Q-factor - pedal strike calculator ?
I remember coming across an Excel form online where you filled certain measurements of your bike (BB height, Q-factor, pedal width) and it told you the angle of lean in which pedal strike happens.
Anybody have it bookmarked?
Quoted: 4209 Post(s)
Liked 3,875 Times
Back in the day we just leaned over the bike and watched for when the pedal touched the ground, then we "measured" the angle between the seat tube and the road. Andy (who has sharpened his Campy pedal quills with the road a few times)
AndrewRStewart
AndrewRStewart
Quoted: 5791 Post(s)
Liked 2,581 Times
I vaguely remember seeing something like that, but can't help you.
However, unless you're riding fixed wheel none of it matters.
Pedal strikes are easily avoided by good ingrained habits. Imposing limitations on bike design is unnecessary, and may cause other issues not justified by any actual benefit.
FB
Chain-L site
FB
Chain-L site
Quoted: 4409 Post(s)
Liked 1,563 Times
What would one do with this information? Use it for selecting bikes? Install an artificial horizon on the handlebars?
I doubt there is much variation between current road racing bikes.
Likes For Kontact:
Quoted: 4806 Post(s)
Liked 3,932 Times
I call Peugeots and my Raleigh Competition "Slinkies" because the BBs are so low I hit pedals on a regular basis. Good thing is the lean angles are so low it isn't a big deal. But pedals that aren't rugged need not apply for work on those bikes. (I have a box of dead Leotard Berthet pedals - loose at the press-fits and missing all the dustcaps because the left ones want to unscrew every pedal strike. I don't know if pedal strike added to the press-fit loosening. It certainly did not help. Just saw that those pedals can be had on Ebay for $273. A higher BB and I could be wealthy.)
My idea is that this info would be useful for choosing cranks and pedals and if considering going down in wheel/tire size
EDIT: Found it! Right where I should have checked first, Sheldon Brown's site https://sheldonbrown.com/bbdrop.html
Likes For Krov9:
Liked 3,932 Times
Aren't race bikes still tailored toward US criteriums (10-3/4"+ BBs) and European mountain races (closer to 10-1/2")? That 1/4" makes a big difference on pedal strike.
Quoted: 2495 Post(s)
Liked 739 Times
Q factor has got to be the least significant of the variables affecting lean limits. Surely crank length, bottom bracket height, even pedal platform width ... all of those probably 'can' have dimensional variables significant enough to affect lean angle. Cranks can be anything from 175mm (180mm) down to 140mm (130?). Could Q factor possibly have that kind of variability? Never mind, just opened the o.p. link in another window. A bottom bracket height calculator is a VERY different thing from a Q-factor calculator which even an outlier geek like SB knew wasn't worth getting hot and bothered about.
Likes For Leisesturm:
Liked 3,932 Times
B Height, 1/2" (12.5 mm) change - 3.6 degrees or 3.5 mm change causes 1 degree of lean
Q-factor, 30 mm change - 2.2 degrees or 17 mm change causes 1 degree of lean
Crank arm length, 20 mm change - 3.8 degrees or 3.5 mm change causes 1 degree of lean
Pedals can make a much bigger impact.
I drew this around a 10-3/4" BB height varying:
B Height, 11" to 10-1/2"
Q-factor, 135 to 175 mm
Crank arm length, 180 to 160 mm
Pedal used was a Shimano Dura Ace semi-platform that measured 3-1/2" width along the spindle centerline and is so cutaway that I assumed there would be no hit first from a bottom corner. (The pedals are designed for racing on the velodrome where pedal strikes are crashes,)
Liked 739 Times
I just sketched out a typical road bike. Angular effects of changing BB height, Q-factor and crank length are:
Liked 1,563 Times
None of these things has extremes. Today's bikes and cranks are more alike than different. You can't even use a modern derailleur with a Nuovo Record era crank because the arm is too close to the outer chainring.
Current aftermarket cranks are poor matches to Shimano and Campy front shifting, even if you can find a usefully narrower one.
So I don't see what anyone hopes to get out of this aside from being nostalgic to the days of narrow cranks and actual crit geometry.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
It's like riding a bicycle
Likes For 13ollocks:
For context, I'm converting a French tourer (notorious for low BB's) from 700C to 650B and planning to use these. Cranks are narrow Q though.
Likes For Krov9:
Quoted: 980 Post(s)
Liked 582 Times
You can always do what the motorcycle racers do: lean slightly to the inside of the curve, causing the bike to be more upright. No need to drag yur knee though!
Likes For sweeks:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Crit racers do that as well.
Likes For urbanknight:
Liked 3,932 Times
You can even do this quite a bit. I rode my Peugeot UO-8 for years fixed and got really good at the "lean away". Drawback was real understeer. The lean away was basically telling the bike to go straight and you had to physically make it turn with your hands. But it sure beat hitting the pedals and rapidly destroying them.
Likes For 79pmooney:
Liked 3,932 Times
Quoted: 2483 Post(s)
Liked 2,955 Times
Pedal strike is only a consideration if you need to pedal through corners at high speeds. Only bike racers need to pedal through corners. Everyone else can coast.
Assuming your "old French tourer" is not going to be used for racing, which seems a fair assumption, maybe just consider coasting through corners.
Liked 739 Times
Don't know if the o.p. is having us on or not with the plan to use Juvenile Market pedals, but, usually, a change to 650B also involves enough of an increase in the new tire's radius that bottom bracket height remains more or less the same as before. Otherwise, why bother??
