6mm tap, US/standard drill bit size?
I have tap for a 6mm hole but don't have the correct, metric drill bit (5.2mm).
13/64in = 5.159mm
Can I use a 13/64in bit? The answer seems like a yes to me but I would love an answer from someone with experience. First time using a tap.
Thanks!
*I am tapping a brazeon on my seat stay that stripped. Previously 5mm.
13/64in = 5.159mm
Thanks!
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Close enough especially given the slop of using a hand drill.
Use cutting oil, tap straight, back in and out often
Likes For dedhed:
Quoted: 1438 Post(s)
Liked 1,092 Times
According to this chart, assuming M6x1 you would be better off using a #8 or #4 drill. For M6x0.75, #4 or 7/32. I always err on oversized, tapping into an undersized hole greatly increases the risk of breaking the tap. https://littlemachineshop.com/images...DrillSizes.pdf
The 13/64 should work fine. I found a set of metric combination drill/ tap bits at harbor freight that work great for through hole tapping. I put them in my makita impact driver.
Likes For andrewclaus:
Quoted: 4197 Post(s)
Liked 3,849 Times
The M6 tap is a 6mm x 1mm per thread. Not .75mm per thread. MY understanding is that the "M" references a single "standard" thread pitch, in this case 1mm per thread. Andy
BTW this type of info is readily available by a quick Google search for tap drill size. (Just like a lot of other info) Andy
AndrewRStewart
AndrewRStewart
Really Old Senior Member
.041mm is .00163".
I doubt you could drill 2 consecutive holes with the same drill bit and get that close on both.
Likes For Bill Kapaun:
Liked 1,092 Times
Thanks to all for help. This worked great, rear rack is back on.
For anyone else needing to do this here's what I did.
Thanks again!
- M6 x 1 (coarse) tap
- 13/64 bit - made a couple passes after going through.
- used 3-in-one oil to lubricate tap but WD-40 would probably be fine and i saw that suggested in my research.
- I went really slowly and backed out every 1/4 turn or so and cleaned tap and re-oiled. Overkill I'm sure but not hard to do.
Thanks again!
IIRC, taps came in starter, full & plug.
Plug for finish threading blind holes.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
You worked faster than I typed! Glad it came out ok. Glad the 13/64 dill worked. Generally, 3in1 or WD40 DON'T work as well as tap cutting oil, but this is water over the dam now. And for a through (and not a blind) hole, a tapered tap is fine. Running it into the hole to the point where its not tapered is what you want to do.
Typed before I read what you'd done:
Just a point of correction: the nominal correct size for an M6 cutting tap is often given as 5mm. That's for 100% thread depth. As a nod to practicality, most holes drilled for tapping specify about 65-70% of full thread depth. That's where you 5.2mm comes in (one formula is drill size = nominal thread OD - Percent thread engagement/76.98). A bit more accurate estimate using the formulas in the webpage below is between 5.1556 and 5.089mm. But here's the thing: if you use a hand drill, and/or a poor quality drill bit, your hole diameter is going to be larger than the drill. I would target a little less than the 5.09-5.16 target. For this reason, I'd use a number 8 drill (note that this is a NUMBER drill, and the number 8 is not mm). Or a number 7 drill if I had it. But you'd probably be fine with a 13/64 as well. With a number 6 drill of good quality and steady hand you'd be close, but still be too big for my taste. It might work. Use tapping fluid (normal oil doesn't do as good a job).
The penalty for too big a hole is a weak threaded connection. For too small a hole is difficult tapping and possibly a broken tap.
The advice above is for tapping into steel. If you have a notion to try your hand and at tapping titanium, my suggestion would be ... don't. Even drilling Ti can be problematic - it work hardens something fierce and the drill tends to wander as a result. Get someone who's done this. If you must, read up first on drilling Ti, then on tapping Ti, and do some research and get a really good drills and taps. Emuge, Prototyp... etc. And use moly-dee or some other good lubricant.
