Why are some tires hard to change?
Bikes: Specialized Crosstrails
Quoted: 72 Post(s)
Liked 31 Times
I have volunteered on a lot of bike rides over the years. I changed hundreds of tires. Some tires are easy to change, while some fight all the way. The width on the rims varies but they are all 700 size with a 622mm BSD.
So what is it that makes some tires easy to change and some not at all easy?
1) Double walled rims seem to make tire changing a bit harder than single walled rims. 2) Folding bead tires IMO are easier to unmount as oppose to wire beaded tires, however, mounting folding bead tires could be another story. 3) Certain tire brands seem to be harder to change than others. 4) Any combination of the above.
Expired Member
Quoted: 3669 Post(s)
Liked 5,420 Times
You shouldn't discount the phase of the moon. In fact, begin keeping records now and report back in a year.
Likes For shelbyfv:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Talking clinchers here... In my experience, it's more about the rim than the tire. Two that are real bears are the Ambrosio Extra Elite and Mavic MA40. Folding tires have been more difficult than wire bead, especially on these two rims. I don't ever want to mount folders on that Ambrosio rim ever again.
Likes For SurferRosa:
Quoted: 874 Post(s)
Liked 2,287 Times
The hardest tires to mount for me were a set of wire bead tires on my daughter’s Raleigh after she bought a set of MA40 Mavic rims for it. They weren’t impossible , but the needed the tire levers the last third of the way. I can usually mount tires without them or maybe the last couple of inches .
Quoted: 550 Post(s)
Liked 325 Times
Quoted: 1074 Post(s)
Liked 295 Times
I think it’s simply due to production tolerances of tires and rims. Measuring a rim circumference accurately enough at home could be done w/o too much trouble, but measuring a tire bead accurately isn’t as easy. Had some Geax Street Runners that were beasts to mount on Mavic rims. Some Suomityres W106 that weren’t much fun either. Schwalbe Marathon winter and Conti Sport Contact didn’t put up half as much of a fight.
Quoted: 550 Post(s)
Liked 325 Times
0.010" larger diameter there can mean the difference between cussing at tools and comfortably hand mounting tires.
Velox is 0.020", thin rim tapes 0.010", two wraps of Stans or filament tape about 0.010", and two wraps of 1 mil Kapton 0.005". Use 5/8" (16mm) for traditional wheels and 3/4" or wider (19mm) for contemporary wide rims. As added bonuses, Kapton is the lightest and least expensive rim tape. It's often used for circuit board rework, and can be purchased on Amazon or eBay.
You also want to finish at the valve stem on tight rims. Starting there handicaps you with the valve stem keeping the bead out of the smallest diameter part of the rim bed.
From https://www.bikeforums.net/bicycle-m...-mounting.html
Don't finish like this:
or use a bicycle rim tape thicker than necessary like this:
Likes For Drew Eckhardt:
Pennylane Splitter
Bikes: Yes
Quoted: 1797 Post(s)
Liked 1,439 Times
Its always seemed random in the years I've been riding. Certain models of tires from certain brands don't work well with certain models of rims from certain brands. The only tires I've found to be a universal b!itch to get on-and-off are Vittoria 700 tires of 28mm or smaller width, and Schwalbe touring-style tires (Marathon and Marathon Plus). Surprisingly easy to mount were the Performance Bike Gotham Street tires; heavy tires but cheap (<$20), puncture-resistant, and rolled nicely on my utility and SS bicycles. When they went out of business I bought 6 of those (700 x 32 size). If I buy a new brand/model of tire and can't get it to mount easily at home I'll take it back and exchange it for something else, I just don't want to get stuck on the side of the road struggling with a tire.
Quoted: 1088 Post(s)
Liked 1,024 Times
Open tubulars can also be deceptively tough to mount but once they've sat on the rim with tire pressure for a week you don't need tools to change flats.
Some tires are built to tighter tolerances and some rims fudge the diameter just a touch, the wrong combination can really suck; in my opinion the whole tubeless road movement has only made the situation worse and I can't stand them.
The problem is there are no standards. The bike industry has resolutely resisted all attempts to impose standards. In particular the American branch of the industry does nothing but throw monkey wrenches in the works. The Bicycle Technical Committee of the International Standards Organization has been wholly disbanded a few times because the children have not learned how to play together.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I think that it's getting harder as more and more rims are made Tubeless Ready. Even if you're using tubes, the bead 'shelves' are robbing space for the tire to be maneuvered -- making the final stretch of the final portion of the tire bead that much harder. A good article: https://www.slowtwitch.com/Gravel/Tu...tion_7352.html
