Conversion: 27" to 700c and Canti to Mini V
Quoted: 40 Post(s)
I have a 1988 Trek 520 that is an awesome bike, but recently it has been raining a fair bit and the brakes are downright useless in the rain (I have fairly new Koolstop Dual Compound pads). I have long been considering a swap to mini-v brakes, but have recently wondered if I should go ahead and swap to 700c wheels too. It is my understanding that the old steel rims also contribute to the poor rain performance of the brakes. Furthermore, I will be moving from the Bay Area to Denver soon, and wonder if switching to 700c would allow me to put slightly wider knobby tires on for the winter. Any thoughts or advice you have would be excellent!
Quoted: 1361 Post(s)
Liked 424 Times
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
Sugar "Kane" Kowalczyk
Swapped three bikes, two being mid '80's Treks, from 27 to 700c (and one of them back to 27 when a tasty set of wheels came along) without much in the way of trouble.
Also, are you sure you have steel wheels? That would be unusual unless someone swapped them on in the past. And as said above, ditch 'em for a set of alloys and ride it. Then if you still think the brake performance is poor, look at other brakes. Blaming the brakes for poor performance while using inferior rims is pointless.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Commence to jigglin’ huh?!?!
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Do you have a picture of the wheels/brakes set up on the bike right now? That would help us determine if the wheels are indeed steel (some deranged person must have installed them prior to your ownership), if your brakes are set up as ideally as possible, and what kind of clearances we're working with. I have thought about and tried the canti-to-V brake conversion on a few touring bikes, and it comes down to whether or not the canti posts are wide enough apart (80-85mm ideally) and low enough (short distance from them to the dropouts) to facilitate brake type flexibility.
I'm currently yelling happily from the rooftops about Tektro CR720 canti brakes on my 1990 touring Cannondale. Canti posts are 80-83mm apart, and measure 290mm from the dropout/wheel axle to the center of the post front and rear. The 720s just fit, but V-brakes certainly do. What was nice about the 720s is that they look great, are immensely strong, and with Kool Stops, stop with as much authority (in wet or dry) as the best dual pivot side pull calipers that I've ridden (on my other bikes). Oh, and they DON"T SQUEAL! Seattle is very hilly, so if it passes the test here, it'll pass anywhere else.
Your canti brakes should easily accommodate going from 27" to 700C. The stiffer rim construction (most 27" wheels are "single wall" vs. "dual wall" for 700C/newer wheels) will help, and if you can find 700C rims that have machined brake tracks (small grooves), that helps brakes bite even better.
As per usual, proper setup, new/smooth and easy functioning cable action (good cables and housings), proper lever setup/positioning, and a good brake lever are a must to get good performance. A picture and report of that would also help us to get the whole picture of what's going on. You have a good bike, let's get it going properly.
Quoted: 1627 Post(s)
Liked 630 Times
Steel rims should never have been put on that bike; it came with perfectly good alloy ones. Like nesteel says, you can often swap in a pair of 700c rims without much trouble. Sometimes it means having to change the calipers; sometimes you just have to adjust the brake pads. On my Cannondale, I got away with it by using a slightly narrower rim than was on the bike before.
Unless you can find someone here who's done the swap to 700c on that particular year and model, you'll kind of have to fly blind on what calipers will work with the slightly smaller wheel set. But again, maybe the ones you have will be fine.
Once you've got that worked out, modern compound brake shoes are always an upgrade, but again, that won't be all that noticeable on wet steel rims.
The brake calipers are almost never the problem. OTOH, my V brakes always seem a little grabbier than cantis, so they might help out once you get some proper rims.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I don't know if the OP is still on board here, but changing to 700c will change the pad-dive angle considerably, and problematically so if the rims are on the narrow side.
What this means is that the pads will be occupying a vertically wider swath of the rim's side wall (or braking track). This is more of a problem with 1) rims having a narrow brake track and 2) rims that are much narrower than the tire (making the pad's more-vertical travel path possibly cut into the tire sidewall as the pads retract).
I've found even the Trek touring bikes to have very little clearance for fenders or even a tall tire, so 700c gives 4mm of additional vertical clearance vs. 27" assuming the tire cross-section is kept the same.
I've put quality Araya and UKAI steel rims on bikes that came with alloy rims, not a problem if it is for dry-season riding and using correct brake pads.
The OP needs alloy rims though.
Quoted: 40 Post(s)
After the consensus of the responses, I double checked and, indeed, I was mistaken. The rims are alloy and appear to be the stock rims. I don’t know how I got it into my mind that they were steel, but I apologize for the misinformation. Nevertheless, the fact remains that my brakes work very poorly in the rain. Would tektro 720 or mini v (tektro 926al) offer more power? I find it very hard to get my current Cantis dialed in. I can post pictures tomorrow of helpful.
Liked 1,296 Times
Make sure that the pads are contacting the rim squarely such that after initial contact, the pad does not tilt as lever force is increased.
The lever shouldn't feel spongy after the pads contact the rim.
Bianchi Goddess
Liked 2,928 Times
It would't hurt to take a little sand paper or emeryboard to scuff the pads and even some steel wool on the rims then rubbing alcohol on the rims to clean all the dirt and grit off.
I would certainly consider switching to alloy wheels for better stopping and better overall ride quality. However switching to 700c wheels may not be practical. You might get lucky and find some brake that works but I believe in general swapping 27" to 700c wheels on a bike with cantilever brakes isn't always practical.
Going to 700c wheels will allow for fatter tires and/or studs or knobs which wil help with snow. However, usually the snow in Denver is gone fairly quickly so what I have are multiple wheels one pair of which have studs and one pair without. On those days when the roads are icy studs are very nice but a lot of drag when on dry pavement. In warmermonths you might have some gravel grinders and some road slicks as your set. One of the things I love about older bikes is their ability to run larger tires.
Death fork? Naaaah!!
Just a note: after 12 years of fighting with the mini-Vs on my Miyata Triplecross I'm switching back to cantis.
Top
Top
Bikes: bunch of junk
Quoted: 22 Post(s)
I converted my Raleigh Aleyska to 700c to fit 38's with fenders and the stock canti's worked. Luckily they did since the pivot spring is on the wrong side - you'd either have to make an adapter (I've thought of doing this) or buy Paul brakes in order to upgrade. There's no hills here so marginal brakes are totally acceptable.
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
