any dynamo hub users out there?
Bikes: 1984 Miyata 610, original owner
any dynamo hub users out there? (Done, I'm buying one, thx)
I'm on the fence on getting a shimano dynamo hub.
I have a bottom bracket hub I used 25 years ago and back then they were like a second brake. picture pulling a teenager in a little red wagon behind you for 20 miles.
I'm considering this for a gadget and phone charger more than for lights
I will go with either a dynamo or solar charger:
https://www.rei.com/product/837625/jo...-solar-charger
I'm building a fully equipped "touring" bike with all the bells and whistles but in reality it will mostly be an excercise bike with some long distance weekend campouts every now and then.
If I take a week off work, I'm going to have my toes in the sand on a Filipino beach, drinking homemade coconut wine (Tuba), visiting my wife's family.
This dynamo would definatly add to the "cool" factor
the shimano is equivelent to the schmidt in drag but half the price
drag chart:
https://www.peterwhitecycles.com/imag...ower-input.jpg
I'm interested in first hand "pro's and con's " experiences
Thanks
drag chart:
Thanks
IDK about Shimano's , but Schmidt has negligible drag, on or off..
sealed bearings..
Have 3, 20", & 2 28" might sell the polished non disc one, [32 o]
apparently AXA's top model headlight, now, built the USB outlet in.
mount: Fork crown
sealed bearings..
mount: Fork crown
Bikes: Soma Saga, 1980 Schwinn Voyageur 11.8, New Albion Privateer
Quoted: 76 Post(s)
Liked 9 Times
I have a Shimano 3n-72 which I power a headlight and taillight off of. I love the convenience of always having light and not havign to screw around with batteries. In my experience any drag is completely inconsequential. I commute with the bike every day and have taken it on a couple trips and have never never really noticed an appreciable difference with the dynamo hub. In fact, I would say that when the light is off, I forget I even have a dynamo hub.
Quoted: 454 Post(s)
Liked 104 Times
I've got a Schmidt Son Delux and a Shimano T785 w/centerlock disc. The Shimano is noticeably heavier than the Schmidt, but it's also on a heavier bike (Salsa Vaya vs Lynskey built Ti frame)so this additional weight isn't a big factor.
For performance, they both power my lights fine, I use a Edelux + B&M rear with the Schmidt and a Supernova E3 with the Shimano, also have an E3 Tail for the back as well, but not yet fitted.
The Schmidt looks nicer, but they both perform the same job well, for longevity, have been using the Schmidt for 2 years now, guessing about 12000-15000km, never missed a beat, only got the Shimano a few months ago, and have put about 400Km on it, but this will be heavily used over this winter..
Not tried external electrical harnesses as yet, but am looking at this as an option https://www.bumm.de/produkte/e-werk-u.../usb-werk.html
Quoted: 5969 Post(s)
Liked 2,876 Times
The biggest improvement in dynohubs isn't in the hubs, but in the lower power requirements of LED lighting systems. Forgetting the mechanical drag of good Dynamo hub, which can be just about as low as a regular hub, and the small weight penalty, the probale has been the need to produce 6 or 12 watts to support the lights. !2 watts is a decent percentage of your power output and very noticeable.
However today's LEDs can produce the same output with much less power, so the effort needed to support the lights is far less. Combine that with the backup battery and circuitry that provides steady lighting at lower speed, or when stopped, and the drawbacks of Dynohubs are virtually eliminated (other than cost).
I'm on the fence about building a dynohub wheel for my commuter. It'll free me from managing batteies (currently good for 1-1/2 round trips), and give me more freedom to extend my trip home or make detours without running out of juice (happens in the winter).
For a tourist, a Dynohub is the way to go, since you won't have the ability to keep batteries topped off daily. As far as Shimano vs. Schmidt, I can't say, but either way, you'll find that they far exceed your expectations.
FB
Chain-L site
FB
Chain-L site
I cant PM, haven't reached my 50 post mark yet.
contact me about that hub. how much? what condition? how many miles.
(EDIT: email removed)
I'm going for a "showroom clean" look on this bike
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
The intangible is the sense of freedom you get. No worries about batteries dying. No hesitation about the use of lights when you're wanting to conserve your batteries. I've taken to running lights during the daytime when I feel that I need some extra visibility.
Oh, and what great lighting too!
-G
I have a SON, can't feel any drag. When I got that wheelset, I went from 28 mm wide tires to 35s, and I still can't feel any difference.