No. 8, 5.05mm, 0.1990 inch
No. 7, 5.11mm, 0.2010 inch
Fractional 13/64, 5.16mm, 0 .2031 inch
No. 6, 5.18mm, 0.2040 inch
For tap drill sizes:
https://www.natool.com/wp-content/up...atp113-116.pdf
For available drill sizes:
https://www.imperialsupplies.com/pdf...DrillChart.pdf
SE Wis
Liked 3,390 Times
My only concern was that I hadn't realized that some taps are 'tapered' and some are 'bottom'. It seems my tap was slightly tapered but reached the correct width (6mm) within about 1/4" of tip. Had the taper been any longer (not sure if this is standard), it would have been a problem because it would have maxed-out against the inside of the seat stay prior to reaching full width.
You can turn a tapered tap into a bottoming tap by grinding the tip as needed.
Quoted: 3948 Post(s)
Liked 7,291 Times
4.7 mm drill => 100% threads
5.0 mm drill => 77% threads
5.2 mm drill => 61% threads.
Liked 341 Times
The metric thread form specification is shown on Wikipedia (below). I suspect that we agree that the theoretical thread height H, is sqrt(3)/2 * pitch. Pitch being 1mm, then, H equals 0.866mm. The thread form does not contain the top H/8 of the thread crest, nor the bottom H/4 of the thread root. This makes it stronger than the early American National Standard which used sharp root and crest. The current Unified (flat root) or Metric (allows for rounded root) standards are stronger. Anyway, the internal thread radius is 5/8H less than the nominal, or 5*0.866/8 mm, or 0.541mm. That's 1.082mm less in diameter. So 4.88mm should be 100%. The 13/64 drill bit is 5.159mm. I get this as being 77.6%. Given that most folks target 65 to 70%, and a hand-held drill is gonna make a hole that is a bit oversize I think the OP chose just about the perfect setup.
But where is this discrepancy coming from? 4.7 vs 4.88 for 100%, and 5.16 being either 77% or about 63%?
Can you share your source? I'm going to dig out may Machninists Handbook to see if I can find the numbers in there.
Liked 7,291 Times
Don't ask me why, but 3/4H is usually considered 100% thread percentage rather than 5/8H. (I think it's actually due to an historical issue in the U.S.). The differences you note arise from whether you choose 3/4H or 5/8H as 100%.
Using the 3/4H convention, the simple rule of thumb for 77% threads is: (Drill size = Thread diameter - Thread pitch). That's the basis for the vast majority of thread charts, with sizes rounded to the nearest common drill size.
For other thread percentages, there are many online calculators:
https://www.guhring.com/tech/TapDrill/
https://www.kennametal.com/us/en/res...rill-size.html
We're getting information from different sources apparently. I'd like to know 1) the correct sizes (and yours may be), and 2) the source. I put links in my post - do you have source info, or a citation for the above?
Liked 341 Times
I guess the key point is that 0% is 6mm. And 5mm is either 92 or 77%. And 5.16 is either 77 or 64% All reasonably good numbers (tho 92%, if true, might cause some taps to break).
I asked the question: 5/8 or 3/4 on a site for professional machinists I visit. Will report back if there's any clarification. In the mean-time... Use a number 7 drill! It's 5.105mm!
Liked 7,291 Times
The two charts you referenced in a previous post list 5.00 mm and #10 (4.91 mm) as the drill size for M6 x 1 threads.
Liked 341 Times
Just got a note from an experienced machinist. He's in England, so presumably knows metric specs. He says that while 5mm is the standard, "However 5mm = 0.1969'' ……….on tough / hard / horrible material, where I can, I use 13/64 = 0.2031'' the extra 0.0062'' making life easier."
Liked 341 Times
The topic has been discussed numerous times on Practical Machinist. Search the website ...
Liked 341 Times
Also noted that you have questions on PM regarding tapping M6x0.5, and tapping Invar... (Assuming that you use the same Tomato Coupe name). Above my experience.
But, as I said, 13/64 gives you a pretty good (77% or 65%) thread engagement either way. And the OP (who has long ago gone out for a bike ride) got his rack mounted.
Old trick my Dad a machinist , (& WW2 Vet), showed me,, hold the tap up and the twist drill ,
right size you see the valleys of the teeth in the tap behind the drill you are holding in front of it..
Liked 7,291 Times
