Cassette Replacement timing?
2017 Specialized Diverge.
105 W/Ultegra Cassette and chain.
Florida, so flat and relatively consistent speeds. No climbing, and I'm a gentle shifter.
125-175 miles a week average. All road miles, no dirt.
Im a clean weenie. bike gets a good bath once a month. Chain gets a good wipe down and relube once a week.
Have about 3750 miles on my Ultegra 11/28 Cassette.
I am wondering if I should start thinking about a new cassette? Bike still shifts crisp and I have rear deraileur adjusted at least pretty well. There does seem to be a little more noise coming from the rear drive train lately though?
I replaced my chain about 1000 miles ago.
Love some feedback and opinions.
Thx
Thx
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I get 20000 miles on a cassette if I wanted but I changed the last one at about 17000. Unless they skip with a new chain they are fine. Those who ride in bad conditions and very hilly terrain may get fewer but if you keep the drive train clean and replace chains they go a long time. I might add I generally get 7k on an 11 speed chain.
Quoted: 7348 Post(s)
Liked 2,465 Times
I get about three chains out of cassette. I replace the chain before it is totally worn, and I think that's an economical approach.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have 26,000 miles on a Sram Red cassette and finally bought a replacment.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
So perhaps counterintuitively, this suggests you do entire rides in maybe only 1 or 2 gears, and therefore, while every cog on your entire cassette may not be worn, you may more quickly wear out 2-3 of your primary used cogs faster than other riders who'd use a lot more of their cassette's range.
Likes For Sy Reene:
On Your Left
Liked 2,433 Times
Same here. I left a new chain on that was just starting to skip and ran them both to failure, what could go wrong? Well the chainrings went wrong.
Liked 2,465 Times
I've never worn out a chainring. I'm not sure why.
Likes For popeye:
On my 3x7 speed Shimano drive train I got close to 10K miles before the smallest cog wore out on my 1996 Trek 520- shark's teeth. I do a lot of climbing, weigh 220, tend to be a lower RPM grinder, though I've improved over the years. I rarely replaced the chain on that one, maybe once.
On my 2017 road bike with 2 x 11 Shimano, the smallest cog hit that point at about 7500 miles. Chain was replaced twice.
In 2019 I replaced the old Trek 520 with a Jamis with a 1x SRAM drivetrain with only a 38 tooth chain ring up front - I'm curious to see how things will wear on that one since I am in the small ring in the back a lot. Been trying to stay off it and force higher cadence but old habits are hard to break.
On Your Left
Liked 2,433 Times
I got a great deal but don't plan on swapping until needed.
Quoted: 7652 Post(s)
Liked 3,473 Times
I recommend timing the replacing of the cassette so that it happens while you are not riding the bike.
Quoted: 942 Post(s)
Liked 527 Times
The "little more noise" probably has more to do with your chain lube.
Quoted: 6963 Post(s)
Liked 10,962 Times
Liked 3,473 Times
Still, when replacing drive train parts I almost always get off the bike first ... or at the very least stop pedaling.
Quoted: 696 Post(s)
Liked 910 Times
I replace my Shimano 11 speed chains between 1500-1800 miles and the cassette every other chain. I wonder if I can keep the cassette longer but am reluctant to push my luck.
On Your Left
Liked 2,433 Times
It's not like you're gonna crash due to warn parts.
There are tools to measure chain wear. And cassettes don't need to be replaced until the teeth show wear. Maybe bring the cassette to a LBS and ask them if it looks worn.
Likes For GlennR:
Quoted: 696 Post(s)
Liked 910 Times
Hi Glen, I use a Pedro’s chain checker. I don’t want excessive cassette or chain wear leading to bad shifting or worn chainrings. Over time I’ve learned that my past issues with bad shifting and dropped chains weren’t due to cassette wear. It was usually derailer adjustments or worn cables. I don’t want to find out after the fact that I should have been more proactive with going too long on a cassette yet I do wonder if I’m replacing the way cassette sooner than necessary.
Bikes: SL8 Pro, TCR beater
Quoted: 988 Post(s)
Liked 584 Times
Thx
Thx
2) Short answer is, you need to replace your cassette if it's worn out and you should not simply rely on the number of miles on it. A visual inspection can confirm if it needs to be replaced, but based on the mileage, I am pretty positive you are good to go for another few thousand miles.
On Your Left
Liked 2,433 Times
just another gosling
Quoted: 3887 Post(s)
Liked 1,938 Times
Replace the chain when it measures 12-1/16" between pins or a little before. That's the only rule. Then replace the cassette when it starts to skip under hard efforts with a new chain. It'll only start skipping when the chain is on one particular cog, the most used one, so it's not really an issue when that happens on a ride, Just ease off a bit with that cog or use the other ones. It'll be fine. I've worn out a lot of cassettes.
It's the same thing with chainrings. When you get out of the saddle with a new chain and it skips on a chainring, replace the chainring. Just keep your butt in the saddle for the rest of the ride. Also not really an issue unless you're running an old crankset and everyone's sold out of the chainring you need. I've also worn out a lot of chainrings and have had to stock up on chainrings to keep the old gruppo going.
Here's a trick for the really high mileage riders: Save the old chains when you take them off and number them. When a new chain skips on a cassette, take that cassette off and give it the same number as the last chain you took off. Those parts will still work together. Same thing with chainrings. When you take them off, number them, hang them with other parts of the same number. You'll wind up with several sets of matched parts which you can run together, even if they're worn out. I have a very high mileage friend who did that to save money - it adds up if you ride enough miles in bad weather.
In response to a comment above, I always replace my own cassettes and chainrings. I use a torque wrench on the cassette rings. I've had cassettes come loose in the middle of a long ride twice when they were replaced at a shop. That's a huge bummer since no one carries tools for that on a sport ride. Too many wrenches think their wrists are torque wrenches. 25 ft-lbs is a lot of torque.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 988 Post(s)
Liked 584 Times
It happened to me last month on my brand new 2021 TCR. Stupid mechanic didn't torque it to specs and cogs ended up all loose after 50kms of ride. Crappy bike shop.
Liked 2,465 Times
Thanks for the warning about the cassette lockring. I haven't paid much attention to the torque on my bikes, and I'm sure I've under-tightened them. I'll check them now.
