Do bigger chain rings require longer chain?
Old 07-27-20, 11:46 AM
rbrides
Curmudgeon
rbrides's Avatar
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times in 28 Posts
If I replace my 48/32 with 52/36 will I have to replace (or lengthen) the chain?
rbrides is offline
Old 07-27-20, 11:57 AM
70sSanO
70sSanO's Avatar
Quoted: 1942 Post(s)
Liked 2,162 Times in 1,321 Posts
Yes.
Replace.
John
70sSanO is offline
Old 07-27-20, 12:40 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Good time to replace the chain anyhow.. put a new cassette on too..
fietsbob is offline
Old 07-27-20, 01:26 PM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,779 Times in 3,297 Posts
If you have to save the chain, you could put rear cassette on with smaller low gears. IE if your current is a 11-30, then maybe an 11-28 would let you keep the same chain.
Of course chains are usually cheaper than cassettes. And you'd have to have some quads like Kittel to push your new low gear ratio up a steep climb if you are used to the low gears you are giving up.
Iride01 is offline
Likes For Iride01:
Old 07-27-20, 11:16 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
maybe, see Park Tools instructions. I’ve used the big chainring big cog methods with no problems.
https://www.parktool.com/blog/repair...-length-sizing
MudPie is offline
Old 07-28-20, 10:13 AM
squirtdad
squirtdad's Avatar
Quoted: 2336 Post(s)
Liked 2,802 Times in 1,531 Posts
and i really like the small small sizing approach.... big thing is to make sure that big/big works so you have no bad results in the event of an accidental shift into big/big
i have used this for both modern and vinatage set ups
squirtdad is offline
Old 07-28-20, 10:25 AM
70sSanO
70sSanO's Avatar
Replace the chain. You are already going to replace the chainrings and cassette. You would be foolish to run an old chain with a new drivetrain.
If the chain length was correct for 48/32 there is not a snowballs chance it will fit with a 52/36.
John
70sSanO is offline
Likes For 70sSanO:
Old 07-29-20, 08:57 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
Thanks, John.
rbrides is offline
Old 07-29-20, 09:06 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
Thank you.
rbrides is offline
Old 07-29-20, 09:08 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
Great. I'm a PT fan. I like hear from the fine folks here at bikeforums too.
rbrides is offline
Old 07-30-20, 06:37 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1096 Post(s)
Liked 559 Times in 446 Posts
The big/big plus 1 inch method does not work with Campy's new RDs that have an extended mounting bracket or any RD with a wolf tooth extender. The little/little method only works if you're not exceeding the RD's wrap capacity. I have a Campy 12 setup with a 10-36 sram 12 cassette that has a 42T wrap, but the RD only has 39T of wrap. The chain will hang loose in the little ring and 2-3 of the smallest sprockets. The chain is 1 inch longer than normal and must be to wrap the big/big. I have shifted into that combo unintentionally.
DaveSSS is offline
Old 07-30-20, 03:25 PM
kennyc23
Is necessary to lengthen the chain if replace a 11-25t with a 11-28t cassette?
kennyc23 is offline
Old 07-30-20, 03:26 PM
fietsbob
Bikes: 8
Try it and see...
fietsbob is offline