The owner of the LBS does a lot of randos, I think he has a Sanyo hub. Cheap and effective.
Quoted: 31 Post(s)
Liked 10 Times
I've been using bottom bracket dynamos for 30+ years. I had settled on a Soubitez 80 dyanamo with Union halogen front light and a BS3648 Union tail light. I had to replace the system about two years ago because the components finally wore out.
I replaced it with LED head and tail lights and a Sanyo NH-T10 bottom bracket dyanamo. I could not be happier with the new equipment. As, Mr. FBinNY noted, the big improvement is in the lighting. I have a 1 watt system and it puts out about 3 times the light of the old 3 watt halogen front light. I also get full brightness, when walking the bike. Both front and rear lights have super capacitors that keep the lights on for several minutes after stopping.
There are also improvements to the dynamo over the original Sanyo Dynapower of 30+ years ago. The bearings are sealed (and replaceable), and there's a rubber belt around the wheel. They also beefed up the spring, so slipping in the rain is not a problem. One less obvious improvement has been to the internal magnets. They are a lot more powerful, and generate more electricity per revolution than the old stuff. The dynamo also has a remote mechanical switch which I've found myself using more often than I thought I would.
There is drag. However, it's a lot less than the old Soubitez or Dynapower. I usually realize I've got the dynamo engaged from the hum rather than the drag.
The bottom bracket dynamo is not a bad deal, if one is not willing to sacrifice a front wheel. The dynamo's cost is less than that of a dynahub, without adding on the additional cost of building a dedicated wheel.
Bikes: Nothing amazing... cheap old 21 speed mtb
yeah. these guys talked me into the dynamo hub but that solar charger will be going in my camping gear
Yes, very happy dynamo hub user here. Shimano makes good hubs. I have several hubs, from old (1948) SA dynohubs to SONs in my collection. They have all worked great, but the SONs and the Shimano seem the smoothest. The Sanyo hub is a good budget model. The SONs have top notch quality and drool factor. LEDs have really made dynamo hubs effective. Super capacitors help too in the standlight department.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Power output is also better because of modern rare-earth magnets. I have a 1949 Sturmey-Archer Dynohub that still works fine, but the power output is nothing special.
Agreed, but the old SA will drive a modern LED light much better than the old incandescent lamps. I used one for years with a modern LED headlight.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1253 Post(s)
Liked 338 Times
This year I have been using a SA XL-FDD and XL-RD5 on an old Raleigh frame.
They are both awesome and quiet as a mouse. Later I got a Schmid Edelux and it lights the road really well, but the switch is way too easy to flop around inadvertently. I was using new LED bulbs in my old tail light which is small and plastic. They got too hot and 2 of them fried before I figured out what was happening. I haven't installed my B+M tail-light yet.
Quoted: 2642 Post(s)
Liked 1,991 Times
I've got a Shimano and a Schmidt dynohub (on separate bikes), mostly for commute lights. There's a moderate secondary use for overcast and rainy rides, but most of those happen during commutes anyway. Always available, never need charging. Although I do feel a slight vibration with both around 17 mph when the lights are on, there's no significant drag with lights off. (Sure you can measure it with sensitive electrical test equipment, but not enough to notice when pedaling.)
I have to question the usefulness of either solar or dynohub chargers for touring, though -- at least in the U.S. You can find a place to plug in and charge a device if you stop at a restaurant or library in an hour or less, which is about what a solar charger will do in a day of sunshine. It's perhaps possible to charge more stuff (or maybe keep a GPS charged) with a dyno convertor. Questions for that are, do you need all those electronics to be left on? and do you need a cell phone when you're in the back country where you need the GPS for navigation?
So while it's a personal choice, my choice goes: NO!
Half way there
Good luck.
-G
Counterpoint: there is definite drag in the Shimano hub when it's drawing power... just that it's not very consequential. At all. I notice it, but a lightly rubbing brake pad makes for more resistance. The difference between tire at optimum pressure and minus a few lbs. Noticeable, but negligible.
I have one on my commuter bike and the weight of the hub vs batteries for a light plus regular hub is probably less than I accidently overpack every commute.
And the benefits far outweigh the negatives. Although I've yet to find an elegant way to deal with wiring.
I use the Shimano 3N80 on my touring bike. I have disassembled the hub completely for repacking. It is well built and the drag is not noticeable regardless of whether a light is connected. I have experienced interference problems with a wireless computer, so I recommend a wired computer if you opt for a dynamo hub.
