Saddle question
Bikes: Giant XTC 1 SE
Saddle question
Couple of months ago I bought a road bike . (rode mountain bike for years) Giant Defy 2. And overall I am happy with the bike. Except for the saddle. It sucks. Did not feel right when I bought bike, but I wanted to ride bike awhile and see if I could adapt to it. Not going to happen. After about an hour, it becomes very uncomfortable.
Young man at bike shop in Little Rock reccomended a Specialized Romin saddle. I had test rode a Specialized bike when I bought my Giant and I do remember the saddle being superior to the saddle on the Giant. So, anyway, can I get some saddle suggestions from my fellow 50+ crowd?
Liked 6 Times
You've just opened a can of worms with this request. Saddle threads can get VERY opinionated. Having lived through more than a few on this forum, here's what I can tell you.
1. There is no universal agreement on which is the "best", "most comfortable", etc. Each has their own opinion.
2. Sometimes it's an issue of adjustment of the saddle and not the saddle itself. Just a few millimeters in tilt, for example, can make a very big difference in comfort.
3. Sometimes the correct saddle has a lot to do with your overall body position. For example, sitting up in a more upright position will put more of your weight on the saddle.
4. If you can get a good LBS to loan you a saddle to try for a few days and return if not satisfied, that's always a plus.
5. Someone will tell you or state that riding a recumbent will eliminate the issue entirely.
6. Someone will tell you that Brooks is the only saddle you ever need to buy.
Realistically, it is a trial and error process. I currently ride four different saddles. The only things they have in common are: a relatively flat profile on the top of the saddle; they are all fairly firm; they all or at least 150mm wide on the back section of the saddle. Good luck with your search.
Attached are my saddles: Selle Italia SLK - Specialized Toupe - Selle Anantomica - Koobi Xenon
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Bikes: Diamondback Edgewood LX; Giant Defy 1
I have the Giant Defy 1. I gave the saddle nearly 10 days of riding with a several adjustments at the LBS and it still wasn't working for me. I test road a Specialized Avatar Gel for 5 days of riding. I tried a Fizik and ended up with the Avatar. You need to test the saddle for several days and some good distances as well. Also, your butt is going to have to get used to the new position. Test out some saddles but you need to be able to test them for several days of rides. Nos88 has great advice.
Behind EVERYone!!!
Bikes: 2010 Specialized Tricross Comp 105 Double
Quoted: 54 Post(s)
Liked 97 Times
Both of the above are, pretty much, spot on. I have been riding road for years and have, finally, found the saddle for me. That saddle is the Specialized Romin Comp and mine is the 155mm wide version. I tried 5 different saddles before I got to that one and it felt better almost immediately. I have had it for 2 months now and love it.
Of course that eed to try out a has NOTHING with whether it will work for you. You will need to try out a few sadles for yourself and see what you discover. I have yet to ride a bike where the stock saddle did not have to be changed.
“A good teacher protects his pupils from his own influence. ”
― Bruce Lee
― Bruce Lee
Time for a change.
Liked 5 Times
Not one particular make but The type that springs to mind is the Flight Titanium. I first got onto these about 15 years ago and tried a couple of Flights and nothing special. Then I got the Ti version and what a difference. It is only the rails but comfort in a big way (FOR ME). Prostate problems and I tried all sorts of saddles and it was only when I went road that it was eased somewhat. The thin OM saddle on the Giant OCR was not that good but better than any saddle on the MTB's. Next bike had a Fizic and that was good but only for 6 months. looked around and I needed a thin saddle- like the Flight- have a cutaway which the Flight Ti did not have and I would prefer just a bit of padding. Flight Max gel seemed to fit the bill and it does. Very similar if not identical shape to the Ti and used it on one bike ever since. The other bike has a San Marco Aero fitted and same shape- same cutout and the padding is hard foam. The two ride identical. The Uno has an OM saddle fitted that I was certain was going to be changed but is settling down gradually. Same shape as the other two but instead of a cutout there is a shallow depression.
Last week I found my original Flight Ti so may give it a try again. Reason it came off the bikes was due to the prostate and MTB upright sitting stance. Might work well on the road bike now.
Spike Milligan
Spike Milligan
Council of the Elders
Bikes: 1990 Schwinn Crosscut, 5 Lemonds
NOS88 pretty much has it covered but fwiw here's a few saddles that are very popular:
Specialised Avatar
Fizik Aliante
Brooks B-17 or 17n
Others may have additions to offer.
