Light in darkness
Light in darkness
I noticed some bikers seem to have some kind of 'flash light' on the steering wheel of their bike. I believe these are specifically made for bikes. I'd like to add one in order to have a better view on the (distant) road in darkness. Safety concerns really. Something really reliable/durable.
Can anyone give me some advice, experience? Especially, which brand(s) do you recommand?
Rechargable battery or not? Luminosity? ...
Urban 800 Fast Charge - Light & Motion
I use the L&M on my helmet. The front light on my commuter bike is powered by a hub dynamo so that I never worry about batteries. The L&M light referenced above is an enclosed rechargeable lithium battery and has newer technology that allows "fast charging." Lots of lighting discussions in the "electronics, lighting, and gadgets" forum. Be prepared to get lots and lots of different suggestions.
I like Cateye volt lights. I like their mounts and that I can easily get another mount to put on different bikes. I have the Volt 800 which is plenty of light on the dark road I ride on. I recommend a steady on light and rechargeable if you are riding on a dark road. Flashing works okay on well lit road, IME. Try not to use a slow flash mode as it is really hard for anyone to judge your speed when using that mode.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
You should definitely get some lights. Headlight and red tail light. You have lots of options! Batteries or rechargeable or several kinds of generator, at all levels of price. You can put it on the fork or the handlebars or your helmet.
FWIW, I have the Cygolite combo kit with USB rechargeable head and tail lights,
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
As usual with these types of threads, most people recommend what they have, if they like them and it works. I run all Cygolite lighting (Expilion front, 2 Hotshot Pro 80's rear), and besides their performance and features, I highly recommend them because of their excellent mounts. They stay rigid, meaning the lights are always adjusted the same way every time you take one off and put it back on. I DO NOT recommend L&M lights because of their rubber strap mounting methods. In my opinion that's an extremely poor method for mounting lights to a bike.
Quoted: 5793 Post(s)
Liked 2,585 Times
FWIW there's a sub forum devoted to lighting and other bike gadgets.
Bike lighting is a big subject in it's own right, and you can spend anything from $10 to hundreds (plural) on bike lighting. If you're serious about lighting the road well enough to ride by, it'll cost real dough. OTOH if you're mainly interested in being seen by oncoming cars then any number of low cost lights will do the trick.
FB
Chain-L site
FB
Chain-L site
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
No, it doesn't. $15 to $20 buys a lot of light. The light may not have the polish of higher end lights and perhaps it isn't built to last as long, although this particular light has severed me very well since the fall of 2015. I have others that have been ticking along since about 2010.
But in terms of output, the above are brighter than a lot of very expensive lights. I have an Cygolite Expillion 800 that I purchased for $130 at REI about 4 years ago. The $20 light above is brighter than the Expillion at it's brightest setting. I had a Princeton Tech "be seen" light that I paid $70 for about 10 years ago and the $20 light is about 100 times better.
No, the mounts aren't the best. But there is a work around for that that's not too expensive. I even converted the Expillion to that kind of mount. It drives the cost of the light up to a budget bustin' $35 and a bit of sweat equity.
There's no need to spend "real dough" nor to suffer with "be seen" lights. The above $20 light will not only let you be seen but will let you see where you are going. They are cheap enough that you can gang them up and still come out ahead. I have 2 on the bars and one on a helmet.
Stuart Black
Stuart Black
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Another lower-cost option is a "magicshine clone", like this. The head is very light and goes on the handlebars, and has a power cable going out to the bigger battery case which you attach to your frame somewhere (some people cut the top off a waterbottle and keep it in the bottle cage, maybe along with a patch kit etc). These are bright enough, but have a VERY narrow beam, making a bright circular spot about a foot in diameter ~10ft in front of you. If you get this you will want to get a spreader lens. That spreads it out either in the wide or long direction (depending how you rotate it in there), according to your preference.
If you're riding at night you will also want a bright red blinking tail light. It's easier to get something decent for not much $ here, since you only need light to be seen, not light to see by. I've used PlanetBike Blinky, it's pretty good. But I think the favorite light out there is any model Cygolite Hotshot. Very much worth the $30-ish they cost.
