Bar End Shifter Improvisation?
Quoted: 7 Post(s)
Hey all. So some may know that I'm building up an older Nishiki, and everything is coming together. I'm super excited; however, the recipient of the bike is attempting to be enthusiastic but it's hard when he won't be able to ride it for months.
Anyway, the guy I'm building it up for is a tall dude and he didn't like the idea of the lengthy reach down to the DT for shifting, so I decided barcons would be the way to go. Long story short, I'm having pretty much zero luck finding some decently-priced Shimano 7speed bar ends, and I'm wondering what my options are really. Would it be cheaper to get something like the Rivendell adapters and then use indexed DT shifters?
Lay it on me, C&Vers!
Quoted: 1612 Post(s)
Liked 2,594 Times
check these out from Rivendale https://www.rivbike.com/products/show...-mounts/17-068
Quoted: 7 Post(s)
Hm. Those look good, but they're rivaling the cost of some 8speed shifters that I found. Can I make an 8speed shifter work with a 7speed cassette?
Bikes: bunch of junk
Quoted: 22 Post(s)
I've used parts bin friction thumb shifters clamped on the drop for one of my parts bikes in the past. They also can be mounted next to the stem if you can get the shifters to fit. Its completely ugly but it works.
French threaded
Bikes: many
I assume you want sis only then?
Friction setup would be no problem.
I'm trying out some suntour "mighty shifter"s and I bet you could fit them with indexed shifters without too much hassle.
This might work
https://www.chainreactioncycles.com/M...?ModelID=42336
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Quoted: 443 Post(s)
Liked 27 Times
Shimano originally sold their 8 speed bar end shifters as 7/8 speed. Get the Ultegra shifters. They're easy to find. I've been using them for years on a 7 speed. It has never missed a shift.
Bar End Shifters
Shimano Ultegra 8 Speed Bar-end Shifters LD801 $84.95
These permit switching between indexed and friction shifting.
Complete with cables, housing and down-tube cable stops for attachment to down-tube braze-ons. If your bike doesn't have the braze-ons, you also need to buy a pair of clamp-on cable stops.
The 7-speed units are no longer available, but the 8-speed shifters actually work quite well with 7-speed cassettes, especially with modern rear derailers.
Bar End Shifters
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 104 Times
Try to track down early GripShifters, originally designed for triathlon aero bars. These work well on the bottom of drops. The later models pictured by Norwood have a shorter ´throw´and are a bit trickier to turn with the bottom of the hand, IYKWIM. All in my experience, of course.
GO BIG RED
Bikes: 1996 Bianchi Veloce 1993 Bridgestone MB-3 1992 Trek 700 1992 Trek 820
Bikes: Cannondale T700s and a few others
I'm thinking about these for one of my bikes.
https://www.kellybike.com/2nd_xtra_takeoff.html
