Best dyno lights for a front rack mount?
Old 01-22-19, 02:45 PM
cormacf
Bikes: 2017 Lynskey Sportive Disc, 2021 Lynskey Pro29, 1977 Schwinn Super LeTour 12.2
Quoted: 119 Post(s)
Liked 70 Times in 29 Posts
Planning on mounting a dyno (Shutter Precision)-powered light on the bottom of my front rack. Will be riding in total darkness quite a bit (brevets and Seattle winter commutes), so lighting the ground is as important is being seen.
Any suggestions?
Thanks!
Cormac
cormacf is offline
Old 01-22-19, 02:57 PM
unterhausen
Randomhead
Liked 3,699 Times in 2,519 Posts
For randonneuring, I would go with an Edelux II or an IQ-X.
unterhausen is offline
Old 01-22-19, 03:13 PM
Kedosto
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times in 190 Posts
Tough to beat the performance and value of the B&M lights. My 80 lux Cyo Senso Premium with its shaped beam is a total game changer. The shaped beam allows control over where the light is cast. Follow the instructions and you'll enjoy riding with an amazing field of view without blinding oncoming traffic. B&M has a 100 lux (IQ-X?) which, considering how nice the 80 lux performs, must be insanely great. I also recommend B&M taillights.
-Kedosto
Kedosto is offline
Old 01-22-19, 03:18 PM
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
There isn't nearly the room you think there is under your front rack. Adjacent to the rack might work but leaves the light either ripe for getting hit or one side of the bike blind. Mounting at the axle leaves the bike susceptible to splashes and throws the light too horizontal. B&M specifically say not to mount the light at the axle. Also they say that a dynamo light mounted mounted upside down won't have good optics & is likely to fill with water. Between the fork crown and the handlebars is best.
I am pleased with the B&M Lumotec IQ-X it's 100 lumens, but has a narrower throw & weaker plastic mount than the Luxos U. I think the driven led's are likely the same but The Luxos U IQ-2 is nominally 70 lumen, largely on account of the wider light distribution, thus lower light "density". The Luxos U IQ-2 will do 100 lumens for short periods of time until the internal cache battery depleats. The Luxos U IQ-2 also has a remote switch I don't like because the housing broke after 50 miles, & the switch seems susceptable to water intrusion & has to be mounted somewhere. So yet another wire.
The problem. with dynamo lights rests purely on the number of electrons you have in supply. Bright & focused or less bright & distributed. Either light I mention is plenty bright enough to ride by, but my preference is the IQ-X due to it's simplicity.
base2 is offline
Old 01-22-19, 04:04 PM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
Agreed.
I've seen a "mount" that'll hole one of these on a rack, though I can't find a link now. It's basically just an arc of sheet metal, presumably fairly stout, with a hole in either end. One bolt holds it to the rack, and the other holds the light to the mount offset from the rack so you get clearance. IIRC you could buy it for $10-15, although an afternoon in the garage with a Dremel and some aluminum sheet stock might be cheaper. It looked fairly elegant, though I never got a round tuit to mount my troubled light like that. Anyone remember where that was?
pdlamb is offline
Old 01-22-19, 04:08 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
E Delux body & mount is Aluminum, lens Glass; B&M, plastic .. Tab, most of body* and Lens
I have the B&M Eyc Senso T on my Brompton, Fork Crown Closer to the ground so seems brighter..
* top of body is aluminum for LED heat sink dissipation..
In LBS, had more than 1 B&M Luxos U* arrive at tour's end, broken off , mounted on the front rack of tour bikes.. getting to the coast..
getting a rack fabricated with a light guard?
* that one includes a USB output..
fietsbob is offline
Old 01-22-19, 05:00 PM
Kedosto
Quoted: 564 Post(s)
All very good points. No upside down mounting. No sideways mounting. No axle level mounting. I originally mounted my B&M off the front of my porteur style front rack. It stuck out too far for practical use and I got tired of knocking it on things. It was only a matter of time before I broke it. I could have mounted it back at the fork crown, but with the porteur rack anything placed on the rack blocks the headlight. I ditched the rack and went with a Tubus Duo set, and mounted the light at the fork crown. The world is now a well-lit place.
The mounting arms on my B&M headlights are stainless steel and are very stout. It would be a shame if they cheaped out with plastic mounts on the new models.