LET'S ROLL
Lezyne Mega Drive on handlebars, Cygolite Hotshot Micro and Hotshot Pro on seatpost, NiteRider Lumina Flare 650 front and rear light on helmet.
Long Island City, NYC by 1nterceptor, on Flickr
Lights on my Brompton by 1nterceptor, on Flickr
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I'm perfectly happy with Chinese lights costing $30. I'm also pretty happy with my Cygolite Metro 550. But I doubt someone who has only just discovered that there's such a thing as bike lights is likely to want to dosh out $50+ for a headlight.
Work: the 8 hours that separates bike rides.
I have had the Chinese lights, they are plenty bright. My issues with those lights has been with them changing modes or going off when I hit the slightest of bumps. I've also had problems with battery packs and some the individual rechargeable lithium cells. Also, I found that the very bright light spills all over and can be annoying to oncoming riders or traffic.
Quoted: 676 Post(s)
Liked 13 Times
I keep my lights specifically aimed so as to reduce or eliminate blinding of motorists and other road users. I don't want to have to mess with that over and over again every time I mount the light or move it to other bikes. Cygolite mounts fit that requirement very nicely, and they are easy to tighten and STAY tightened. I've had cheap bike light mounts that always want to come loose. The Cygolite mount never comes loose. The light also doesn't vibrate or bounce around, like my BT speaker does with a rubber strap mount.
I think a more appropriate statement would be: if you want a light to see by, that is also self-contained and easily moved between bikes, it will cost real dough. I like to use one light to see with, and I like that I only have to deal with one (forward) light that needs to be charged, that I can easily move between bikes with additional mounts, and can be easily removed and thrown into my charging station box for charging.
Sorry, didn’t notice there was a sub forum (me newbie). And ‘handlebar’ is what I meant, of course.
Thank you all for your sound advice.
Quoted: 5224 Post(s)
Liked 3,585 Times
Liked 4,221 Times
The Mawri mounts cost about $10 each. Even with 4 bikes with 2 mounts each on them, that's only an extra $40. A helmet mount costs about $5 so, all in, I've spent about $100 for lights and mounts. I still have 3 lights that are brighter than the Expillion for less money.
Stuart Black
Stuart Black
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Quoted: 676 Post(s)
Liked 13 Times
Self-contained? I haven't really seen the need nor do I find the Expillion to be superior to the other lights I use. It certainly doesn't have the run time of the Magicshine clones and, at $135 per, even I can't justify having more than one of them. The o-ring mount on the Magicshine (and clones) works and it's easy to move from bike to bike but, I do agree that there are better mounts out there. The Mawri mount that I linked to is far superior even to the Cygolite mount which is why I converted my Expillion over to the Mawri mount.
They're also designed, engineered and assembled in the USA, which might be important to some people.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
I've owned a set of the eBay/Chinese CREE lamps with the separate battery pack. While they were quite bright, the battery didn't last very long, requiring a charge twice a day (once at work and once at home). That in itself was a PITA, but then there was the charging wire that failed which required minor surgical splicing, and then the cable from the battery failed, and again, more surgery. The mounting was also a hassle. In the end I just gave up, or rather, it gave up.
I'm currently running two 'self-contained' units. One requires charging once a day as I run that one at full power. The other at night time flash, and then day time flash. Much simpler.
In terms of how much power you need, more is better.
Quoted: 676 Post(s)
Liked 13 Times
Liked 4,221 Times
Expilion 850 is $90 max, other versions are less. The Metro 850 is less than $60. I don't want to deal with external batteries and wiring, and I find the daytime flash and night pulse modes of the Expilion to be superior to modes on other lights.
Frankly, I'll gladly deal with wires to get more run time and much more light. Personally, I only use the Expilion during the transistion times in the fall and spring when I don't need 2 hours of lighting to get to work and, more importantly, back.
Stuart Black
Stuart Black
Quoted: 676 Post(s)
Liked 13 Times
MSRP hah, anyone who pays that is too gullible. The 850 is $90 or less all over the internet. I'm actually thinking of picking up a Metro 850 now that I see it for less than $60. It's basically the same as the Expilion with 2 fewer modes I think, which are 2 modes that I never use. An 850 lumen self-contained light with a great mount for under $60 is a smoking deal.
