SRAM S7 - how to block it in direct drive
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
I have entirely given up on that hub, in the last decade but I imagine that all one would need to do is set the depth at which the central pin has to enter into the hub. How to fix the pin onto position, though, I don't know, save for having a workshop with perhaps a welding machine.
Senior member
Quoted: 942 Post(s)
Liked 656 Times
The trick is to fix the clutch in the middle position where the ring gear pawls are engaged with the hub shell, but the clutch is not coupled to the planet carrier.
The clutch is actuated by the outer sleeve.
seanspotatobiz
Bicycle Mechanics
9
02-02-18 09:06 AM
daveshack
Singlespeed & Fixed Gear
2
04-12-12 10:33 PM
