FSA Gossamer Cross MEGAEXO- removing crank
Old 09-20-14, 05:38 PM
matimeo
matimeo's Avatar
Bikes: It's the motor, not the bike, right?
Quoted: 39 Post(s)
Liked 16 Times in 13 Posts
So I've got an older cross bike with a FSA Gossamer crank, but I don't understand the removal process on my new bike, and the manual was useless. Likewise a search of the internet is coming up short, so I defer to the experts at BF (is this just a new model?).
My older crank just has a hex bolt fitting that removes the non-drive side crank arm. This one has the "M17" bolt inside of what the instructions (linked here) seem to be calling the "QR-17 self-extracting bolt", which supposedly comes pre-installed. Since I got the bike all assembled, I can't figure out how to get this off. I tried loosening it with a hex key and it started to loosen but then felt tight after a turn or so. It gets tight turning it clockwise as well. Scratching my head here.
edit: Just found this: https://www.parktool.com/blog/repair-...elease-systems
So do I need to take the self-extracting bolt off in order to remove the crank bolt? It would seem that way from my experience of loosening and not being able to get it off. Now I have to buy another tool if that's the case.
File Type: jpg
matimeo is offline
Old 09-20-14, 05:45 PM
bikeman715
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
Quoted: 85 Post(s)
The bolt will get tight just before it pull the arm off the BB axle , this is normal . QR-17 self-extracting bolt is what it is . Maybe this will help , Park Tool Co. » ParkTool Blog » Self Extracting or One-Key Release Systems
bikeman715 is offline
Old 09-20-14, 05:50 PM
matimeo
matimeo's Avatar
Quoted: 39 Post(s)
Ha, you beat me to it. Doesn't it look like from the picture on the Park site, that you have to remove the QR-17 self-extracting bolt, before you can completely remove the M17 bolt to remove the crank? Or does self-extracting mean that it gets hard because that's the resistance pushing against the bolt to get the crank to extract itself? Ah, I think I'm starting to see what's going on here.
matimeo is offline
Old 09-20-14, 05:55 PM
bikeman715
bikeman715's Avatar
Quoted: 85 Post(s)
does self-extracting mean that it gets hard because that's the resistance pushing against the bolt to get the crank to extract itself? yes this is what I mean .
Old 09-20-14, 06:59 PM
GeneO
GeneO's Avatar
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times in 105 Posts
yes
GeneO is offline
Old 09-22-14, 09:35 PM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
Main problem with the crank is the need for someone else to hold the crank on the other side when you finally torque it to spec on reassembly. It is very difficult to do by yourself to the specified
torque.
sch is offline
Cool_Man
Bicycle Mechanics
20
04-18-21 10:17 AM
JimboMartin
Bicycle Mechanics
36
02-06-16 05:32 PM
sproyd
Bicycle Mechanics
11
01-31-12 06:37 PM
ridethatbike
Bicycle Mechanics
4
07-28-11 08:59 AM
Dylansbob
Bicycle Mechanics
17
10-06-10 02:09 PM
