Battery problem
Bikes: repco MTB 26" + sram 2 speed automatix hub , road king cruiser 26" + lifepo4 48v x 12ah + 200w motor
Battery problem
Hi , ive got a problem im hoping isn't serious and its to do with my battery . Today I removed the battery from my bike and connected it up to another ebike . When it was connected to the other bike nothing happened so I immediately disconnected it . I pushed the button on the battery to see if the green bars lit but only a red light comes on now .
There was no smell indicating something burnt out and no noise . I checked the fuse and the wire isn't burnt out so im stuck hoping I haven't ruined the battery ,,,,any suggestions ?
Also to mention ,, the battery is a lifepo4 48v . The fuse may have been burnt out on the end and I couldn't see it but it looks ok except for a slight brown tinge on the glass . If it is the fuse there,s nothing on it to say what type it is .
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
It isn't likely that your battery has been truly killed. Fuses blow/trip due to a fault/short. I'd guess the (evil battery killing) ebike is drawing a big load and getting hot somewhere (not shorting).... which is melting a heat sensor in the battery pack.
Quoted: 883 Post(s)
Liked 824 Times
Rick, as indicated above, it doesn't seem as though you ruined your battery connecting it to another bike. Easiest thing to try is replace the fuse and try the battery in the previous system. If that doesn't work, you might consider recharge since it may have been dormant for awhile (give it enough time to balance) and try again.
rick
thanks to dave cutter and 2 old , the battery problem has been fixed . I pulled the bms off the top of the cell and when I turned it over ,,,the underside of the printed circuit had a burned 3mm foil track going to what I suspected to be the power supply . I took it to a guy I know who repairs guitar amps and he resoldered it . Its now back on the bike and going as it did before this happened . I also took it to a battery shop where they checked the cell and they told me it was unharmed by the fizzle on the BMS ,,,. All is good !
rick
rick
Quoted: 883 Post(s)
Liked 824 Times
Rick, great job correcting the problem. Ron (spinningmagnets on ES) has an interesting article in electricbike today. He stated that many battery problems were BMS related.
rick
commu*ist spy
so the battery shorted and burnt a wire inside... I wonder why it didn't trip the fuse first.
also, I would be cautious with the other bike that you put the battery in. there's obviously an exposed wire somewhere in the controller or power wire that's shorting out the battery
