Repair Broken SS Bottle Cage?
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
I have a King Cage SS bottle cage that broke near the bracket recently. It's 10 years old, so I am not upset that it failed as everything can break over time.
However, I really hate throwing out things that can possibly be repaired, so I was considering trying to fix this. The tubular steel is VERY thin walled, so I am pretty sure regular epoxy will not work. I don't weld, so that's out. My idea is to put a nail or some other short metal object that is similar in size to the ID of the steel tubing into each end of the break (to stabilize it), and finish the job with some epoxy. I am hopeful this would work, although might be more of a "bodge" than a "hack."
Any suggestions? Plan B is to cough up $25-30 for a new one.
Liked 8,928 Times
Quoted: 6196 Post(s)
Liked 4,811 Times
When you get beyond attempts to save it, remember that throwing it in the trash will just result in it sitting in a land fill for many years. A scrap yard or recycling bin that accepts miscellaneous metal objects will be a better choice.
Metal generally recycles very well.
Quoted: 3241 Post(s)
Liked 2,512 Times
Universal Cycles in Lancaster, PA has 22 of them listed on their website for $20ea. Get a new one and recycle the broken one.
https://www.universalcycles.com/visit_us.php?store=PA
Likes For seypat:
Likes For Litespud:
Liked 8,928 Times
Yeah, I don’t solder so metal bar (nail?) plus epoxy is the idea.
Likes For datlas:
Blackburn also has a stainless cage called Chicane and are what I use. Have yet to have one fail and they are about half the price of a King Cage. Necessity is the mother of invention, my friend. Try your idea and see what happens. The epoxy I use for structural repairs like this is JB Weld. Do the repair off the bike and use loss of epoxy and rough up the nail so the glue gets a good grip.
Quoted: 1109 Post(s)
Liked 1,200 Times
Quoted: 790 Post(s)
Liked 348 Times
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2586 Post(s)
Liked 5,648 Times
If the JB doesn’t work prepare to start coughing. I bought a cage for $8. They are out there with no coughing required.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,473 Times
Amazon.com : Zefal Pulse L2 Bottle Cage, Black : Sports & Outdoors
Liked 2,512 Times
That is crazy talk when you can buy a 19 g CF cage for < $22.
Likes For seypat:
Liked 1,473 Times
Liked 2,512 Times
Maybe the bike has Chris King hubs/headset and he wants something that matches..........kind of.
You shouldn't put CF on there anyway. That's like a ticking time bomb.
Likes For seypat:
Liked 2,512 Times
JB Weld will cost between $5 and $10. Don't know about the metal rod. A cost analysis might be needed. Recycle the old cage plus some other metal scraps laying around and you have enough coin for a new cage.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I use gel super glue for all kinds of jobs - amazing stuff, and you can buy it at Dollar Tree for $1.25 for 2 or 3 tubes. With a close fitting nail the repair will last forever.
Likes For sced:
Quoted: 601 Post(s)
Liked 781 Times
Quoted: 8287 Post(s)
Liked 9,062 Times
I don't think you can solder to stainless steel. A skilled welder can fix it but it won't be cheap. If it fatigued enough to fail at one point it's probably fatigued enough to fail someplace else.
JB weld is amazing stuff and might be the solution you seek.
Quoted: 20810 Post(s)
Liked 9,456 Times
Has anyone called the OP a cheap-ass, yet?
Liked 2,512 Times
Likes For seypat:
Liked 9,456 Times
Likes For WhyFi:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I'm with you on the second point you made, fatigue probably killed this cage, and it's likely developing cracks on the other side of the cage as well. IMO, that makes it a situation of throwing good money after a lost cause. BUY a new one, take this one to get scrapped.
Quoted: 4806 Post(s)
Liked 3,932 Times
You can solder Stainless if you use a strong acid flux. I'm going to be using the stuff on a stainless kettle as soon as I get the flux delivered. Stainless is a pain to weld because it needs an inert gas, right?
That would work very well. Take very little epoxy. If I were doing this, I'd first see how far I could stretch the tube away from the break. (Say 0.5 cm.) I'd then epoxy in my plug, oak, nail, rod; whatever I had, into the mount-side tube so it stuck out 0.4 cm. Let the epoxy set. Now gubber up the protruding end, slip the tube over, pull it tight against the joint, clean up joint and let it set.
And last, if it came out neatly, I'd send a letter/email and photo to King. They'd enjoy it. (The WB King, not Chris King! They are a small crew and love making a good product.)
Quoted: 643 Post(s)
Liked 1,526 Times
I would put a small piece of metal rod in there and JB weld but if you have a small local welding shop or metal fabricator, I see no harm in asking them what it would cost to repair. Something like this can probably be done in a minute or two and they might just ask you to slip them a few bucks on the side.
