 51 Times
Jan Heine had a good article on this:
https://www.renehersecycles.com/are-...an-road-bikes/
It discusses the GCN video posted above.
Are gravel bikes slower than road bikes?
1. If tests show dedicated road bikes are faster, those tests are stupid and irrelevant and wrong, racing is stupid
2. If any test shows gravel bikes are the same (or touring, or city bikes etc etc), see this is exactly what I've been saying about bikes for centuries
He has a right to his opinions, and I'm certain that some of his research and testing is valid. But he's not one to let objective reality interfere with his logic or the conclusions he's been advocating for a generation. So I find it tricky to tell the valid tests apart from the editorials.
Likes For fourfa:
#52
Just took the gravel bike out yesterday, 25 miles of pavement to get to Fairfax before dirt. Being not slow is nice so this doesn't take all day. Felt about the same as my aero race bike on pavement. I'm sure it must be a bit slower, but more like 2% than 20%
#53
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I did a lot of testing last year. Answer - it depends on the tire.
A good gravel tire (I used Ramblers and G-One) was not a lot different than a "training" road tire. I used a Conti-4 seasons.
Most people don't ride a gravel bike at 30mph like GCN does. But I tried it. Rambler and the 4-season were similar, with a slight edge to the slick. at 30mph, those tires had about 60 watts of rolling resistance.
The GP5000 were only 25watts rolling resistance. That is like adding 30-35 watts to my threshold power. Try doing that by by training! It also lowered my heart rate by about 5bpm at speed. And, they just felt like I was riding on ball bearings (even though the road was crap).
Just riding solo on the road, yeah, GP5000 was about 8% faster - or about 1-2mph depending on my speed. Not sure why GCN needed so much power for the gravel tires. They should not have any where near that much drag - even at 30mph.
Yep the GP5000 are amazing. But comparing a gravel tire to a 4-season training tire, there wasn't much difference.
Likes For chas58:
#54
Non omnino gravis
I just did my Tuesday morning loop on my SSCX bike, and less than 5% slower than a comparable effort on my carbon road bike. So that's the same course: 18lbs, 22 gears, 700x23s vs. 25lbs, 1 gear, 700x34s. Effort... similar (at least a similar stress score.)
Ended up 4 minutes difference over 50k, 1h41m for the road bike, 1h45m for the SSCX. I'm sure a lot of it comes down to tire-- there are some really slow tires out there. But geometry? Doesn't mean all that much to use mere mortals.
#55
Quoted: 1218 Post(s)
Liked 298 Times
I did however choose the RDO over the 853.... so it's not all about comfort. (part of that choice was standover) though. I figured I could run a gp5000 32c, Jon bon 35 barlow pass 38, snoqualmie- 45 riddler, or 42 resolute also.
A 650 switchback hill is very tempting but I've heard of them ballooning. Niner says 2.0 for the 650b so possible.... I am really undecided, and I'll also be seeing a huge mix of surfaces with this bike
#56
Quoted: 232 Post(s)
Liked 146 Times
On similar routes, I'd cruise at 32kph on my TT old titanium bike, and about 29kph on my gravel bike (ie. easy 6 RPE efforts )
Just based on that, its about 10-8% slower.
That said, my gravel bike is at least 3kg heavier with a maybe a 100g heavier disc wheel (TT bike has rim brake wheels)
Not to mention the aerobars.
So not fair comparisons, though in real world situations a gravel bike does some things the TT bike can't, so they are what they are.
With a lighter gravel bike with 28mm tires, maybe that 10-8% difference will shave down to 3-5%?
The marketing hype on wider tires to me only holds weight if a lot of the roads are really bad.
I have noticed that I sail thru such sections on 42mm tires compared to other riders if they are on roadbikes.
There is just too much bumping up/down with very high pressure tires that there is a loss of fwd traction. (even more so it its bad road + climbing )
#57
Liked 415 Times
I am the point now I'll take comfort over speed. but I also don't enjoy rides that i have to work for it. Meaning if I have to put in that much effort then I better be going faster.
Since this year, group rides are out, I've been riding the 40mm tires - cause why not. Kinda like the way the Terra Speeds look on my bike. But certainly when I'm back to commuting and fast group rides (where I'm the only one not on a road bike), I'll choose the easy speed.
