Which tire to these wheels ?
Bikes: Cyco Alu-City-Bike, Custom alu 700c (Campagnolo Veloce groupset), vintage Benotto "Paris Special" (Campagnolo/Shimano), Nishiki 522 Cross
I'm confused about the terms of tire sizing during my hunt after the right tires for my new wheels (Campagnolo Khamsin) with these specs:
Which numbers should I pay attention to on the tires?
Quoted: 453 Post(s)
Liked 104 Times
The wheel is for a 700c tire, if you want comfort, and your frame can take it, a 28mm, if you want comfort & speed, 24/25/26mm (most frames should take upto 25mm with no issues), if you want speed 23mm, if you don't want comfort / like to look retro, go 19mm or less.
Quoted: 5772 Post(s)
Liked 2,563 Times
The critical number is 622 (mm) which refers to the diameter of the rim it fits. 18.5 (mm) is the tire's approximate width, and here you have some latitude but ate limited by frame and fork clearance. 18.5 is extremely narrow, so feel free to go wider if possible.
28" is the obsolete nominal size in inches and was the approximate diameter of the complete wheel including the tire.
FB
Chain-L site
FB
Chain-L site
Quoted: 86 Post(s)
they decided to put two notations, separated by a '/' on the tire, the first one is metric system based and is most useful. the other is Imperial (as in 'imperious') System based and is just about useless, unless you are designing a frame or trying to calculate gear-inches (you don't want to know ).
sometimes a Rosetta Stone is necessary to fully understand tire sizing.
Post #12
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
18.5mm is the rim width. Which as rims goes is quite narrow. Although all Campy rims still live in the stone age of narrow rims, I don't think they make any rims larger than 20.5 mm yet (externally measured, brake track to brake track).
Post #13
TBH though...you will not be able to measure any speed difference between a 28mm slick and a 23mm slick. And the 28mm will be far more comfortable, although as you state frame clearance is a bugger...since all frame companies seem to believe riders are all sub-70KG.
rim width: 15mm inside
Liked 406 Times
15mm measured what-to-what? I presume that is the inside-bead-to-inside-bead measurement, I have a pair of 2006 Zondas that have a 15mm internal bead measurement. Where'd you get the pic in the OP from? I've never seen a graphic like that, then again I've never gone hunting for one.
Did some looking, 20.5mm is the official nominal brake-track width for basically all their 2015 wheels.
Quoted: 4197 Post(s)
Liked 3,849 Times
I have never seen a tire so proudly marked with a "width" that was intended to be a rim width. Why would this be assumed to be a rim width when marked on a tire? Andy.
Likes For Andrew R Stewart:
Quoted: 86 Post(s)
it's marked with a 18.5 and has an x 622 too.
the rim must match the tire, so the markings could be referring to the tire's dimensions or a rim that the tire fits. i'd put my money on the inflated tire's dimensions. although incredibly narrow for a modern tire designed for anything but a track sprinter.
in any case, it's unlikely that the 18.5 and the 622 refer to two different objects though.
like i said previously, you need a Rosetta Stone, maybe a crystal ball too.
Post #14
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
700c x 23 should work nicely
incazzare.
I am running 700c x 27mm Challenge Parigi-Roubaix tires on that rim with no problems. The tires actually measure 29mm on the rim.
(FYI, 622mm, 700c, 28" and 29er are all the same diameter rim. Obnoxious, I know. Personally I don't know why we can't just use the metric designation in general.)
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Post #15
Thanks to all of you, especially Mr. lostarchitect.
I finally feel well suited for ordering some tires
Post #17
The final choice: 700x23c
Thanks for help !
Thanks for help !
Nice tire, with the reflective stripe.
I have the Bontrager H2's (28mm) with reflective stripe on my road bike. Pricey but nice.
Put Continental Touring with reflective stripes on my Specialized Sirrus (32mm)
Liked 3,849 Times
I wonder if a Schwalbe Marathon Plus (700X28C) tire would fit my Benotto "Paris Special" frame on this wheel ?
Likes For smashndash:
the Schwalbe Marathon Plus (700X28C) tire fits perfectly, even though it has cost a lot of elbow grease to put it in place ...
