good hub bearings
good hub bearings
My front (Roval CLX32) bearings are a bit gritty and you can feel they rotate quite slow (in hand).
I want to change them, and... question, to what?
(ceramic bearings for 50-100eur/pcs are out of question )
In my FS frames I used Enduro (max) always, but after reading that many ppl consider them just (above) average? I'll think more...
- Some ppl say that Enduro bearings are 'just average', (Enduro Abec 5 61802 LLB -13.5eur)
- so maybe SKF (SKF 61802-2RS1 26eur)
- NTN then (~16eur for 6(1)802)?
- Have you heard about Cema ceramic bearings? (these are for about 22eur)
- DT Swiss 6802 ESB/ESNB L - ~10-15eur (I don't know who makes them)
- ISB ?
Quoted: 5792 Post(s)
Liked 2,581 Times
Just about ANY commercial grade sealed bearing is more than adequate for your needs. Though they aren't as common, single sealed bearings have a (very) slight benefit of lower seal drag, and you don't need an inner seal anyway. But that's not to fret over either way. Commercial bearings are typically rated for 10,000+ hours of continuous duty in 3,600rpm electric motors, and are more than adequate to your needs. If you have concerns over rumors of poor quality for Enduro, consider skf or Fafnir, or any others.
In any case, I don't believe it's possible to wear out any of these on a bike UNLESS they're compromised by dirt or water. So seal quality and condition, and riding conditions become the major factors in service life.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
somehow... all bearings on bikes fail, in suspension sometimes even just after few months (if you live in wet place), and seals (LLU - full contant) are not able to stop all the moisture.
However, these are for my road bike and currently I live in a dry area (it rains once per 1-2 months I can ride my MTB at that time )
ok, too much thinking, I'll just get the once it's easiest to get (just not enduro this time)
Liked 2,581 Times
This is why exposed "sealed" bearings don't hold up on bikes, especially mtn bikes. IME-they actually do a better job keeping water in than out.
So, do the best you can, and expect a sub-optimal service life.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
I know that, it was just an answer to your statement "I don't believe it's possible to wear out any of these on a bike...."
yep, I ride my bikes only outside, I don't use home rollers.
still one question:
still one question:
Quoted: 6196 Post(s)
Liked 4,810 Times
Are you sure they are worn out. Or do they just have grit and sand in them.
Quoted: 194 Post(s)
Liked 204 Times
The problem is that when you get grit or sand in the bearings then removing those particles becomes problematic, whether or not they have caused any appreciable wear. The cages are quite good at catching the grit or sand, but then removing anything caught there is difficult, and once you can hear it it in there, then there is too much for the cages to carry.
Any reasonably name brand bearing will be fine, but probably the best are bearing brands like NTN, SKF, NSK, ***, etc, many of which are manufactured in Japan. Ceramic mostly does not outperform high end steel bearings in this application except for extremely minor weight differences. DT bearings are pretty nice, I think the better ones are
Enduro makes/resells a LOT of products. They have such a presence in the bike industry both because they market to the bike industry and because they do design a number of products/bearings uniquely to the bike industry. Enduro MAX bearings for example are uniquely designed for suspension pivots, for example. For hub bearings probably the above recommendations are better, though in practice Enduro's bearings work perfectly well, especially their better stainless bearings.
If you ride in wet/gritty conditions decent, inexpensive bearings and replacing them more frequently will net you better performance than high end bearings run until they begin failing, though it's obviously annoying to have to do with excessive regularity.
Likes For cpach:
Quoted: 2604 Post(s)
Liked 1,933 Times
Is "***" a similarly named bearing company?
Likes For pdlamb:
interesingly, after removal those bearings didn't have gritty effect, they were smooth,
New mounted without a hassle.
Liked 2,581 Times
Bike people are constantly reminded about preload, which is fitting for classic cup/cone bearings. However the cartridge bearings typically used cannot tolerate any preload. They are usually deep groove radial bearings with correct preload built in. Axial preload f forces the balls against the sides of the races causing destructive wear.
If the hubs have any adjustability, via shims or otherwise, take up excess play, leaving a trace, but do not preload.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 839 Post(s)
Liked 1,062 Times
Likes For Crankycrank:
Liked 2,581 Times
Don't you love the auto-censor?
Think about the plight of folks who sell wood kindling.
Likes For FBinNY:
I've been thinking I might want to open a restaurant named, "I Don't Know." Figure that half the time someone's going out to eat, they start by asking someone else, "Where do you want to go?" followed by "I don't know." I'll make a killing.
With regard to "dust" versus "water" seals, I was not a bearing engineer, but my application used a "double-lip" seal, the inner lip kept in the grease, the outer lip kept out dust, and they both combined to keep out water.
Back in the day, for roller bearings, I bought Timken, but I don't think they made ball bearings, so for that it was New Departure Hyatt I think. "Doesn't anyone buy American anymore?" - Martin Blank, Grosse Point Blank
Likes For sweeks:
Quoted: 4210 Post(s)
Liked 3,875 Times
This different preload and resulting feel is exactly the same with loose ball cup and cone angular contact bearings that most moderate and lower cost bike use these days (and were the standard across all price points only a couple decades ago). One can adjust the cup and cone bearings to freely spin even when well worn. It just takes reducing that preload enough. This is not the best way to service a cup and cone bearing but a method I (and many other mechanics) have done on so many poorly assembled and maintained bikes during tune ups. One aspect of servicing that a pro has a better understanding of is the "good enough" point and trading off cost of service against perceived benefits. Andy
AndrewRStewart
AndrewRStewart
Really Old Senior Member
Likes For Bill Kapaun:
Liked 2,581 Times
Separated they would translate to:
Cast steel ball manufacturer.
But Germans like to combine multiple words when describing a single thing, like the way we say railroad, instead of rail road in english. For example while we say train station, Germans would say trainstation. (bahnhof), and maintrainstation.
It has 3 sss because its actually 4 words. So you have the last 2 from guss and the first one from stahl.
(When commenting about inferior USA primary school education, versus Germany and Japan) "They think that with a fax, the paper is sent through the telephone lines. Idiots! Only the INK goes through the wires!" - Dave Barry
Likes For Duragrouch:
Quoted: 506 Post(s)
Liked 639 Times
While your statement is basically true, the time to failure can vary widely depending on bearing seal design, bearing quality, and maintenance. I'm used to not having to replace bearings over many tens of thousands of miles. But then I ride Campagnolo exclusively. YMMV
