Am I a Fred?
Am I a Fred?
My stack is pretty high.
Do I look like a fred? Getting close to Fred territory?
Likes For ups:
Quoted: 822 Post(s)
Liked 1,960 Times
There's a little Fred in all of us. We all started when we didn't know any better.
Likes For CAT7RDR:
Quoted: 18412 Post(s)
Liked 15,535 Times
You could slam your stem, but you’d still be a Fred. Embrace your lot in life.
Likes For indyfabz:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,990 Times
Are your present at all the Manchester United games and other press events where a mascot would be helpful? if so you are probably Fred if not probably not.
Likes For raceboy:
Quoted: 2952 Post(s)
Liked 3,106 Times
I dunno. Is this you?
Likes For caloso:
Likes For Oldguyonoldbike:
Quoted: 1814 Post(s)
Liked 923 Times
Not enough stuff on that bike.
Bigger saddlebag, at a minimum.
I'll bet you don't even have facial hair, or a flappy jersey.
No water bottles, 'tho, so maybe you have a camelbak.
Likes For Camilo:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
SPD pedals on that bike: #notpro
How do you hydrate?
- Bidon in jersey pocket: pro
- Hydration pack: notpro
- Fanny pack with bottles: fred
How do you hydrate?
Expired Member
Quoted: 3672 Post(s)
Liked 5,426 Times
Looks as if you could have gone one bike size larger.... That is a pretty good bit of spacer height but the indication there may be a Camelbak involved is at least as worrisome. Not to mention the non drive side pic.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
If your mind is small enough to think in terms of "a Fred" then you have other ego, self-confidence issues to worry about.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Point of order:
IMO order a different drop bar, don't try to gain a hand position by altering the mounting rotation of the bar in the stem. The reason bars come with tick marks where the stem mounts isn't so one can Fred-it-up by swinging that sucker skywards. The reason is so you can match the bar mounting up to the stem/headtube angle your bike has.
If having a piece of bar between the bottom of the drops and the hooks is a thing for you, order a bar like that.
Otherwise, I wouldn't rotate the bar up like that. It's either a bad solution to having the wrong bar, or a fit coordinate problem.
It's a geometry and forces thing. Imagine using the bar for leverage to do hard work using the hooks..........you're going to be racking the steering back and forth and may crash. Using the bottom of the drops means the force goes up/down through the bar, not affecting steering.
Likes For burnthesheep:
Expired Member
Liked 5,426 Times
How do you hydrate?
How do you hydrate?
I don't think these updates influence my Fred factor.