-Kedosto
Kedosto is offline
Old 01-23-19, 01:30 PM
fietsbob
Bikes: 8
With my Koga WTR (short travel) Suspension fork, I used a B&M Nylon Mount on my Schmidt e6 and kept it, for the E deluxe ... its been fine for 10+ years..
so Best , for clarity, if you specify Which Plastic ...
The casing of the B&M headlight is not ductile like Nylons.. its more prone to crack , and have things like the mounting tab break off when hit..
My Eyc is well protected, under my Brompton front bag, use a stamped from Stainless steel sheet metal mount on it (Schmidt made)
fietsbob is offline
Old 01-23-19, 03:38 PM
Harhir
Harhir's Avatar
Bikes: Fahrradmanufaktur Trekking Bike, 2 x Lightning Phantom, bikeE AT, Radwagon3
Quoted: 180 Post(s)
Liked 138 Times in 72 Posts
I am using an IQ-X and love it. I have several trail sections through the forest which are in the pitch black and this little headlight provides a lot of light. I however did not use the standard plastic bracket but used a more sturdy metal bracket.
Harhir is offline
Old 01-24-19, 07:49 AM
Hoopdriver
On Holiday
Hoopdriver's Avatar
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times in 12 Posts
Another happy IQ-X user. Great bright lighting pattern and flexibility in mounting (i.e. the mounting strap can be rotated around the light body for any orientation). Yes the mounting strap (sleeve?) is nylon but seems to be pretty robust. If it worries you, you could fabricate a metal one with not much trouble.
Hoopdriver is offline
Old 01-24-19, 08:14 AM
trailmix
trailmix's Avatar
Bikes: 50+/-
Quoted: 63 Post(s)
Liked 81 Times in 48 Posts
-Kedosto
Totally agree. I am also using an 80 lux Cyo Premium for randonneuring and am very satisfied with it. Like you, I can only assume that the Edelux and the IQ-X are even better. I went with the SON widebody deluxe hub and B&M Toplight in the back and couldn't be happier.
trailmix is offline
Old 01-24-19, 10:35 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
I also vote for the 80 lux Cyo Premium.
What rack are you using? Do you have fenders? If so, what fenders? Here are a couple ways I have that light mounted:
www.rhmsaddles.com.
rhm is offline
Old 01-24-19, 02:59 PM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1759 Post(s)
Liked 488 Times in 313 Posts
I'd get an upside-down Edelux ii, but I got a great price on a right-side up one so I have it mounted with the Nitto lamp holder #6. I also looked at the soma wingman, but it seemed like a bit too much.
kingston is offline
Old 01-25-19, 02:41 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 868 Post(s)
Liked 721 Times in 396 Posts
+1 on the Cyo Premium.
Reynolds is offline
Old 01-26-19, 01:54 PM
angerdan
Quoted: 126 Post(s)
Liked 7 Times in 7 Posts
Any suggestions?
B&M IQ-X is the brightest light and offers much bang for the buck.
bumm.de/en/products/dynamo-scheinwerfer/parent/164/produkt/164rtsndi-01-schwarz-164rtsndi-silber.html?
Taillight:
bumm.de/en/products/akku-batterie-rucklichter/parent/323.html?
spanninga.com/en/product/pimento/
Mounting options:
bumm.de/en/products/mehr/gruppe/Mounting%20brackets.html
bikeforums.net/electronics-lighting-gadgets/1126857-minoura-spacer-light-gadget-mount-di-light-fender-hole-mount.html
angerdan is offline
Old 01-26-19, 04:07 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
Moved from Commuting
Homebrew01 is offline
Old 01-26-19, 05:53 PM
znomit
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times in 366 Posts
You can mount the IQ-X upside down too.
znomit is offline
Old 01-26-19, 09:03 PM
Tourist in MSN
Quoted: 3462 Post(s)
Liked 1,468 Times in 1,145 Posts
I assume you already know this, but just in case you don't, most lights have a vent hole in the bottom and that is one reason (besides light beam) that other posters are saying do not mount it upside down, as rain water can get into the light if it is upside down. But not yet mentioned is the potential for tire spray if you do not run fenders. So, think about where your tire spray is when you decide where to mount the light so that the tire spray does not get into the light casing.
Tourist in MSN is offline
yoitsandy
Touring
10
12-06-16 06:52 PM
veganbikes
Touring
15
12-07-14 08:22 PM
kato1kalin
18
09-09-11 04:06 PM
rfomenko
17
09-17-10 03:07 AM
tsappenfield
Classic & Vintage
5
04-08-10 01:03 PM
