Puncture changing upside down?
Do you think it is improper to turn a road bike upside down to change a puncture? I ride with a group of skilled cyclists and a newcomer turned his bike upside down to remove the rear wheel. Needless to say, heads turned.........
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
IMO it is improper to turn the bike upside down. Why?
It scratches the saddle. Maybe this doesn't matter to some, but it'll ruin a good leather saddle.
If you ride classic brakes not wrapped under bartape, it bends the cables, and they have a memory.
Likes For trailangel:
Quoted: 2026 Post(s)
Liked 1,096 Times
As mentioned it's hard on the saddle and bars and can cause fluid loss and air entry if the bike has disc brakes. But, then, it wasn't my bike so I don't care what that guy did to his.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
I'm seeing rim brakes and unless that grass is really sharp, the saddle is in no danger.
Their bike Their call.
Likes For dedhed:
Quoted: 5224 Post(s)
Liked 3,581 Times
who cares? it's his bike. I would love to do it that way, like I did in the 70s, but my bikes have stuff on the bars that would hit the ground before the bars, so I just lay my bike down. side note: if you know exactly where the puncture is like w/ a thumbtack you don't even have to remove the wheel from the bike. keep the bike anyway you like, get 1/2 the bead off, sneak part of the tube out, patch the hole, sneak it back in, get that part of the bead back on, & inflate!
Likes For rumrunn6:
Likes For woodcraft:
Quoted: 1572 Post(s)
Liked 643 Times
Back in the days when men were men and bike frames were steel, the brake cables used to stick up making it possible to kink the housings if you tipped your bike upside down. If I ever owned a bike as nice as that Pinarello I think I'd turn it upside too just so that everybody could read the brand label on the down tube.
Likes For Retro Grouch:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12767 Post(s)
Liked 7,679 Times
I flip mine all the time, unless there's a handy tree with a branch that's just the right height to hang the saddle nose on.
Unfortunately they're rare around here
I always do it like this if there's a soft surface nearby (to avoid damaging de seat). I remove the Garmin first though.
The bike only touches the ground with the seat and the rubber grips.
Have been doing this for years and I have never damaged the bike nor had problems with hydraulic brakes (just make sure you don't press the brake lever with the bike upside down).
Quoted: 6193 Post(s)
Liked 4,808 Times
It doesn't bother me. For some things like adjusting the DR it usually won't work. For a tire change, why should anyone care. I suppose some might be thinking how they heard it's so bad for hydraulic brakes, but as far as I know that is only some of the early ones or maybe certain types.
Heads probably turned just to see what was on the underside of the downtube, or whether or not his water bottles were leaking.
who cares? it's his bike. I would love to do it that way, like I did in the 70s, but my bikes have stuff on the bars that would hit the ground before the bars, so I just lay my bike down. side note: if you know exactly where the puncture is like w/ a thumbtack you don't even have to remove the wheel from the bike. keep the bike anyway you like, get the bead off, sneak the tube out, patch the hole, sneak it back in, get that part of the bead back on, & inflate!
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
I'd be concerned about debris getting into the delicate, complex, and expensive brake/shift levers when upside-down.
If you're with a group, have someone hold the bike while you remove the wheel. Then lay the bike on its side, derailleur side up, while you deal with the puncture. Then have someone hold the bike while you re-install the wheel.
If you're by yourself, it's not that much harder. Lay the bike on its side to remove and reinstall the wheel.
LR÷P=HR
Quoted: 866 Post(s)
Liked 1,204 Times
I've always flipped mine. But the are all Rim.
Never even considered not flipping a disc, thanks for the pointer.
Barry
Barry
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
I wouldn't flip the bike. I hate flipping bikes. Especially if you are in a group you can easily have someone help you hold the bike if absolutely need be.
Likes For veganbikes:
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
Quoted: 645 Post(s)
Liked 797 Times
I do this all the time - I’m not having my RD or crankset sit on the ground, regardless of what anyone says. Are you supposed to remove/install the wheel with one hand while holding the bike up with the other? Bollocks to that
Likes For Litespud:
Quoted: 836 Post(s)
Liked 1,061 Times
+1. Can't believe some think this is such a heinous thing to do. The bike in the OP's photo looks like it's on dry grass. Probably the best type of outdoor surface to do this on. Disc brakes maybe not a good idea. A saddle or brake hoods sitting on the grass without a rider on it compared with your sweaty arse and grubby hands rubbing away on them for thousands of miles. No comparison.
Coming from the sane mountain bike world and not the nutty road biker world we flip them
And that is with hydraulic disc brakes OMG!!!!!!!! The whole flipping hydraulic disc brakes being bad thing is way WAY over blown. Yeah you might not want to store them upside down for long periods of time but a few mins won't hurt anything. Even if you do end up with spongy brakes from doing it you just squeeze the lever 3 or 5 or 10 times and they fix themselves 95.87% of the time.
Even on roadie rides I don't remember ever seeing anybody get a flat and not flip their bike to change it, I know I always have. Never had a pure roadie make any weird comments when I have had to change a flat. All my mountain bikes run tubeless now so the bike that has been flipped the most to change tubes is the road bike and it is also the only one that has 0 evidence of being flipped, no scratches from it. If anything I would give you an odd look for not flipping it since it makes everything so much easier.
Likes For Canker:
Quoted: 4559 Post(s)
Liked 2,802 Times
I use my portable, inflatable, dehydrated iWorkstand. Fits in a tiny Lezyne Road Caddy saddle bag.
Unless hardcore roadies are watching. Then I just flip the bike upside down. I don't like people asking about my workstand.
Quoted: 576 Post(s)
Liked 1,001 Times
But its your bike, do as you wish.
Likes For DorkDisk:
Likes For Moe Zhoost:
Quoted: 576 Post(s)
Liked 1,001 Times
I can see under-the-chainstay U-brakes needing flipping on the trail, however.
Liked 742 Times
Can't believe a rider cannot hold the bike with one hand and remove a wheel with the other!
Rubber side down only please.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
