Rotator cuff injury
Quoted: 55 Post(s)
Rotator cuff injury
I had a freak accident in the parking lot on my bike when returning to my car three weeks ago. There was some damp moss and as I pulled up to my car to brake the wheels slid out.
As I was falling I was able to partially catch myself by extending my arm and using the back bumper to break the fall.
That was 3 weeks ago. I have some pain when in bed but during the day it is OK unless I try to lift my arm above shoulder height.
From what I have read, it's probably a tear in the rotator cuff. I am seeing an orthopedist tomorrow.
Of course I don't want surgery unless absolutely necessary.
Any advice for rehabbing it?
Thanks in advance.
Thanks in advance.
Quoted: 6303 Post(s)
Liked 4,899 Times
Rotator cuff injury will heal itself, but it takes 6 to 9 months or so. Then you'll likely be left with a frozen should and not even be able to lift your arm over waist level.
I tore mine and ignored doing anything about it and that's what happened to me. However all that was needed was a couple months of physical therapy 3 times a week for what was I think 2 maybe 3 months. And a few stretches by the DPT that went to my threshold of pain, but each time I could feel the something that I can only describe as a bunch of rubber bands stuck together then separating suddenly when stretched enough. Each time that happened, I regained a lot of movement pain free to that point. After the third such stretch, I was 100%.
Regardless of what you do, take the physical therapy if it's suggested. Don't be a wuss, though the PT's will say you shouldn't have any pain during therapy, I think the DPT knew there had to be a tad every now and then.
Of course depending on how bad and how much you damaged it, YMMV. Only your Orthopedic surgeon will know for sure.
P.S. I thought there was a delete function available to you until your thread is answered. So maybe you can delete that double post if you open it to edit and look around in the advanced editor.
Quoted: 2333 Post(s)
Liked 2,097 Times
I messed around with PT for 2 years before surgery
Then was offered surgery. I healed very quickly. The pain from surgery was relatively trivial. I wish they offered it sooner.
Likes For GhostRider62:
Quoted: 12206 Post(s)
Liked 1,501 Times
Sit on a chair, place your hands in front of you, palms up. Without moving your upper arm at all, rotate your arms out to the side. That's the easiest exercise I know for that. These are small muscles, you never use much weight. If you get to the point you want more, add reps.
Have your PT guy show you how to do vertical external rotation. It's easy to do it wrong, esp. at the beginning. It also often doesn't get covered in PT. The other one I do a lot is called Y. If any of these hurt, don't do them. You bring your hand up and across your body until it's straight up. Most of these can be rehabbed without surgery, but that's up to you and the Doc.
My typical PT schedule is every other day, lots and lots of reps, and more exercises than they ask for.
Once you get cleared for PT, hit Youtube for more pt exercises.
Best of luck.
Best of luck.
Quoted: 681 Post(s)
Liked 949 Times
I tore mine and another tear cant remember the name. also tore some muscles in my upper arm. I kept re injuring it as every time I was startled or bumped something I would jerk my arm and hurt it. I finally got a MRI about 6 months later and got a choice of PT or surgery. surgery would mean no arm use for 2 months then limited for two more. so I took pt and it really did well. still took months and even after I could not lift my arm as high. I did weight lifting and other things I worked out several times a day and now its pretty much normal. Now my wife hurt hers having to use a walker for a few months and pt seems to make it worse. but no matter what its a really slow process.
a hour after I had my accident I opened the fridge the door bumped my leg and it caused me to fling my arm out and it hurt worse then when I had the accident. I did this several more times once I tore another muscle when I jerked my arm after bumping something.
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4454 Post(s)
Liked 4,564 Times
My right shoulder is shot. Hate it because I miss weight training but cycling is easy on my shoulder. Yes I should go to the doctor then get sent right to PT. Not saying PT doesn’t work but I do PT by default just keeping up my place. If I seek medical I want surgery ASAP and get it fixed. Not stuck in PT because you end up under the knife anyways.
Quoted: 996 Post(s)
Liked 1,667 Times
First get the studies, X-Ray, CT, MRI... Just do it and remember you have to ask for it. Then its build it up or repair it. Either way you end up building it up but building it up without knowing the extent of damage can make it worse. Also remember that there are not that many exercises for building up a rotator cuff. They need to be prescribed by someone who knows the exact mechanism of injury or things will get worse again.
A rotator injury can be severe even without any major force or impact. My wife tore hers swinging a fly swatter... dam fly!
Liked 4,899 Times
Likes For Iride01:
Liked 1,501 Times
Quoted: 5234 Post(s)
Liked 3,608 Times
Thanks in advance.
Thanks in advance.
Quoted: 681 Post(s)
Liked 949 Times
Quoted: 1514 Post(s)
Liked 735 Times
I've been through PT with both shoulders. The only downside is that I'm slightly less flexible now - which was partly why I needed the PT in the first place.
Life Feeds On Life
Liked 4,564 Times
Yup, I hear ya. Soon I will go see a surgeon and see what exactly is messed up. I look at my weight training anatomy book and damn the shoulder is complex .
Liked 3,608 Times
Likes For rumrunn6:
Liked 3,608 Times
Between 2012-2017, I injured each of mine and one of them twice. Each time, they took a long time to heal. I just dealt with the pain with Advil. I didn't do a ton of physical therapy. but I couldn't really play golf, nor throw a football. I had shooting pain on several occasions during that span, but only once was I forced to bed. I continued to ride the whole time. I now have full range of motion.
