ooops...i got a stoker stem!?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i bought this stem off ebay. turns out it's a stoker stem though it was not advertised as such. really, i thought it was a threadless dirt drop stem like i'd never seen before. looks like this....
cool stem, i think. can i still use it, though, as a regular stem. that is what i thought i was getting
Quoted: 964 Post(s)
Liked 1,451 Times
Ha, I use a threadless stem as a stoker stem on one of my tandems! Stoker stems are commonly overpriced, but threadless stems and shims are cheap/free!
Likes For scarlson:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
sorry, that doesn't really answer my question.....unless that wasn't your intention?
Likes For thook:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12759 Post(s)
Liked 7,672 Times
Pretty long stem for dirt drop use however. Also check bar clamp diameter. Most "dirt drop bars" use 25.4. That one might be 25.4 or it may get be 26, could even be 26.4 but that one's unlikely.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
it doesn't match the steerer. it's bigger than 1 inch and smaller than 1 1/8....which confused me once i got it home and tried to use it as it was advertised for 1 inch. so, i made a shim of some thin sheet metal and clamped it to a 1 inch quill adapter. works pretty good, in that regard. and, the bar clamp itself is 26mm.
the image shown is not the stem i have. that's an ebay image i found before posting since i don't have an actual photo image of mine. nevertheless, the effective reach on mine is 10cm. just right, really, for my 55cm top tube miyata triple cross. gets the bars up just high enough without need for any spacers on the adapter save a threadless canti hanger clamp
anyhow, my concern was/is as to the safety of using a stoker stem relative to the amount of forces on the steering since that's not the manufacturer intended design. so, if that's not really a problem, the i guess i'm good to go. thanks!!
Quoted: 637 Post(s)
Liked 1,279 Times
It was made to clamp on a seat post, probably something around a 26.4 or 26.6. Not a big fan of shimming steering components myself. I've done it on a temporary basis but having face planted into concrete because of a stem failure years ago I try to avoid it.
Quoted: 1106 Post(s)
Liked 1,326 Times
I have a stoker stem for which I have no use - where are they fetching these high prices, I'm all for that.
Quoted: 7348 Post(s)
Liked 2,462 Times
What are the inner diameters?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i did ask a question. i simply overlooked the question mark. to quote "can i still use it, though, as a regular stem (?)". look for it. it's there in the first post right under the image.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i know shimming handlebars is common place. but, i did wonder about shimming the steerer. logically would stand to reason if shimming the bar is fine so should shimming the steerer. both see the same forces. otoh, i had thought about using a half round file to make the stems post clamp bigger for 1 1/8 and getting a different quill adapter. i'll give this set up a trial and if it acts like it's going to shift around and such i'll try the filing. thanks!
Quoted: 637 Post(s)
Liked 1,279 Times
Handlebars rotating in the stem is one thing but have you ever had the stem come loose and your handlebars suddenly turn 90 degrees to the bike? It is NOT fun. And you're talking about a lot of filing that won't end up round so you'll lose contact area with the steerer reducing the clamping force plus weakening the stem. I've kissed the pavement, it's not worth saving a few bucks over doing it the right way.
Likes For Murray Missile:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 964 Post(s)
Liked 1,451 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
haha...what? i was referring to my childhood days of bmx bikes when i just started learning how to wrench on my bikes. one day i took a huge jump off a drainage ramp. i did not ride my bike home..lol
that is a cool carry case, though
