Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Best sitbone measurement done at home
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 05-08-19, 08:19 PM
acorn54
Quoted: 31 Post(s)
while experimenting sizing my sit bones for a brooks on my bike, i came up with an idea that i'll pass along. the image one gets is remarkably similar to what i have seen
on the internet in x-ray images.:
light coat shaving foam on toilet seat cover
without undergarments on, of course sit on shaving foam.
the resultant image easily defines the sit bone structure for you to measure.
acorn54 is offline
Old 05-08-19, 09:53 PM
texbiker
texbiker's Avatar
Bikes: Cervelo Caledonia Rival AXS eTap, Blue Norcross AL, Lynskey Helix
Quoted: 112 Post(s)
Liked 103 Times in 81 Posts
Years ago I wrote this on my blog:
Saddles are a very personal fit item. If you are like me this is probably the bicyclist’s equivalent of the search for the Holy Grail. To me the important part is getting the seat cushion part to line up with my sit-bones. How do you do this? My thought is to take a piece of rather soft styrofoam about 3/4″ thick as a template to capture your sit-bone size, position and width. Here is how to do it:
* place the foam on a hard surface where you can sit as you would on your bike
* sit on the foam, being sure to make the sit-bones produce an impression into the foam
* now you can get fancy if you like, make a plaster-of-Paris casting of the impression
* take this casting or sheet of foam with you when inspecting saddles at your bike shop to compare your position versus the saddle positions.
texbiker is offline
Old 05-08-19, 10:32 PM
Bmach
Quoted: 440 Post(s)
Liked 264 Times in 162 Posts
You are making it to complex. Just go to a bike shop and have them measure it. When you decide on a correctly fitted saddle ride it for a couple of hundred miles let your butt get used to it. I think to many people do not give their body time to adjust the a saddle before changing it out for another. Then the body has to adjust to another saddle and the cycle starts all over again. Just 2 cents worth.
Bmach is offline
Old 05-09-19, 05:29 AM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1759 Post(s)
Liked 488 Times in 313 Posts
What do you do with the sit bone measurements when you have them? I have never measured my sit bones, but I have ridden a lot of different saddles and have not personally observed much correlation between saddle width and comfort.
kingston is offline
Old 05-09-19, 06:57 AM
USN
i just bought a foam cover at walmart and bought the riding shorts with the foam in them, Im good.
USN is offline
Old 05-09-19, 11:01 AM
Iride01
Iride01's Avatar
Quoted: 6178 Post(s)
Liked 4,795 Times in 3,307 Posts
Let us know how that works after a four hour ride. If you are only doing a 20 minute ride, I'm sure it's quite comfy.
Oh.... welcome to the forums. You gotta take the flak... It's forum life.
Iride01 is offline
Old 05-09-19, 11:18 AM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3885 Post(s)
Liked 1,938 Times in 1,383 Posts
I too have noticed little correlation between measurement and published saddle width. But for sure, don't get too narrow a saddle. I don't know the formula but it's probably something like add 40mm to measured width.
Results matter
Carbonfiberboy is offline
Old 05-09-19, 12:22 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
sheet of foam core and a wooden chair? lay down the foam core-paper piece and sit on it. ?
fietsbob is offline
Old 05-09-19, 09:36 PM
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times in 56 Posts
No, actually, not being mean, you are not good. Piling foam on foam is not going to be comfortable. Just the opposite.
I have sat on the newspaper in my Speedo (or sans Speedo as the case might be) and gotten my sit bone number. I purchased my Specialized (Avatar) saddles using that number and am very pleased with the results. I have a somewhat wider than average (for a male) sit bone width, fairly wide. No, I am not fat, 5-10+, 29 inch waist and 154 pounds. The point being for many perhaps it does not matter but for a person who is outside of the norm for their gender, it could make a big difference.
Loose Chain is offline
Old 05-10-19, 01:38 PM
Clem von Jones
Quoted: 151 Post(s)
Liked 23 Times in 16 Posts
Fill a large 1 or 2 gallon ziplock baggie with enough flour to make a thin flour mat after you evacuate all the air from the bag. Place it on a toilet lid and sit down slowly and carefully whilst bending forward into an aero posture. You should get two very distinct points where the bones jut out.
Clem von Jones is offline
Old 05-10-19, 03:58 PM
Iride01
Iride01's Avatar
Talking
Maybe someone should sell some casting kits tailor made for getting an impression of our butt. We could then take the mold and make an actual casting of our buts. Then we could take them with us to the LBS and see with our own eyes how we fit to a potential new purchase. <grin>
Not certain if I'm serious or jesting. Maybe both.
Iride01 is offline
Old 05-10-19, 05:57 PM
The_Joe
Quoted: 110 Post(s)
Liked 45 Times in 25 Posts
I've used aluminum foil and a semi-firm cushion (ottoman or wide couch arm) with good results. Checked against measurements from an actual site bone measuring device it all matched up.
The_Joe is offline
Old 05-15-19, 09:21 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
My mom always does the measuring for me.
trailangel is offline
Old 05-20-19, 12:55 PM
USN
Short rides only, maybe 2 to 10 miles with some rest stops, yep my bottom is ok,,,no long rides for us, mostly weekend warriors, simple stuff..
USN is offline
Old 07-03-19, 04:20 PM
berner
Quoted: 663 Post(s)
Liked 496 Times in 299 Posts
If your home printer has a copy function make the copy of your butt. Just don't post here. On the other hand, it you are kinky, think of the image as wall art.
berner is offline
Old 07-24-19, 09:03 PM
TXBDan
Bikes: Trek Fuel EX, Trek Checkpoint
Quoted: 41 Post(s)
Liked 18 Times in 15 Posts
I used this method but with the foil on a carpeted stair in my house. It worked amazingly well. I had no idea what my sit bones looked like...
TXBDan is offline
Likes For TXBDan:
Old 08-07-19, 02:23 PM
audiomagnate
Location: Omaha, the most bike unfriendly city in the Midwest!
Bikes: Cannondale Six 5, 89 Trek race bike
Quoted: 45 Post(s)
Liked 25 Times in 19 Posts
Me too, it worked great. You have to make sure you get a perfectly unrumpled piece of foil, you can't yank it off and tear it on the built in cutter. You have to carefully unroll it and cut it with scissors. I got 115 but my left is slightly aft of my right. Do you measure in a straight line between them if they're off axis or extend a line and measure the actual lateral difference, which is going to be a tad shorter.
audiomagnate is offline
bigbiker1
32
08-24-17 06:56 AM
etw
General Cycling Discussion
24
10-22-13 06:34 AM
Tall Cool One
Fitting Your Bike
5
07-04-13 03:39 PM
