Newbie Question: Installing Bar Ends??
Southern Grrl
Bikes: Marin Hawk Hill, Trek 800
Hi Ya'll! I just got some bar ends from Pricepoint and want to install them on my MTB, a Marin Hawk Hill. Installation "seems" fairly simple just by looking at the bar ends(pic of them attached). I'm guessing I need to cut the rubber grips correct? Is that all? Just cut them an inch or so, just enough to clamp on the bar ends? Anything else I need to do? Read somewhere that I need to slide the shifters over? How does one do this? I am a girl and not good with mechanics...should I just take it to the LBS for this?
Freewheelin'!
Bikes: A big one
yeah, you can cut your grips if you wish but it will reduce space for your hands. it may be just best to slide everything down a bit more. just take your time and you'll be fine.
Remember Wool Shorts?
Bikes: Gios Torino, Lemond Zurich, Giant
It would help if you cut the grips "off" the bars. Meaning, take them off.
Bikes: 2005 Scattante R660 Triple, 2006 Specialized Rockhopper Comp Disc
Here's how you do it. If you need the extra grip space, then cut holes big enough for the bar to fit through on the ends of the grips. Slide the grips inwards leaving enough space for the barends.
Put the bar ends on and enjoy.
Alternatively, you can just remove the grips all together. And use bar tape. Don't move the shifters or brake leavers unless you need more space to use them.
Bikes: 1990 Burley Bossa Nova, 1992 Paramount PDG-70, 1993 Specialized Stumpjumper, 2005 Jamis Dakar XC Pro, 2007 Rivendell Bleriot
Quoted: 28 Post(s)
Liked 5 Times
I would just move the grips and brake levers in by the width of the bar end clamps, unless you like having your handlebars as wide as possible. Depending on how/where you ride, narrower bars can be good (although they are definitely out of fashion right now).
https://www.bikeforums.net/showthread.php?t=172381
