Modern Canti's for a vintage touring bike - suggestions?
Quoted: 796 Post(s)
Liked 522 Times
In my experience vintage touring bikes i.e a mid 80s Nishiki Cresta GT or Schwinn Passage, have front canti posts that are spaced in the 75 to 80mm range and are therefore much narrower spacing than on more modern bikes. I tried Tektro 720s on my 86 Schwinn Passage a few years ago and discovered this issue, they were fine in back but would not work up front so I remounted the stock Dia-Compes.
Having just finished setting up the stock Dia-Compe 962 brakes on my Nishiki I got to wondering if there was something a bit more modern and easier to set up/adjust that would work with the narrow canti studs? I have seen Planet X Frogs as an option (thanks @thethinman) but those show up on amazon as "no longer available" and I don't see them elsewhere. So my question has anyone had success with a more modern set of canti's -Tektro,Cane Creek, Avid etc on a vintage tourer and if so which model?
I can live with the Dia-Compes and the tedious set up but am curious if there is another way.
Thanks
looks great without an actual wheel
Thanks
Thanks
Thanks
The Tektro 720 are nice brakes. I have them on my Riv, but yeah, not friendly to vintage post spacing.
Likes For Salamandrine:
Quoted: 796 Post(s)
Liked 522 Times
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Why they put those posts so close together I'll never know. I had someone send me some NOS MAFAC studs they wanted brazed onto their frame, I talked them out of it, as the miter and position of the stud would make it difficult to get a wheel with anything other than a 25mm wide tire on it pumped up. One of the advantages of centerpull posts is you can put them on forks with fairly narrow fork crowns and still have them swing open enough to get a fat tire through.
Those Tektros are inexpensive, easy to set up, and have all the adjustability one would want. Unfortunately they don't play well with vintage forks.
