Ballpark Costs of Midrange Shimano GXR Upgrade
Old 05-17-19, 05:46 PM
timacn
Quoted: 9 Post(s)
I'm getting ready to pull the trigger on either a Cannondale Topstone 105 or Sora. I am BY NO MEANS knowledgeable about relative merits of various components, so I rely on the expertise of people in this forum. (and I sincerely thank you for the advice!)
I've been wondering about the advisability of buying the Topstone Sora for $1050 and then upgrading to a midrange Shimano GXR group when the GXR stuff becomes available. (assuming I would even want/need it down the road). Or do I just go with the highly regarded 105 groupo now? I confess that I do like the green color on the Sora equipped model.
As always, thanks for your help and advice.
timacn is offline
Old 05-17-19, 05:47 PM
timacn
Quoted: 9 Post(s)
Whoops! I forgot to ask for the estimated "ballpark" costs of a midrange GXR upgrade for the Topstone Sora. Sorry.
timacn is offline
Old 05-17-19, 11:12 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
My guess - $900 for the full 105 level groupset with hydro brakes
Elvo is offline
Old 05-18-19, 02:17 AM
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
What do you want from GRX that you aren't getting with 105?
Canker is offline
Old 05-18-19, 09:01 AM
timacn
Quoted: 9 Post(s)
Good question, Canker. What would an upgrade from 105 to GRX get you? I'm assuming that Shimano did something different with the GRX to make it attractive.
timacn is offline
Old 05-18-19, 09:10 AM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
The primary difference is a crank (48/31T or 46/30T vs 50/34T). The brake pivot points are re-designed, and there are a few other tweaks. One of the rear derailleur options lets you use a bigger cassette.
If it were me, I would get the 105-equipped bike, and then only change the crankset and/or rear derailleur if necessary. (The chain-line will be +2.5mm, but I think the worst-case scenerio is that you might have to get a new front derailleur.) The Sora-level bike is likely to have other compromises. Also it is much easier to upgrade piecewise if you have 11-speed 105 to begin with.
Alternatively, wait (a year?) to get a bike already equipped with it. But keep in mind it will be more expensive because it is new.
Cyclist0108 is offline
Old 05-18-19, 05:03 PM
Canker
Quoted: 330 Post(s)
Same here but I'd add you can already get a 48/32 or 46/30 chanrings from Absolute Black for your 105 crank now if you need the easier gearing. They aren't cheap but if you need em you need em and you don't have to wait. There is also the Roadlink option to make your standard RD fit a bigger cassette. I'm running the Absolute Black chainrings myself but may switch out to a GXR crankset for the 48/31 option when my current rings wear out depending on how much the crankset costs.
Canker is offline
Old 05-18-19, 08:27 PM
Chi_Z
Chi_Z's Avatar
Bikes: Niner RLT 9 RDO
Quoted: 263 Post(s)
Liked 69 Times in 50 Posts
the pivot point is redesigned only in the di2 version. For mech, the brake lever shape is a little different and the hood rubber has more ridges that's about it
Chi_Z is offline
Old 05-18-19, 10:24 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,102 Times in 1,366 Posts
My plan is to wait till next year and see what the bikes are like that come with this group set. I expect they will be a little bit cooler. I’m hoping Salsa’s new model, the Warroad, will come with the 1X and a dropper.
And then since that will be too darn expensive, wait a little longer for a sale!
Buying a new bike with the intention of throwing all the drivetrain and brakes away in one season sounds CFCP to me
Darth Lefty is offline
Old 05-20-19, 03:33 PM
timacn
Quoted: 9 Post(s)
Good advice from all of you.
Not sure what CFCP means, so I looked it up. CFCP - California Farmland Conservancy Program?
timacn is offline
Old 05-20-19, 03:57 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
I dunno, but it doesn't sound good.
throw that $$$ into a good bike rather than upgrading before you buy it.
chas58 is offline
Old 05-20-19, 07:23 PM
jideta
Quoted: 94 Post(s)
Liked 139 Times in 74 Posts
105 FTW
Seems to me that GRX is trying to fill a void that's not there. I mean it's nice and all, but do we really need ANOTHER group?
Half the fun of putting a gravel bike together is frankenbiking the thing. I had Dura Ace, XT and 105 in the beginning. Still evolving (going Campy!).
I was guessing GRX would be in XT range plus a couple of hunski for the STI and hydros: $800?
jideta is offline
Old 05-20-19, 07:37 PM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
OP - the bigger question is do you want to run tubeless? Because the Sora Topstone doesn't come with tubeless ready wheels or tires, the 105 does.
2019 Salsa Warbird
shoota is offline
Old 05-20-19, 08:06 PM
softreset
Quoted: 129 Post(s)
Liked 54 Times in 25 Posts
I run an 11-36 SRAM cassette with my 105 GS RD with zero issues. I put a Praxis Alba crankset (48/32) on my bike and I've got a hair under 1500 miles on it with zero issues. Granted I don't do a lot of riding in the muck but a whole lot of dust/dirt.
I've been happy with 26 gear inches on the low end with a range of about 491%
Granted an 11-34 paired to a 46/30 would be a touch lower 25.9 vs. 26.1 and some tighter spacing towards the bottom of the cassette, there's no frankenstein-ing to achieve these results with 105 and zero additional accessories.
