Bikesdirect Mini Velo upgrade thread
Old 06-16-19, 06:47 PM
  #801
danduva1
danduva1's Avatar
Bikes: Retrospec Spec SS folder, Cannondale SR 500, Lemond Tourmalet, Cannondale R900, Bianchi Sport SX, Mercier Nano Mini Velo, 1978 Univega TriStar fixie/SS
They fit on my Nano, real snug but no problems. But I didn't like the road noise they made and switched to Primo Comet 1.5 inch.
danduva1 is offline
Old 06-16-19, 09:11 PM
  #802
Cowick22
Quoted: 16 Post(s)
I just saw your reply.
Thanks for the input, I really appreciate it. Road noise, huh? I hadn't thought of that... something to think about before I buy new tires...I have been wanting fatter tires for a while, but I am a bit torn because the Schwalbe Marathon 1.5's I currently have are pretty quiet and that makes for a nice ride...IDK worst case I'll not like them and try different ones...🤷
Cowick22 is offline
Old 06-17-19, 08:08 AM
  #803
grayrest
Bikes: Birdy, Orbea Gain, Optima Baron, SatRDay
Quoted: 24 Post(s)
Liked 11 Times in 8 Posts
I switched my recumbent's tires from marathons to comets and it felt like a different bike. The marathons had been through at least one previous owner, maybe two, and due to neglect of the wheels had worn in a pattern that made them lumpy when on a round and true wheel so the comparison probably isn't fair but the comets are nice.
grayrest is offline
Old 06-24-19, 05:36 PM
  #804
mirfi
mirfi's Avatar
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 191 Times in 119 Posts
Originally Posted by mirfi
This will not work as the rear fork is 130mm (?!?!?!?!?!) and nearly all the shimano hub 406 wheels on the market are 135mm (as this is).
I did find a 130mm hub wheel on Thorusa that is a Dahon replacement. Went from 32 spokes to 28, hope it holds up.
mirfi is offline
Old 07-29-19, 08:30 PM
  #805
Cowick22
Quoted: 16 Post(s)
Panaracer HP406 20x1.75 Skinwall Tires
I just ran across these tires randomly on the internet and was wondering if anyone had tried them out. I love the look of gumwall/Skinwall tires. Not a lot of information out there about these tires. I thought I would check with you guys here to see if anyone had any info on them. I have run panaracer paselas on other bikes and found them to be really nice riding tires.
Cowick22 is offline
Old 07-29-19, 08:34 PM
  #806
Cowick22
Quoted: 16 Post(s)
Glad you found a suitable replacement.
Could you cold set it to widen the rear triangle a bit to get them to fit?
I wouldn't suggest doing it yourself if you haven't done it before but rather have a lbs do it for you...
Cowick22 is offline
Old 07-29-19, 09:00 PM
  #807
Cowick22
Quoted: 16 Post(s)
DarkRock MiniVelo from AliExpress
I was wondering what y'all thought of this DarkRock V22 Ferry Trail MiniVelo with 22inch wheels.
4130 cro-mo frame, tektro brakes/levers, double walled rims. It seems decent from what I can tell.
I have been looking for a MiniVelo for my wife and I this this might be my best option. I have also looked at the Orbea Katy 40, there seem to be only a few available for sale and that's about it. Any info or opinions are welcomed.https://s.click.aliexpress.com/e/ceZJeJpq]DarkRock V22 Ferry Trail MiniVelo[/url]
Cowick22 is offline
Old 07-30-19, 06:42 AM
  #808
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
I would not want 22 inch wheels as it is a very odd size. Roger
rhenning is offline
Old 08-01-19, 08:43 PM
  #809
Cowick22
Quoted: 16 Post(s)
I thought that as well but
Then looked it up and read a couple of places that 22 inch wheels are gaining a little momentum because people want the small wheel like a 20 inch but also want better sustainable speed that a larger wheel provides and that the 22 inch wheel is the compromise.
Cowick22 is offline
Old 08-01-19, 08:53 PM
  #810
Cowick22
Quoted: 16 Post(s)
O am thinking of having a set of wheels built up...
And I am looking at the SunRingle Rhyno Lite rims they are 27.5 width. The Jalco rims on the nano are 22.2 there should be plenty of room for this rim to work laced to either a 100mm front and 130mm rear Tiagra hub.
I was also looking at the SunRingle CR-18 406 20 inch rims but after scouring the internet for info and reviews of both rims I believe the Rhyno lites to be a bit better quality rim. I am not trying to slight the CR-18's but judging from reviews about the Rhyno Lites strength and ability to stay true it just seems they are a little bit better although a tiny but heavier.
From the listing pictures does anyone see any reason these rims won't work for the Nano?
Cowick22 is offline
Old 08-02-19, 12:43 PM
  #811
rhenning
Quoted: 380 Post(s)
The rim you listed says 406 which is a 20 inch rim? I have a Moulton with odd sized small tires and I paid more for the tires than the bike and still had to restore it. Should replace the rims but they are also hard to find and are 3 times the bikes worth plus spokes. Basically I try to not buy bikes with odd tires. Roger
rhenning is offline
Old 08-02-19, 04:18 PM
  #812
Cowick22
Quoted: 16 Post(s)
Yes there are two main types of BMX rims 406 and 451's. Both are 20 inch rims/wheels. The 451's are usually thinner and have alot of small width road bike style tires. (Probably have some wider style rims and tires as well, I just haven't run across them). Although, it seems that most mini velos from Asia use 451 wheels/rims.
