Barcons from downtube shifter levers? (campagnolo)
Bikes: 1989 Cannondale SM2000 with drop bars and Nitto technomic stem; 194? CCM Step Through; ???? Stumpjumper (currently frame)
Quoted: 22 Post(s)
Hello all,
I acquired some Campagnolo downtube shifter levers (just the levers, no more other hardware as per picture) and was wondering if this was enough to somehow come away with some bar end friction shifters, or if they're at least enough to use on the gevenalle shifters? Ideally though I'm after good old fashioned bar end shifters. Thanks!
(if nothing can be done, I'd love ideas for any bike themed things I can use them for, maybe as a zipper, key chain, etc. )
Lever only.... missing all the other important washer parts ...
Their classic friction only bar end shifters is part number 1012/3.. in catalog # 17 publ 74..
Quoted: 4208 Post(s)
Liked 3,875 Times
I suspect that unless you are quite skilled at fabrication the results of trying to make a friction pack for these levers will be poor. I have worked on a number of friction only bar ends over the years and compared to the Sun Tours (and less so the Shimanos) they suck. Very high friction needed to hold the cable from moving with steering swings or bumps and very hard to smoothly move the lever or trim it finely. Andy
AndrewRStewart
AndrewRStewart
you can just use those on your key ring, and buy Gevenalle shifters complete..
... with what looks like a good enough , though not Campy, lever .. can you use that lever you have?
Buy & try..
Buy & try..
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
The bar-end shifter pods from Rivendell would let you mount any Campagnolo-copy downtube friction shifter (Zeus, SunTour Cyclone/Superbe, etc.) as a bar-end shifter, but you still need all the missing bolts and compression washers, as @AndrewRStewart and @fietsbob note above.
https://www.rivbike.com/products/sil...nts-pair-17068
They including the square hole washer in the package these days?
I have 4 _1012/3 on 2 bikes with old RD/FD,
that don't need much cable pull across 6 speeds
More modern (read Slant Panto) do need more cable pull...
Quoted: 22 Post(s)
Might be better off getting the complete 'silver shifter' set pods levers and all
The reproduction of the micro ratchet Sun Tour Sprint is using a down tube lever...
& function well ..
you have to scrounge eBay & old bike shops for the campag small parts...
& function well ..
Quoted: 22 Post(s)
So I contacted Rivendell and with or without the washers these would not have worked with their bar end pods. Thanks everyone for the replies.
Quoted: 2026 Post(s)
Liked 1,096 Times
I replaced mine with Sun Tour Cyclone "Power Ratchet" shifters and the problem never reoccured.
These days the "Silver Shifters" sold by Rivendale and Gevenalle are about the best new friction downtube/barend levers you can get.