Not to mention the tech is available right now and from my experience 105 is durable, reliable and most importantly readily available.
softreset is offline
Old 05-21-19, 05:35 AM
MAGAIVER
MAGAIVER's Avatar
Bikes: Kona Unit, Kona Kahuna, Kona Dew DL, Scott Big Jon, Trek Checkpoint ALR4, KHS Urban Soul, Haro Team Issue, GT Force Expert Carbon, Bernardi Quadra.
Quoted: 31 Post(s)
Liked 48 Times in 25 Posts
Get the 105 version and if you feel like you need smaller chainrings you can either go for the GRX crankset and front derailleur or absoluteblack chainrings. The Sora build of the Topstone has more compromises then just the drivetrain. Not beeing to setup the wheels tubeless would be a deal braker to me.
MAGAIVER is offline
Old 07-17-19, 12:02 PM
SCTinkering
SCTinkering's Avatar
Bikes: 2020 T-Lab X-3 w/GRX Di2, 2018 Trek FX-5S with GRX/Xt 1x drive train
Quoted: 44 Post(s)
Liked 41 Times in 25 Posts
Yeah that bit of info kind of soured me to building out with GRX. I'm thinking GRX 1x crank, 105 hydro shifters (even though it's only a 1x up front) and sticking with the XT derailleur out back.
Tinkering is part of the fun...
SCTinkering is offline
Old 07-17-19, 12:42 PM
Koyote
Quoted: 6927 Post(s)
Liked 10,930 Times in 4,667 Posts
Get the nicer bike and start riding. If any of the components are lacking, replace them later.
Koyote is offline
Likes For Koyote:
Old 07-17-19, 04:27 PM
csrpenfab
Quoted: 76 Post(s)
Liked 99 Times in 57 Posts
Get the 105 and don't look back. I have the new 105 7000 series stuff on both my Giant SLR2 gravel bike and Trek FX6S flat bar road bike and it's great. Shifts just as well if not better than prior bikes I owned with Ultegra or XTR.
csrpenfab is offline
Likes For csrpenfab:
Old 07-17-19, 06:00 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
Did you pull it?
shelbyfv is online now
Old 07-17-19, 06:40 PM
BluFalconActual
Quoted: 144 Post(s)
Liked 55 Times in 33 Posts
I also was debating the same thing but my Giant Revolt came with 105 with a Praxis 48/32 crank and I can’t think of any reason why to switch to the GRX stuff since it has worked so brilliantly for me.
BluFalconActual is offline
Likes For BluFalconActual:
Old 07-17-19, 07:38 PM
simmonsgc
simmonsgc's Avatar
Quoted: 83 Post(s)
Liked 14 Times in 8 Posts
Coo-coo For Cocoa Puffs, I'm betting? I remember that commercial. No sugar in that breakfast cereal at all.
simmonsgc is offline
Old 07-17-19, 08:54 PM
itskohler
itskohler's Avatar
Quoted: 28 Post(s)
Liked 11 Times in 8 Posts
When I bought my Topstone I knew off the bat I wanted to 1x and loved the green that comes on the Sora tier. 400 bucks on wheels, 300 bucks on group, 50 for odds and ends. I have a 1x Rival group for less than the Apex tier, with better wheels and a smidge less in weight.
GRX is new and you won't find deals on eBay for a bit. I agree with everyone else saying to go 105 and upgrade as necessary. I got very lucky on the deals I could find, that lock will be scarce looking for GRX.
itskohler is offline
Likes For itskohler:
Old 07-22-19, 10:26 AM
SCTinkering
Quoted: 44 Post(s)
Pulled the trigger on this. Found a set of brand new 105 7000 hydro levers for less than half of retail (they were take offs from someone that thought they weren't good enough?) so my gain and I saved a crap ton of money too.
Likes For SCTinkering:
Old 09-01-19, 07:08 PM
SCTinkering
Quoted: 44 Post(s)
Finally going into the LBS to get the upgrade done. The OE calipers won't work with the 105 levers, so I'm also adding 105 calipers.
Also had to add a Wolf Tooth Tanpan so the 105 shifter would work with the XT rear derailleur.
Swapped out the shimmed SLX single ring with a GRX 800 single ring crank set. the Q-factor on the SLX was too wide to even shim correctly. So that slop is gone.
So yeah it's been an expensive undertaking. Good thing my wife doesn't know or care about how much I spend on bike components. 😁
Old 09-01-19, 07:48 PM
Metieval
Metieval's Avatar
Quoted: 1218 Post(s)
Liked 298 Times in 214 Posts
as for the question in the OP
GRX 1x group $740 doesn't include crank
GRX 2x11 (braze on) $870 - $1050 all on Ebay from Taiwan
the Topstone is clamp fyi
the aluminum Topstone is already 46/30 11-34 sora being 9speed, and 105 being 11speed
the AB ovals are good for oval, but they are picky finicky shifting. and they COST a LOT!
IMO If he isn't racing then gear jump don't matter 9speed is good enough. if he likes the color then buy the SORA and invest in wheels. however sora is mech disc, and 105 is hydra.
really?
Metieval is offline