Likes For chas58:
#58
Quoted: 147 Post(s)
Liked 8 Times
Won’t make a difference to most people, unless they’re elite roadies.
Then you’ll need the lightest, fastest road bike money can buy. Irrelevant to 99% of the population.
#59
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
#60
jj
Quoted: 140 Post(s)
Liked 110 Times
I’ve been asking myself this a lot. I really want to love my ‘16 Kona Roadhouse even just half as much as I do my ‘86 Trek 770. I don’t.
Tires do make a ton of difference.
my “gravel” bike has become the Roadhouse when it’s with 32c Paselas. It has a 72 deg headtube
my Roadie is the Trek with 25c Corsas. It has a 74 deg headtube. Also it’s a lot more flexible.
I haven’t yet looked at the trail difference to totally say that geo is doing something to me. Their stack and reach aren’t far off. I’ve done everything I can to make the bb-bars-saddle relationship close to identical between the two bikes.
Even with the Corsas on the Kona, no matter how hard I hammer it, how much time I spend in the perfect tuck, I am slower on it than I am on the Trek.
Getting off of a 100miler on the Kona and being ready to pass out and just taking the beat up old Trek to grab some groceries, I feel ready to hammer out another hundred miles. If I do the opposite, I find I’d rather walk to the store.
I think that some of it is the tires, but more of it is (I don’t know which) in either the modern fork’s extra stiffness fighting back at every pedal stroke or the slack geometry that asks your legs “what’s the rush? Why not sit up and ease back for a bit”
20%? I don’t think it’s that much. My trying-to-snap-the-cranks-off-on-the-Kona times are only about 2-5% longer than my having-fun-on-the-Trek times on the same routes. I’d sure love to experiment with some powermeter pedals to have an answer before I give up on the Kona and try having Waterford build me a wide-tire-clearing copy of my Trek.
#61
I ride a road-plus bike, going for safety over max speed: if I hit an unexpected road anomaly on my 48mm tires at 30psi, I'm unlikely to lose control; while hitting the same thing on a 23mm tire at 110psi may lose control. If you lose control, you probably injure yourself, with the broken clavicle being one of the common injuries. While you are recovering from the injury, you are losing performance at an exponential rate. So from my perspective, if the road-plus bike has protected me from crashes that I would have experienced on a typical road bike, then the road-plus bike is the faster bike (because it allowed my engine to grow stronger).
#62
If I could switch my 46 large (gravel) chainring to a 50 or 52 and my tires to GP5000 tubeless with very little effort, I wouldn’t own a road bike. The 46 with shorter tires spins out way too soon.
Alas it is pretty easy to just grab the bike I want to ride and yeah, the road bike with 32mm tires is considerably faster on the pavement than my (much more expensive) gravel rig with 45’s. I don’t like going slow.
#63
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Likes For Noctilux.95:
#64
Non omnino gravis
#65
Liked 415 Times
Again, its fun riding my bike in a semi-competative road ride. 32mm GP5000 tires with tons of clearance, when everyone else is on 25mm 100psi road tires on road bikes. I get comments on how I'm a lot faster than I look (especially when sprinting to the front of the pack at 30mph), and people squeezing my tires to see how much pressure is in them (50-60psi). Personally I think on our crappy roads, this bike is faster than a pure road bike on 25mm tires.
I don't own a road bike. Its easy:
I'm riding the gp5000 in the rear all summer/fall. I do put a fatter tire on the front if I'm going for the rugged stuff (its worth it to get a second set of wheels for me).
I don't know how to spin out on 46t chainring. I can pull hard at 40mph, and above that its much more efficient just to draft or tuck.
(but hey, I'm a trackie. I'm not spinning out on the oval until I'm going over 40mph with a 49x15, lol)
#66
Expired Member
Quoted: 3672 Post(s)
Liked 5,430 Times
#67
put efficient rolling slick tires on it and see if it feels faster,
set up a time trial course & compare times with you on both bikes?
#68
Liked 415 Times
(I did do a group ride fixed gear once, but doing 180rpm down hill isn't something I ever want to do again, lol).
Likes For chas58:
