Bright rear light with long battery life
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I am in the market for a bright rear light with a long battery life and am seeking recommendations! Specifically, here's what I'm interested in:
Not interested in dynamo at this time.
- Bright - for both daytime visibility (in flashing mode) and night (steady) road cycling
- Long runtime: preferably 12+ hours
- Reasonably small/light
- Mild preference for USB charging
- Budget friendly (under $50).
Bikes: 2003 Litespeed Vortex, 2017 All-City Mr. Pink, ~1997 Trek Multitrack 700
Quoted: 139 Post(s)
Liked 94 Times
I have the Cygolite Hotshot Pro 150. Of the 6 modes, there is only one that will last longer than 6 hours. In that one mode, I got through a 300K without any issues.
The other light that I like better is my Cateye Rapid X3. I mount it on my seatstay.
Both are USB charging.
Something that takes AAA? I have a few different models and they last a minimum of 50 hours with NiMH batteries.
I have a requirement for an integrated clip and AAA and have been using these for a while now. If you don't need an integrated clip there are many other AAA choices.
https://www.planetbike.com/store/sup...ail-light.html and https://www.walmart.com/ip/Bell-Arel...Black/43120866
The Planet Bike one is really bright but noticed recently when it gets wet it gets wonky. The Bell model is a single LED and not nearly as bright but going good for years in all conditions and will last for a week+ of all day rides.
Quoted: 4560 Post(s)
Liked 2,802 Times
If run time and cost are primary considerations, check out the Bontrager Flare 1 and Flare 3 tail lights. Both run on 3 AAA batteries and will run a heckuva long time. I'm going on about 2 months with the Flare 1 on a hybrid that's often used for errands and long casual and group rides at night. They're rated for 30-80 hours per set of batteries. So far mine hasn't dimmed like many AA/AAA lights do with extended use. One problem with my handful of AA/AAA head and tail lights is the discharge curve is a long arc and about halfway through the runtime the output is about half that of a fresh set of batteries. So far that hasn't happened with the Flare 1. Sometimes switching to NiMH rechargeables ensures brighter output per charge, but also a shorter runtime.
It's the brightest of the AA or AAA battery powered tail lights I've tried, but not quite as bright as my Cygolite Hotshot SL50. But at only $15 it's a bargain. I'll probably get the brighter Flare 3 as well.
It's a bit heavier than a Cygolite Hotshot, but the Flare has the best clip I've tried -- I'd be surprised if one ever popped loose from a saddle bag strap. It has multiple nubs that dig into the web strap. In contrast my Planet Bike Rack Blinky 5 is a slippery rascal and will securely hold only onto the provided mounts on the rear rack or seat post.
While the Cygolite Hotshots are a great value in a bright tail light with an intensely focused beam (the reflector also limits side visibility), a common complaint is that after a year or so they don't run as long per charge and won't hold a charge for long. That's been a minor issue with my Hotshot. Even if I don't exhaust the USB rechargeable battery between uses it no longer holds a charge for a week or longer like it used to -- now I need to recharge it every couple of days, even if it hasn't been used. And in most modes it'll last about 3 hours now.
Best thing about the Cygolite is the compact size, light weight, intense beam that is most intense from directly behind, so it tends to provide a psychological nudge to get tailgaters off your back. The clips are very secure too -- I've never lost one off the fabric strap on my seat bags.
Quoted: 139 Post(s)
Liked 94 Times
- 6 exclusive night and day modes provide enhanced safety : Steady, Zoom, Steady Pulse, Daylighting, Triple Flash, Random Flash
Likes For GadgetGirlIL:
Randomhead
Liked 3,699 Times
can't you reduce the brightness on the Hotshot? I recall the max runtime for flashing on the original hotshot was 56 hours. I'm pretty sure I have used the throbbing setting on my hotshots for overnight. I have also recharged from a battery pack, doesn't take too long. But it would be a good idea to have a spare.
I hate Cygolytes website, why would the only source for runtime be the box, which everyone is going to throw away?
Quoted: 139 Post(s)
Liked 94 Times
If I recall correctly, you can only reduce the brightness on the steady mode. But I do 95% of my riding alone and feel that the flashing mode attracts more attention both day and night. When I was stopped at a control this past Sunday I had not one, but two motorists comment positively on my visibility! In case of a serious adverse event, I want my husband to have solid documentation that I was visible.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
@GadgetGirlIL and @unterhausen got me on a bit of a Cygolite investigation.
Turns out that I have boxes from an old Hotshot 80 Pro (lost in a crash a couple years back) and a Hotshot 100, currently in use. Only the 80 Pro lists runtimes on the box. I also learned that one cannot adjust the brightness of the flashing modes (which I tried and obviously failed to do), but rather, the tempo of flashing can be changed.
