Average Male Inseam to Height Ratio?
big ring
Average Male Inseam-to-Height Ratio?
Does anyone know what the average male inseam-to-height ratio is?
Do manufactures set geometry with this proportion in mind?
My measurements:
70" (177.8cm) Height
32.25" (82cm) Inseam
46.1% Inseam to Heigh Ratio
I want to know - relative to the male norm for my height - is this short legged or long legged?
Based on the answer to above, which company's geometry would suit me? (Example: I know Lemond is good for relative short legged riders, but I'm not sure what that is, quantifiably.)
My measurements:
Aluminium Crusader :-)
there's an old thread about this with several measurements
https://www.bikeforums.net/showthread...ghlight=inseam
there are others, too, if you wanna search
I'm 182cm with an 89.5cm inseam
NOT PANTS INSEAM!!
Some of you Yanks seem to get pants inseam and real inseam mixed up
NOT PANTS INSEAM!!
big ring
Thanks for that link.
However, I wanted to know if there was a more authoratative source than individual contributions. Individual responses are nothing but statistical noise. It would be useful, though, to know what the aggregate view is. Hence my post.
SilentRider
Bikes: Trek Madone SLR 7, Giant TCR Advanced Pro, Trek Domane SLR, Trek Emonda SLR Project One (x2), custom Bingham Built Titanium road bike
but why?
There are so many other aspects to bike fitting. Throw this measurement away if you are after a good fit. Invest in a $75+ professional fitting at your [recommended] LBS and go from there.
Bike companies may well do this, but I have never heard of it.
big ring
Originally Posted by FrankBattle
but why?
I realize there are other aspects to fitting however no LBSs that I know of offers a good fitting. It's mostly intellectual ************ - plus I'm curious.
I already know the tight window as to my size. Mostly, I'd like to know the tendency of manufacturers to cater to certain proporations (as in the Lemond example I used earlier.)
Bikes: n+1
check out the charts at the bottom - seems he's had years of experience
https://www.prodigalchild.net/Bicycle6.htm
SilentRider
big ring
The way I determine frame size is to start by saying this equals two-thirds of the rider’s inseam. (This is a starting assumption, other factors need to be taken into consideration.) This means that for the taller the rider, the amount of seat post showing out of the frame increases progressively. The resulting difference in the handlebar to seat height ratio accommodates the taller rider’s longer arm length. The handlebar stem also increases in length for a larger frame. The top tube length on larger frames increases at a lesser rate, because the upper body length increases at a lesser rate.
Ah yeah. I understand intellectual curiousity. Stab in the dark here, but you could just try emailing the technical departments of whichever bike company you are interested in .. Worst possible answer is "no." No?
Bikes: n+1
[QUOTE=MIN]Interesting insight from that link:
[I]The way I determine frame size is to start by saying this equals two-thirds of the rider’s inseam.
I think things were thought to be a little more clear before sloping top tubes.
Biker looking for a ride!
Bikes: Kuota Kreedo...looking for something different.
Height 188 cm
crotch 84 cm
trunk 73 cm
arm 79 cm
44.68 %
crotch 84 cm
trunk 73 cm
arm 79 cm
44.68 %
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Quoted: 1743 Post(s)
Liked 1,281 Times
My measurements:
My measurements:
SilentRider
Because you guys respond quicker. Isn't that the purpose of an Internet forum? To share ideas and filter out the sh1t?
You asked a specific question (relating height/inseam with frame size) to which you will get a myriad of answers since not everyone is riding the right fit bike. To get a specific (or reliable) answer, you need more than forum answers. Besides, people probably lie about their inseams and/or height. Imagine that.
Eternal Cat3 Rookie
Bikes: 2004 Giant TCR2 Composite & 2006 Fuji Touring
why would people lie about their inseams and height?
Don't know if you have a background in statistics or not. Bottom line is inseam length (independent of height) still dominates for the vast bell curve of cyclists out there. There is a correlation however. Dave Moulton's chart is derived by thousands of fittings and he is a pre-eminent expert on the subject. So is Sheldon Brown. Both subscribe to the 2/3 X's cycling inseam for frame size. I do too. Statistically most (not all) derive their height in their legs. Tall people many times have pedestrian length torsos. This applies to Sheldon Brown and myself and countless others. As a result, bicycles are designed to grow vertically almost 2:1 versus horizontally in frame size. This is not happenstance but based statistically on a normal distribution of height to inseam ratio. The reason that seat tube length or now virtual seat tube length with the advent of sloped top tube geometry bikes predominates is because virtual or actual seat post length dictates head tube length. In the grand scheme it is the ratio of seat post to head tube length that matter for saddle to handlebar drop. The other prevailing factor is top tube length and again, top tube does not increase nearly as must as seat post and head tube length between frame sizes which agrees with the statistical norm that torso size does not change nearly as much as inseam for different size people.
HTH,
George
HTH,
George
Eternal Cat3 Rookie
I'm tall and my inseam is 50% of total height, seems to reflect what George said.
SilentRider
NorCal Climbing Freak
This is a rhetorical question, right?
Quoted: 1581 Post(s)
Liked 1,189 Times
Here's the ratio I recall reading a while back in something by a sports doc (it was cycling-related): for males, dividing total height by true (cycling) inseam (bare feet/floor to pubic bone) will typically give a number somewhere between 2 and 2.2. 2 is long legs, 2.2 short (both relative to total height). My case: 174.5 t/h, 84 cm inseam gives 2.07, so tending slightly toward 'long legs for height/short torso.'
