Shimano GRX gravel group
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
https://www.cxmagazine.com/shimano-u...00-rx600-rx400
Particularly interesting, "interrupter" hydro brake levers:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Shimano now has 1x.
There you go.
-Tim-
There you go.
-Tim-
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
YEEEEEEEES!!!
Shimano FINALLY sells a 46/30 crankset!!
https://gravel.shimano.com/en/components/di2-speed/
(and for those who care, 1x as well)
BUT...with 12-speed about to be a thing any time now...this is again the World's Worst time to be releasing 11-speed parts. When gravel riding season is already under way and people have already bought kit for the year.
Likes For Marcus_Ti:
Quoted: 722 Post(s)
Liked 353 Times
Now it is Official no more cry babies in regards to Gravel. The very biggest of the big dogs has barked thus it must be true.
Anyone able to tell what they did here? is it just rebadged or a new way of doing things?
I love it.
I love it.
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4426 Post(s)
Liked 4,528 Times
Now another product I’m going to need I think I’m going to set up a go fund me page for bicycle component addicts.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
If I am reading their propaganda correctly, the new cranksets have a +2.5mm chainline that requires you to get the matching front derailleur (or maybe both, at least in the case of the Di2 version). They are also going to introduce in-line hydraulic brake levers later in the year.
The higher-end 48/31T crankset seems like an unusual gearing choice.
Liked 406 Times
I'm seeing 48/31 & 46/30 as the two 2x choices across all marketing material, including all the stuff that's been given out to bike shop employees. So we'll have to wait and see if it's a typo or just a 17 tooth difference choice.
Not a typo evidently: https://gravelcyclist.com/bicycle-te...CsARGqI2Ngizl8
“...RX810 series cranks offer Shimano’s widest-ever delta between small and large chainrings, a 17-tooth gap, that also debuts the company’s first ever 48-31T option. This, when paired with the available 11-34 cassette, offers an exceptionally low climbing gear while maintaining a 48-11 ratio that allows riders to take advantage of strong tailwinds and long descents..."
Liked 406 Times
A 17T FD is just to odd to not be a typo. They're always 16T.
48-17=31, so it's the max spread on the crankset that their FD can handle if you don't want to sacrifice top end speed. (I know "nobody uses it" except that a 105 cadence on 48x11 is 37mph, which is very attainable) I'd definitely lean toward that set if I had this group.
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
I was going to say this is completely unnecessary.
But the in-line hydraulic brake levers and changed pivot point for the brake levers are both pretty damned neat.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
It's been long enough since the CX50 and CX70 groups. Those had cantis!
The brake-dropper lever (bripper?) and the hydraulic interrupter are really clever. The chain line is for 135QR/142TA, which makes sense in context. I'm kind of surprised they didn't take this opportunity to do 1x12 and the new freehub like XTR, but I suppose that needs to percolate through DA first.
Speculations about performance aside, I really like the styling. Shimano does a great job. The crank is like a classier version of the old Race Face cranks.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times
One thing I'm not sure yet and cannot figure out anywhere. Will I be able to use the Shimano RD-RX812 rear derailleur with a 2x drivetrain. I'd love to have a 46-30 or 48-31 double crankset with an 11-42 cassete.
From reading shimano's not very intuitive website it seems like the RD-RX812 is for 1x applications with a 42t max cog and the RD-RX810 is for 2x applications with a 34t max cog.
Disco Infiltrator
Liked 2,105 Times
The 11-42 is the XT M8000 version which means we'll have 11-42 cassettes around for at least another generation. Whew! Was worried they'd be Eagle'd away. But also means a road hub will need a spacer, since the MTB stuff never went away from the 8-9-10 speed freehub width.
RD-RX810 Search in Compatibility
RD-RX812
RD-RX812
Genesis 49:16-17
Genesis 49:16-17
Likes For Skipjacks:
Quoted: 714 Post(s)
Liked 800 Times
SRAM has been doing this with their(mostly unknown) Wide Spacing road cranksets. They offer a "wide spacing" braze on adapter to space the front derailleur over 2.5mm. The problem is that the adapter is priced similarly to buying a new front derailleur.
Disco Infiltrator
Liked 2,105 Times
Who ever heard of a 31 tooth sprocket? Front or rear?
Genesis 49:16-17
Genesis 49:16-17
Quoted: 1975 Post(s)
Liked 232 Times
https://www.velonews.com/2019/05/new...vetrain_493384
Apparently the shift ramps line up better with a 31T, as for odd teeth chainrings SRAM did the same thing with their new cranksets