Specialised Avatar
Fizik Aliante
Brooks B-17 or 17n
I have A couple bikes with Fizik Vitesse saddles..
2 0f them came thru the Palo Alto Brompton dealer..
was a special order batch made with a different rails bend
for that companies superlight folders..
QBP has Vitesse in the light weight metal rail, bend version now,
my 1st vitesse was the standard rail, I had to get a different seat post
with a low profile clamp, so I got a Race Face seat post, next..
now that saddle migrated to the top of the Thud-buster LT on my Bike friday.
I was OK with Brooks pro's for decades, took a few long Cyclo-camping tours on them
but I don't worry about the leatherless saddles, getting soaked.
leather covered San Marco Rolls and Selle Italia Turbos are OK, too.
racy bikes stay on the peg for the most part. no mudguards.
His Brain is Gone!
Bikes: RANS Stratus, Bridgestone CB-1, Trek 7600, Sun EZ-Rider AX, Fuji Absolute 1.0, Cayne Rambler 3
I walked past a bike rack today with 7 road bikes in it, 4 of them had Brooks saddles.
"Too often I would hear men boast of the miles covered that day, rarely of what they had seen." Louis L'Amour
There are two types of road bikers: bikers who are faster than me, and me. Bruce Cameron - Denver Post
Bikes: Trek 1.5, Scwinn Sporterra comp, Cannondale Synapse carbon
I love my Ellipse Royalgel. I've never found a stock saddle to be comfortable but have never bothered to try to break them in either
Liked 6 Times
Sorry, Tom. I just can't resist this. Are you saying that 4 out of 7 bikes not being ridden have a Brooks on them?
Bikes: 2009 Rocky Mountain RC30 D
The never ending quest for the comfortable saddle ...
Like a lot of you folks, I've been riding bike for over 50 years.
Up front, --- this is entirely anecdotal.
I've ridden horses bareback, binders and tractors with steel seats, to rolls and everything in between.
I have yet to find a material that is better suited for me and my butt on a bicycle than leather.
Had a Specialized Avatar Comp Gel 155mm for a year, just switched to an Avatar Expert 155mm. The gel is now on my back up bike. Like the Expert better than the gel, even though both are really comfortable to me. The foam gives me better support on long rides, the gel is fine to 30 miles or so.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
I must be an exception to the rule on saddles. Both of my road bikes still have the OEM saddles on them and between the two I have over 5,500 miles on them. No real problems with either of them.
With that out of the way, one saddle that I am seeing on a lot of road bikes is the ISM Adamo. I am still thinking of getting one after hearing all the praises from the owners. Several riders in my club have them and say it's the last saddle they will ever use. I still haven't tried one yet, but I intend to look into them soon. The only thing I see as a drawback is the price; the Road and Prolog models are both $170.00 with their cheapest model being $130.00 (MSRP).
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Semper Fi
Quoted: 1173 Post(s)
Liked 358 Times
My experience is with Brooks Pros and B-17 until my N+1 this year (Prologo Kappa on it) and it is back to 1978. They break-in nicely and fit you like a glove. My wife loved her B-17 and my son is riding my old one on the R500 I gave him.. When the stock seat on my CAAD 10 is shot, in a few years probably, I'll get another Brooks Professional. Just like them alot.
Bill
Bill
Semper Fi, USMC, 1975-1977
Bikes: 2011 Trek SOHO Deluxe, and 2010 Specialized Roubaix Expert
Quoted: 7 Post(s)
I have replaced 2 Specialized Avatar saddles that came with new bicycle purchases. The issue may have been their width. I preferred the Specialized Toupe Expert and a Selle Italia SLR Fibra. The only complaint with the Fibra was the leather cover. I now have a Selle Italia SLR Monolink Flow. It is so awesome!! It has a Lorica cover and a very narrow nose that noticeably reduced friction vs the Fibra.
Go to this site : https://www.wekeepyoucycling.com/en/p...ring-tool.aspx
Order the measuring tool. Measure your sit bones. Buy a saddle that's the appropriate width for your bottom. That's how to start. And the size of your butt has little to do with the width of your sit bones.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 7 Times
That said, I lean towards Brooks simply because they are old school still works design & materials.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
