Slippery friction shifters
Blast from the Past
Working with a set of Super Record shifters that don't generate enough friction to hold a gear. Worse on front than rear. These are NOS shifters & I'm guessing that the nylon spacers just got hard/slippery sitting over time. Any tips on improving operation?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1085 Post(s)
Liked 1,822 Times
Yes, get some wonder bread
and a hole puncher
and a nickel
make a plastic gasket. So much more grip.
robert
and a hole puncher
and a nickel
robert
"Leave the gun. Take the Colnagos."
Quoted: 2488 Post(s)
Liked 2,957 Times
I'm probably not the only one who guessed that this would be about Campy shifters.
For the Campy downtube shifters on my bikes, I used to pinch the threads on the D-ring bolt with a Vice Grip, very gently, to provide an interference fit. It doesn't take much deformation of the threads to keep the bolt from slipping in use.
I hope this suggestion doesn't upset anyone, like the narrator in Zen and the Art of Motorcycle Maintenance suggesting to his horrified traveling companion that he should shim the slipping handlebars on his pristine BMW bike with a piece cut out of a beer can. ("Best shim material in the world!")
Edit: blue Loctite would work just as well.
Likes For Trakhak:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Make sure you have all the parts and that they're installed properly:
Quoted: 877 Post(s)
Liked 2,296 Times
I have not had that issue with any of my Campagnolo shifters , even the bar ends. I am able to hold gears with hand tightening the D-ring on the DT shifters.The bar ends are a bit fussy to get just right but once set are good . I would suggest a good cleaning and look at a diagram to make sure they are assembled correctly . Someone here should have a copy of the exploded view of the assembly.
Likes For Kabuki12:
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
I still wanna know about the Wonder Bread gasket. Are we making it out of bread or out of the plastic bag?
If we're using the bag, does it matter which color circle you cut out?
Likes For albrt:
Blast from the Past
Yes, installed correctly, parts match the braze-on exploded view above. Cleaned and installed a couple times. Hand tight the rear just barely holds. The front shifts right back down to the small ring as soon as you let go of the lever. I’ll try cleaning again & perhaps rough up the friction surfaces with a little 400 grit?
Quoted: 877 Post(s)
Liked 2,296 Times
It could be that one or more of the surfaces are worn so that when tightening the D ring there is not enough pressure on the lever. I have the braze on ones on my Colnago and I really don’t have to tighten them that hard.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Take note of part 190/06 It is not intuitive. But, it is very comon to install it backwards. Backwards installation (dome mating to dome) causes all kinds of isues. Domes mate to squares is correct for forgiving, consistant & easy friction adjustment. Study the drawing.
Car dependency is a tax.
Quoted: 472 Post(s)
Liked 1,028 Times
I’m having no trouble with my 70s band clamp Campy shifters. At initial overhaul I cleaned everything out and reassembled with a light film of grease. I’ve redone that a couple of times over the past 10 years. They both work flawlessly. I do need to snug the adjusting nuts a whisker, this time of year, due to the colder weather.
As for spacers, I’ve had success making new plastic spacers out of milk jugs, that translucent white plastic material. Use nice sharp tools for clean edges. Seems to be just the right thickness. As to Wonder Bread: good for chocking a tractor wheel. Not worth opening, let alone eating.
Likes For Prowler:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
Try reducing your cable tension. If not, a tiny drop of Loctite (I use red) on the bolt. Fibre washers are available. As long as the outside diameter is correct, that's about all you need, The hole can be easily expanded at home.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Quoted: 1106 Post(s)
Liked 1,328 Times
For the Record shifters -
If you problem is that they never get tight enough, make sure the two bits that are supposed to apply pressure on the shift lever are not hanging up on the flatted part of the pivot - look for a machining flaw or bit of grit that would prevent them from seating correctly.
If instead once tight they loosen over time, the two pressure bits are shifting slightly on the flats, so you would need to stop that - judicious application of a sharp punch next the flat on the inner surface of the outer bit is what I'd use.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I still want to know the Wonder Bread answer
Likes For sced:
Quoted: 3464 Post(s)
Liked 2,831 Times
I do not like this revised design, I am sure it was cheaper to make.
be sure to test thread in the D ring bolt to make sure that any paint or debris is not sending you a false sense of tension. Tapping these out is a pain as one needs a “bottom” tap
Blast from the Past
Appreciate all of the responses. I'll clean everything up again and verify that nothing is interfering with compressing the friction washer on the lever. I have the levers with the nylon washers 0190/4 & 0190/6.
Liked 2,831 Times
grey haired plumbers would use a small bit of white wonder bread to act as a sponge and block dribbles of water near a copper line repair, any water was clear of the soldier joint and the bread would dissolve quickly enough later.
Likes For repechage:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 302 Times
https://www.performancebike.com/fini...750101/p332614
This sounds tweaky--either finagling the adjustment screws to remain in place (Loctite) or making the works less slippery.
Old fart
Liked 3,401 Times
Likes For JohnDThompson:
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
I heard of an apprentice plumber that didn't have any white bread handy, so he used the whole-wheat bread from his lunch sandwich. The kernels of wheat fouled the valve pretty good.
Liked 2,831 Times
you might consider using a second “Lock” washer under the D ring bolt. As I wrote earlier, Campagnolo eventually supplied 4 washers with a lever assembly kit, enough for 2 per side.
Liked 2,831 Times
other plumber note, place the weld seam of a “Black” waste line at 12 o’clock- I just had a repair where the weld seam split open, it was near the bottom. Bad pipe? Yeah, might never know if it had been at the top.
he also used Henry’s roof sealant at any no-hub connectors. Smart thinking.
Blast from the Past
It was definitely the D-Ring screw bottoming out before squeezing the lever to a correct amount of friction. More on the Front than the Rear. I chased the threads on the D-Ring and in the boss with minimal improvement. A second lock washer was the fix. Didn't have any metric on hand but a #10 was close enough to work.
Likes For Voodoo76:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Maybe not for these levers, but any missing shim or washer might result in the screw bottoming in it's hole(?).
Old grease can leave a very viscous film that makes it hard to move the lever, but which then slips over time, but a little oil or WD40 can break that up and restore correct operation.
Same goes for inside of the steerer, where the stem expander perhaps fails to grip as expected.
Often, as oneclick mentioned, an anti-rotation washer can have a little play on the boss flats, allowing the ring to loosen a tiny bit with each gear change in one direction or the other (left vs. right lever).
Fixing this is very hard, because the washer metal is VERY hard. I've struggled to find tools hard enough to displace any metal adjacent to the flats...
With certain levers including Simplex (plastic) levers or any levers having plastic friction washers, fresh grease (perhaps the wrong grease) can at times be too slippery. Adding a drop of light oil as I always do (and/or patiently allowing the surfaces to seemingly become "contaminated" with metal wear material) restores the grip. One might suspect certain anti-friction additives used in modern greases here (some contain Teflon or other slippery polymers).
Sometimes, as 1989Pre mentions, reducing the cable tension (or lo-limit screw tension) will prevent certain instances of slippage down from the largest cog.
Likes For dddd:
