Front pannier racks..I don't get it
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
I'm fitting out a touring bike and have arrived at the front rack question.
I know, many tour without a front rack..though in the event I think I'll need one, I'd like have the "which one?" decision made. Also..if I know what I'm looking for, it's easier to jump on a deal if one comes along.
So my question...Why are front rack sooo pricey? I have a Axiom Journey adjustable rear rack (model 2429) that I picked up new for $22.
When I look at the various front racks they run 4, 5, 6, 7 times that money. And when I look at front rack construction...beyond basic design changes to accommodate the front fork location, front racks look pretty much the same as rear racks..same tubing..similar complexity of machining-build. Often they are even more simple in design and are rated for less weight than rear racks. So why the high price? Less competition? Fewer suppliers?
One that isn't very expensive & I like the design of(combines a top rack & front pannier hangers into one unit), is the Sunlite. I'm not fond of, don't really need the QR skewer mount as I have mid-fork & lower braze ons, but the design makes sense. I haven't come across much discussion of anyone actually using the Sunlite rack though...is it junk or does anyone use it?
fishboat, The advantage of front low riding racks, where the panniers placed as close to the axle CL as possible, is to promote stability while under way. Yeah, they'll cost more than the parcel rack pictured, but the weight will be lower with a much more secure mounting scheme. The more secure mounting will also allow more weight to be carried by the stronger, less dished front wheel allowing for better load F/R balancing.
Brad
Brad
Quoted: 759 Post(s)
Liked 810 Times
Brad
Brad
If I went with a low-rider rack, I'd probably end up getting a separate above wheel rack for carrying a light-bulky item...this is why I liked the combo in one rack.
Though there are low-rider racks with the above wheel rack built in (like the Surly Nice Front Rack).
This is a Trek 920 Front Rack I just stumbled on, hadn't seen it previously..looks like a reasonable design with lower cost..anyone with experience on this rack"
Still..my original question..I'm just a little baffled why front racks cost so much more than decent (not necessarily expensive) rear racks. They're basically the same raw materials, same labor, same machining process/equipment, just a different layup jig.. Though I understand cost & price have no relationship to one another..maybe just the lack of inexpensive knock-off competition allows the existing manufacturers to demand a high price..and get away with it.
Quoted: 2604 Post(s)
Liked 1,934 Times
Touring cyclists have had racks break on them. The heavier the load, the rougher the road, the less expensive the rack, and the unluckier the rider, the greater the chance of it happening to you.
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times
The Soma Porteur rack is quite versatile. Small panniers on lower bar and optional fence on top:
Deluxe Porteur Rack ? Black CrMo | SOMA Fabrications
Quoted: 759 Post(s)
Liked 810 Times
Of course I was also hoping someone would know of a low rider front rack with a top fence rack attached that was good quality and ran less than $50..new..as the used market appears to be non-existent. Ain't nuthin easy..
Quoted: 759 Post(s)
Liked 810 Times
Tubus. chromoly steel tubus - Tara
Packs down small, when you have to Box the Bike to tour more places than Loops from Your Front Door.
& will last your lifetime + ..
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
It makes sense to me that front racks would be better than rear racks for handling, but how are they when you want to slow the bike on a descent? I flipped a bike once when I tried to scrub off speed going down a long hill (with no luggage) and have been wary of that ever since. I now shift my weight back as far as possible when going down hills, but I'm not sure if that would help much with extra weight over the front axle.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
FWIW, while I perhaps overloaded it, I wasn't too impressed with that Axiom rack. Just never felt that secure to me. Fiancee had no complaints, though, so maybe I'm just nitpicking too much.
After one tour, I can definitely say I'm also in the market for a front rack, and I agree on the lack of reasonable options. All my gear plus my 205# self on the back tire made the front way too light.
Quoted: 759 Post(s)
Liked 810 Times
As I continue to bang about the web..it appears the Jandd Extreme is pulling ahead of the pack in terms of an integrated low-ride & top rack, mounting options (I have both mid-fork and fork-end mounts on the bike), overall size..or lack of it, and price. I still think it's over-priced by about 2-3X..but..I can't make one myself, so there's not many options..
Not my bike..just an image of it mounted:
You're asking why manufactures charge a fortune for taking maybe $10 worth of tubing, bending it and maybe welding on tab here and there and drilling a few holes? Because they can. Not only that the more expensive it is the "better" it is.😀
Quoted: 18430 Post(s)
Liked 15,585 Times
Don't try this with a flimsy front platform rack. Worth all 19,000 pennies to me.
Touring Enthusiast
Bikes: 23" Schwinn High Plains, 20" Trek 830 Antelope
Quoted: 22 Post(s)
I use a Minoura MT-4000SF on my bike. It is made from tubular STEEL and is not expensive.
https://www.amazon.com/Minoura-MT-40...ura+front+rack
I can assure you it handles hefty loads very well. It carries my 35lb photo bag and 15lbs in my front panniers with no problem.
At ~$68.00 USD it's a steal. I had to make brackets to attach it to my bike, but that was very easy.
deleteme
Bikes: deleteme
Quoted: 50 Post(s)
Small market low turnover. I have broken/worn out 5 rear racks and just one front rack over 30yrs.
Only in PNW bike towns do I see people rocking front racks on non-cargo, non-grocery bikes.
If you have multiple mid fork eyelet non-disk bikes I like the jandd racks. However, I've been eyeballing minoura expedition racks. The only on the road grouchies regarding front racks I have heard about from other riders are with two piece front racks.
Punk Rock Lives
Location: Throughout the west in a van, on my bike, and in the forest
Bikes: Long Haul Trucker with BRIFTERS!
Quoted: 119 Post(s)
Liked 46 Times
They may be on the pricey side but they are worth it for apportioning weight. What is in the front racks can be accessed while straddling the bike on the road, so I tend to put my rain jacket and some minor repair gear (e.g. allen keys, spray lube, snacks, etc) in the front, along with other stuff. I personally like the high racks because I use the top part for awkward shaped stuff or my cooking gear, instead of jamming it into my panniers.
Rear Rack, panniers + Handle bar bag may be good enough for you ..
It has worked for others [famously Ian Hibell ]
do what you want.
do what you want.
Bikes: Airborne Carpe Diem; Trek 520
And yes, keeping one's weight as much as possible over the rear wheel is what I would do in all such cases and I have 1 1/2" tires on 26" wheels.
I put a rear rack on the front of my bike. Looked at frame bags or handlebar bags?
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
Stabilizer bar is needed.