I'm fairly certain that I was using the three-flash mode when the light most recently failed ~6 hours, but could be wrong. I think an experiment is in order.
Non omnino gravis
Just set it to triple-flash and job done, no money spent. I run my Hotshot Pro on triple-flash and charge it once a week, so it lasts 15+ hours without issue.
Mine is 2+ years old, and has covered over 20,000 miles, so the battery isn't exactly spankin' new. So if y'all can't get a full day out of it, I dunno what you're doing.
Randomhead
Liked 3,699 Times
I like steady/pulse, too bad the runtime is so short. Seems like they could leave the tempo of that alone and use the second button to dim.
Quoted: 523 Post(s)
Liked 230 Times
This is one of the lights (Cygolite Hotshot Pro 80) that advertises an extraordinary run time for one of the settings. It doesn't seem to pan out if this review taken from the REI website for the light is true. "Exaggerated run times
The light is bright, and the product is easy to use. I occasionally participate in rides extending several hours into the night, so extended run times are important to me. So far I have only tested the three longest specified light modes of the six light modes available: random pulse (spec 7-40hrs), single flash (spec 9-50 hrs) and triple flash (spec 40-100hrs). My results: random pulse lasted fewer than 4 hrs. and both single & triple flash lasted fewer than 7 hrs."
The only way to achieve an extraordinary run time is to lower the lumen output substantially or extend the time between flashes. Either one makes the light less visible. I've seen very expensive lights advertising an impressively long run time but with the lumen output as low as 5 lumens. If you really want a longer run time pick one with a larger capacity battery. That's tough since so many of the expensive lights treat that information as though it is classified information.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I just did an experiment: I set the light to the 4th setting (with steady being 1) and let it go last night. 15 hours later, it is still running!
According to the box for this product (the 100), the 4th setting should be random flash, rather than triple flash. The order seems to correspond to that listed on the Hotshot 80 box, not the box for the actual product. My confusion was that both the 3rd setting (which dies quickly) and the 4th setting (which apparently lasts) have three blinks.
Non omnino gravis
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
I just bought the Cygolite HotShot Pro 200 Tail light, I mounted it to the rear of my helmet and WOW! Exremely bright and the Strobe setting emits a ton of very bright light.
I cannot verify its run time as I only used in it traffic for about 1 hour during the daylight and it was still extremely bright when I shut if off. My biggest fear is getting hit from behind in traffic and all I can say it that Im glad I bought this little light.
The battry is Rechargeable thru USB.
12h @ 30lm (steady):
lupine-shop.com/en/led-lightsets/taillights/1675/rotlicht-max
4,5-30h steady:
NiteRider Sentry Aero 260
https://www.niterider.com/product/5088-sentry-aero-260/
USB powerbank connected (2-20h):
https://www.orfos.us/pages/flarepro
4,5-30h steady:
Hotrod 50 on the other hand good at about 180 degrees or so. 50 50 and 50 = 150, get 3 hotrod 50 insted of 1 150.
3M reflective tape in white amber blue and green works very well, half inch wide works for bikes.
overpowered from about a 20 degree angle, useless for about 340 degress. no 150 for me.
https://www.amazon.com/gp/product/B01MUDQQ0H
A little more $$ but works great. It is thinner than the 3M tape but far more flexible for using on bends. Lasts years.
Liked 2,802 Times
Cool thing about the Cygolite Hotshots is that it's painfully bright only when viewed from directly behind. It has a narrow aperture of maximum brightness, due to the reflector design.
Which in theory should nudge cars off your butt.
Sure works for me when I'm in a group ride and someone ahead has their Hotshot on maximum strobe. It's hard to follow directly behind anyone using those modes on a Hotshot. In group rides I always set mine to steady dim, and use a less potent blinky as a supplemental light.
I think the triple flash mode has much lower peak intensity, which is why it lasts the longest per charge. That's what I normally use.
Non omnino gravis
I've had numerous people pull up next to me at stoplights and say something along the lines of, "That is the brightest taillight I've ever seen. What is it?" So if the Hotshot Pro is only effective from a 20º viewing angle (which it absolutely isn't) then that's fine by me.
One of those people was a lady in full kit-- driving home from a ride-- who made a U-Turn in her SUV to chase me down. Meaning in her rearview mirror a Hotshot is so bright she took notice. Oh, and I don't often ride at night. All of these interactions happened in broad daylight.
Randomhead
Liked 3,699 Times
the two flashing modes are indistinguishable to me, the triple flash with longer runtime is second in the sequence?
There are a lot of lights that are impossible to follow, even on steady. main thing is to aim low
Light
Toplight Line tail lights for rack mount, are 2 LED with a fresnel lens and will light up the whole thing..
I use the wired ones, this is the battery one.. battery is AA so long run time .. they do not blink..
