Buying a crankset
Dirt Bomb
Quoted: 5473 Post(s)
Liked 288 Times
Buying a crankset
I need a crankset for my beater bike. It is a low end Trek 820. It is a 7 speed. I don't want to sink a lot of money into it. My question is, will this:
https://www.bikepartsusa.com/bikepart...rank-crank_mtn
Be a good replacement for this:
The worn out crank has 28/38/48 chainrings and 175mm cranks. It is riveted together. The problem with the new one is there is no information. I don't know the ring or crank sizes. But as long as they would work it really doesn't matter. I think a 170mm crank would work.
OR
Could someone suggest a crankset that is a little better? The next best one I could find is about $60. I would get that if I had to, but if the $16 one would work I'll go with it.
Thanks in advance.
OR
Thanks in advance.
Bikes: 1992 Marin Eldridge Grade, 2007 Kona PHD and 199? Trek 1000 (current build project)
I think those Pyramid ones are 42/34/28 if it's the on I think it is from this page. If it's the other one, then it's 48/38/28.
A cheap'n'cheerful Shimano Tourney triple like the one below you can get for around $30 US.
Really Old Senior Member
You'll probably have to change the BB too. it seems the newer cranks use shorter spindles than the older ones.
Are you really sure your crank is worn out? Compare the teeth to a new crank before you condemn it. Not all teeth have the same profile. Some are different to assist shifting.
might as well get the BB,too, length, as recommended be used with that particular Crank-set..
Dirt Bomb
Liked 288 Times
I'm pretty sure the middle ring is worn. I just replaced the chain, cassette, and RD, and now the chain jumps badly when I ride the middle ring - which is the one I use 99% of the time.
The bike is about 10 years old and has seen much use.
You can get them on Amazon, Ebay quite easily and cheaply, too, but be warned that you're on your own fitting them, and will have to have the tools to do so (which are quite cheap and handy to have around if you own a bike or many).
For interest's sake, it would be good if you could post an image of your chainring(s), esp. the middle one.
New BBs can be had starting at around $10 or so for a basic square taper one, like a Shimano UN-26 - you have to ensure that you get the correct spindle length.
If y
If y
Dirt Bomb
Liked 288 Times
If y
If y
I just want a crank to replace the worn original one. That is all. Thanks.
The problem is that the BB and crankset need to "match" in terms of spindle length (at least to some degree). Otherwise, your crank may bottom out against the frame before it is tightened onto the square taper. If it's wrong to a smaller degree, your chainline will just be weird - forcing you to favor certain gear combinations over others.
Shimano alivio starts at 24 according to the website, and a new BB shouldn't be more than 20. I think that listing shows what length spindle to get too so you can measure your current one to see if it'll work or not... if it spins smooth I'd just leave it alone. Based only on that picture and the skipping you're experiencing it's almost certain that your rings are worn.
Dirt Bomb
Liked 288 Times
I should be able to do this. I can measure the chainline and I have the tools to pull the cranks and to take out the bb. I dont do this everyday so I need to ask questions and look things up. If I take every little thing to the lbs I'll go broke.
S'Cruzer
I do prefer the UN55 BBs over the UN26s, they are smoother, and the metal lock ring always feels better when I torque it on (and it comes off cleanly without cracking). they are probably $5 or $10 more than the UN26's.
the tourney cranks are pretty heavy and kind of clunky, the alivio is a decent notch better. you gotta spend a chunk more to get anything much nicer (deore or whatever around $100).
I've got a UN26 that I was thinking of using if it's the right length for some nice vintage White Industries cranks to put on my old Marin to replace the UN72(?) that's been on there since I got the bike in 1992 (!).
I've got a metal lockring to put in place of the plastic one on the UN26 - is that what you've had experience of cracking on them?
I also noticed that the UN26 seems to use cartridge bearings pressed into the ends of the metal shell, as opposed to the more 'all in one' look of other UNs I've seen.
Bikes: '86 Cannondale SR400, '86 Pugeot PX10, '92 Bianchi Axis, '95 Bianchi Campione d'Italia, '00 Fondriest X-Status, '08 Specialized Roubaix, '13 Cannondale CAADX
How about just changing the worn middle ring?
You can find some at Niagara for example.
Dirt Bomb
Liked 288 Times
Will I notice much difference if I switch from a 175mm to 170mm crankarms?
Will there be much difference if I go with 22/32/42 teeth as opposed to the original 28/38/48?
I'm thinking this would be a good idea because I run skinny tires and the pedals are very close to the ground with the 175's.
Thanks everyone.
Thanks everyone.
It would help prevent pedal strike a *tiny* amount (5mm ), and lower your pedalling torque by an equally tiny amount - how tall are you?
IF you're short, you may be able to spin a lower gear faster, ending up with a higher speed overall.
I have a bad knee and going shorter made a remarkable difference for me. Don't forget to raise the seat 5mm.
I'd replace with the same tooth counts to avoid any FDER issues.
S'Cruzer
note that on a bicycle you don't WANT to 'put out a lot of torque', rather you want to spin faster in a lower gear. mashing hard on the pedals is a sure way to trash the bike *and* your knees in the long run.
You may benefit from installing even shorter crankarms, maybe 165mm if you can find them, and learning to spin faster.
