I stink
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I stink
Literally
after any strenuous ride in my cycling jerseys I am surprised how pungent my jersey’s underarms get (yet my underarms don’t seem to smell much at all). This never seems to happen with cotton T-shirt’s.
is this peculiar to me or to synthetic materials?
anyone else surprised by their post ride aroma?
Quoted: 358 Post(s)
Liked 136 Times
Eat less Red meat. Red Meat tends to make some cyclist "smell" after their ride. I'm not sure why this happens but I have experience some bike riders after they ride. Man, that smell is "special".
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
The short answer is synthetic fabrics tend to smell worse. Fabrics that do not absorb water still absorb body oils during exercise. They also are harder to clean. Lots of good articles on this on the interwebs.
Likes For ericcox:
Quoted: 18420 Post(s)
Liked 15,568 Times
5 Foods That Can Increase Your Body Odor | Next Avenue
Likes For indyfabz:
Quoted: 5224 Post(s)
Liked 3,584 Times
you're not alone. been there, done that
odor comes from decaying bacteria. your current clothing may be a lost cause. shower more or better & wash your garments immediately after rides. I have a small spray bottle of liquid laundry detergent which I sometimes use on armpits. one doesn't need expensive stain removers unless you are trying to salvage ruined clothing. I had a shirt one time that I really liked but it got to a point where I couldn't wear it w/o it smelling. it required repeated special treatments to unlock & remove the bacteria & dried deodorant that built up under the arms. I got it better but eventually moved on to other shirts. I have since figured out how to avoid the problem. 1 tip, if you can't do a load of laundry immediately after a ride, at least take some soap & water to the armpits before tossing in the hamper. but try to wash it the next day
Quoted: 6196 Post(s)
Liked 4,810 Times
Use some oxyclean or other non-chlorine bleach that has Oxy in it's name. The sodium percarbonate is also a sanitizer as well as a color safe bleaching agent.
I actually only use oxyclean when I wash my cycling clothes and I've never noticed that odors hang on to my cycling clothes. But maybe that's because odors tend to hang on me when I sweat for long periods. <grin>
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Likes For datlas:
Quoted: 2333 Post(s)
Liked 2,097 Times
Literally
https://journals.asm.org/doi/10.1128...rmanently=true
Quoted: 229 Post(s)
Liked 327 Times
I suffer from the smellies as well. I'm not sure how much of a difference it makes but when I shower after a ride I toss my cycling gear into the shower and wash as much of the salt and sweat out as I can. Squeeze out excess water, roll in towel, hang on drying rack.
Quoted: 1814 Post(s)
Liked 923 Times
I did that for quite a long time as well, but determined that things were not getting clean enough, contributing to smell, & even crotch funk.
Getting better results with normal machine wash & dry, permanent press cycle.
+1 on the oxy bleach to hopefully get back to baseline of no smell.
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Quoted: 967 Post(s)
Liked 1,631 Times
When washing my cloths I found that a good full second rinse helps allot. Modern day washers are designed to conserve water. If you look closely at your modern day washer cycle you will notice that the level of water in your rinse cycle is at a bare minimum to take the soap out. The soap has the oils and sweat locked into it. My solution was to go for not just a second rinse but a full wash cycle to get all the soap out.
I start the wash cycle with soap. After the wash cycle starts I wait a few minutes for the soap to do its stuff, about 3 min of churning. I then drain and spin then start again with a full wash cycle. This has been the only way for me to get all the soap out of my clothing without beating my cloths to death.
Synthetic clothing that has elastic and can be extra hard to clean because the relaxed spandex traps the oils and sweat. The problem is if you use stronger detergents or bleach you kill the elastic fibers too. If this is the problem then hand washing the item in a solution of BORAX and gently stretching the clothing to get the solution deep into the material will do the job.
Here's another one. Had a guy leave his kit outside on the lawn chair to air out after a ride. It was promptly nailed by a male cat then followed by his dog who actually tried to bury it afterwards... Ha. Anyway, he could not get the cat smell out. He finally soaked the items in a dish pan with 1/4 cup solution of Enzymatic Cat Urine treatment. He said it worked excellently and he also uses it for the inside of his salt water fishing shoes.
Likes For zandoval:
Liked 15,568 Times
Those of us who tour often do that. I actually start the shower with my bibs on. Jersey I take off first because it can be more difficult to do so when wet.
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
I always hang my jerseys and bibs up to dry as soon as I get home from a ride. Once dry, I hang them in the closet, separated so I know which have been worn. Then once a week I wash everything. Bacteria don't thrive in dry anything.
Likes For genejockey:
Quoted: 207 Post(s)
Liked 108 Times
Yep, it probably was funky when you put it on, and the heat and moisture turned up the smell. Put in a bucket, add some water, and then enough ordinary white vinegar for at least a 50/50 mix. Soak overnight, then wash as usual, extra rinse no softener. I usually do this about twice a season.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Likes For SoSmellyAir:
Liked 1,471 Times
But this still means that the bacteria and other microbes thrive while your jerseys and bibs are drying.
Quoted: 18883 Post(s)
Liked 10,646 Times
Fire is the best tool for removing dork discs and BO. 🔥
Liked 11,912 Times
As opposed to being tossed in a hamper or left in a pile someplace.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
You might find being clean & showered before beginning any exercise will help.
A lot of commercial detergents are overpriced with the ingredients maximally stretched for "value" and an added innocuous scent to cover up the absence of clean. About 3/4 to 4/5 bar of Fels-Naptha or a full bar of Zote, 2 cups of washing soda & a cup & a half of Borax will make 5 gallons of HE non-sudsing laundry detergent & cost about $0.02/load.
IME: It's safe to use double in the machine. Setting the machine to "heavy soil" also usually adds an extra rinse cycle. For problematicly stinky funk from improper care, any funky item can be run through 2 wash cycles before setting aside to hang dry. That seems to dislodge any stuck funk.
Machine dry seems to "lock in the flavor," so to speak.
Car dependency is a tax.
Likes For base2:
Liked 1,471 Times
My butane torch is reserved for cooking. Perhaps hanging cycling gear inside out to dry in the sun's UV rays for a few hours is sufficient.
Nice dig!
There is no need to machine dry any sweat wicking synthetic fiber athletic wear.
Quoted: 338 Post(s)
Liked 408 Times
Shower before a ride. It helps with clothes getting smelly, saddle sores forming (less bacteria to start the party) and so on and so forth.
I have a small dedicated hamper for cycling/triathlon kit and try to wash it as soon as possible. Some guys I know rinse their kit in the shower after a ride.
If your kit has absorbed the smell, it's probably beyond saving. Better materials do seem to be more resistant to starting to smell, I have some free dry-fit running shirts which you get on various races and they are far more prone to starting to smell than quality triathlon kit.
I wash all the kit in the washing machine on the default sportswear setting and hang in the sun to dry.