406's are more of a BMX rim/wheel but my Mini velo, the Mercier Nano, utilizes 406 rims, I think because BMX bikes are more prevalent in the US therefore more options would be available to US buyers.
That being said it seems most BMX bikes utilize a very wide rim/tire so as a Nano owner I have to be mindful of rim width as the nano can only take a tire as wide as 1.75 inches, that shouldn't matter too much but I am trying to be overly cautious before purchasing handmade wheels
Cowick22 is offline
Likes For Cowick22:
Old 02-26-20, 06:06 PM
  #813
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1942 Post(s)
Liked 1,073 Times in 637 Posts
A question to all who have a Nano. What is the circumference of the seat tube. I am thinking of using a RSX group on a Nano and need to know if the band will fit around the seat tube.
Thanks for the info!
3speedslow is offline
Old 03-01-20, 06:37 PM
  #814
mirfi
mirfi's Avatar
Quoted: 168 Post(s)
I've had fun with seatposts. Nano is 29.2
Common seat post sizes
27.2 mm = 1.07inch = 1 1/16
28.6 mm = 1.125984 = 1 1/8
30.4 mm = 1.19685 = 1 13/64
31.8 mm = 1.252 = 1 1/4
33.9 mm = 1.335inch = 1 21/64 (close to 1 5/16)
Seat posts I have
Hummer 27.2
Raleigh 20 28.6
Nano 29.2
Downtube 30.4
Urbana 31.8 21inch – 550 - Shimmed
Urbana 33.9 shimmed to 31.8
Common shim sizes
33.9 - 27.2
33.9 - 31.8
mirfi is offline
Old 03-02-20, 05:33 PM
  #815
3speedslow
3speedslow's Avatar
Bikes: A few
mirfi
Thanks,
My local shop has checked online and found two silver 29.2 choices. Ifn’ I want to go that route and not shim.
Old 03-19-20, 08:34 AM
  #816
3speedslow
3speedslow's Avatar
Bikes: A few
The Nano Is Back!
Got a sales message from BD and purchased a 53cm black one. Eager to empty my project box on this one! It’s going brifter, full group RSX as much as I can.
Old 03-21-20, 08:29 PM
  #817
mirfi
mirfi's Avatar
Quoted: 168 Post(s)
And still $299
mirfi is offline
Old 03-22-20, 01:10 PM
  #818
3speedslow
3speedslow's Avatar
Bikes: A few
And still $299
Boom! Got that right!
Mine is due on Wednesday. So torn right now, after fresh grease in all the places do I put it back together and ride or start the modifications and then ride.
Old 03-22-20, 05:05 PM
  #819
mirfi
mirfi's Avatar
Quoted: 168 Post(s)
Cool, I am voting for the former, just to have a baseline. And to feel the effects of each mod.
Godspeed
mirfi is offline
Likes For mirfi:
Old 03-23-20, 06:26 PM
  #820
3speedslow
3speedslow's Avatar
Bikes: A few
Well I was wrong. This was waiting for me at home after I finished my day’s deliveries.
2 days early!
Likes For 3speedslow:
Old 03-24-20, 08:59 AM
  #821
3speedslow
3speedslow's Avatar
Bikes: A few
Since it seems to be a rainy day, I will slow down on the build. Impressed with the packing job! No issues with this frame so far!
I am also impressed with the waste, reuse and recycle footprint.
Fit adjustment
Out of box
Waste
Recycle
Reused for later shipments
Old 03-24-20, 12:05 PM
  #822
12boy
12boy's Avatar
Bikes: brompton sl, surly steamroller, fuji track, gary fisher bmx minivelo etc
Quoted: 156 Post(s)
Liked 16 Times in 12 Posts
You may want to check wheel and headset bearings...mine had only minimum grease and that resembled Vaseline. I think there was zero grease in the bottom bracket as well, which isn't good in terms of removing it later. Grease is cheap so it is puzzling why they would skimp on a little grease.
12boy is offline
Old 03-24-20, 05:59 PM
  #823
3speedslow
3speedslow's Avatar
Bikes: A few
I will certainly do the regrease when I take it down after a ride tomorrow. Some changes I have noticed from past releases of the Nano
-BB is a cartridge now
-dropout hanger is not replaceable
​​​​​​-promax for the brakes
-Shimano Sora blk for rear, Claris blk for front
here are some parts for the upgrade.
First round change
Old 03-25-20, 08:08 AM
  #824
12boy
12boy's Avatar
Quoted: 156 Post(s)
I do like the black frames although mine is Orange. Even though I have the 53 cm frame, I opted for bull horns to stretch out a bit. Othere changes included a 27.2 seat post witha shim, SPDs, 12-32 sprocket, s a Brooks saddle and a Nitto technomic stem.
12boy is offline
Old 03-25-20, 01:23 PM
  #825
3speedslow
3speedslow's Avatar
Bikes: A few
As for the first ride, weighted 27 lbs.
