black ice!!
Bikes: my bikes: Old: 1965 Schwinn 10 speed, 72 Monshee 12 speed, 77 Norco 12 speed, 95 Trek 850, two Specialized Crosstrails, 2016 Specialized carbon Sirrus. New 2020 Trek FX1
Quoted: 54 Post(s)
Liked 36 Times
black ice!!
So, in my neck of the woods, even though it's still officially Autumn, Old Man Winter is making his presence known and sub freezing temps are now a reality in the mornings when I commute to work on my bike. I've been okay so far but I cross two bridges on my route that easily freeze up over night when the temperature nears the freezing level, there's also the danger of black ice on the pavement as my ride is near the water and there's ample moisture in the air. What is your take as a cyclist on dealing with slippery areas and black ice??
Quoted: 9653 Post(s)
Liked 6,365 Times
Go straight and don’t brake.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Black ice? Doesn’t exist. It’s just ice. Calling it “black ice” and saying that you hit a patch of it and could never have suspected that it was there is just an excuse.
Dealing with ice? Mojo31 has it mostly covered. I’d probably say brake gently and use mostly the rear. I’d also add use studs.
Stuart Black
Stuart Black
Likes For cyccommute:
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
But yes: Brake gently, don't use your front brake, and don't attempt to turn - especially not while braking. I also tend to move my weight further back on the bike, which seems to help a little to prevent the front from sliding away from me. I still do this on my cargo bikes, and it still seems to have a little bit of an effect.
Quoted: 3952 Post(s)
Liked 7,298 Times
Likes For tomato coupe:
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
Black Ice aka Invisible Ice? Certainly exists here once in a while. I've hit it on motorcycles at speed, but not yet on a bicycle. Crazy scary stuff on a motorcycle.
Likes For FiftySix:
Quoted: 1062 Post(s)
Liked 665 Times
"Black ice" is an optical effect of ice that has a smooth surface and looks black from a distance, and might not be visible under poor lighting conditions. So really it's about dealing with ice. Riders in my locale seem to have multiple approaches. A lot of riders, including me, use studs. During the winter, my riding is limited to commuting, shopping, etc., so I don't suffer much from the speed loss. I bring out a dedicated winter bike when the salt trucks come out.
But I've noticed that some riders simply use their regular tires and ride more carefully. Maybe they're more agile than I am, and it's not a great loss to walk a bike over the worst patches if you know they're there. And if you're riding a fixed route, e.g., commuting, then you usually know where the ice will build up. There have been a handful of days when an ice storm comes through, and oncoming riders will warn one another about ice by hollering "ice on the bridge" or something like that.
Some riders bring out their fat bikes or big low pressure tires. There may be some N+1 going on here. Do what works for you, try to stay safe. Falling on a lonely bike path is one thing, falling into heavy traffic another. I did once hit a patch of ice and broke a rib.
Riders with off-road skills may be at an advantage. Don't forget the other kind of black ice: Wet leaves.
Likes For Gresp15C:
Liked 6,365 Times
The invisible ice is scary in any vehicle. Most people panic and hit the brakes. Big no-no. Stop accelerating and coast, let the bike/vehicle slow itself, steer straight, and steer into the slide if you slide. The big thing is to remain cool and use your egg.
Quoted: 356 Post(s)
Liked 323 Times
Ugh! I remember 30 years ago or so when going home really fast on slim-tyred bike because I had forgotten something. Standing up and really giving it all I had, the front wheel slipped a bit to the left and when it grapped again, my right foot was off the pedal. and my left thigh on the top tube. I had to turn right to keep my face from hitting the ground, only to then hit a tree. I ended up with a fractured pubic bone, and I still have a "bone bump" on it to this day.
Wet leaves, especially when they have started to rot are every bit as bad as ice.
Likes For CargoDane:
Quoted: 1364 Post(s)
Liked 1,678 Times
Five winters ago I finally bought studded snow tires. This winter I finally bought a 2nd wheelset, so I can just swap wheels. If my "spidy senses" think there may be a fair amount of ice, I ride the studs. Otherwise I just ride and walk the bike where there is ice. In the years before I had studs if I thought there would be a lot of ice, I didn;t ride that day.
Likes For BobbyG:
Liked 4,218 Times
If the road is wet, shiny and the temperature is below freeing, anyone in any vehicle should expect ice and for the friction between the tires and the road to be much less. “Black ice” is used an excuse for driving too fast for the conditions.
I have crashed on a bicycle on ice many, many times. I have never said that I shouldn’t have known that the road was icy. I knew what I was doing each and every time I crashed and why I crashed.
I even spun a 35’ delivery truck bed once on ice. As soon as the truck started to spin, I knew that it was my fault and I was going too fast for the conditions. You really have a lot of time to think about stuff when you are spinning on that long an arm.
Stuart Black
Stuart Black
Quoted: 356 Post(s)
Liked 323 Times
Quoted: 356 Post(s)
Liked 323 Times
I tried to look up what our term "isslag" would be in English, as it is when supercooled rain falls and freeze instantly when it hits the ground that is below freezing - i.e. the shade, bridges etc. where it most dangerous when it's just around freezing everywhere else, but the shade, bridges etc. just that bit colder.
Turns out it is merely "freezing rain" in English (sort of disappointed by that):
https://en.wikipedia.org/wiki/Freezing_rain
And the wiki-entry for "black ice":
https://en.wikipedia.org/wiki/Black_ice
Liked 4,218 Times
Sigh! No, I don't. I just use the word because that is what is used by English-speaking people, and most people drive or ride their vehicle on asphalt. I'm not a native English-speaker, I use the language as it is used by people. Not all words and terms accurately describes reality.
Weather forecasters here are constantly going on about warning people of Black Ice!® when it is cold enough to freeze water and it is drizzling. It’s dramatic! As if freezing temperature and water falling from the sky somehow results in a new and magical substance. I’ve had this discussion before and have been told that Black Ice® can form at temperatures as high as 40°F (4°C). That violates a whole bunch of physical laws.
Well, the opposite of "black ice" would be "white ice" = ice that is very visibly.
The term "black ice" in the United States is often incorrectly used to describe any type of ice that forms on roadways, even when standing water on roads turns to ice as the temperature falls below freezing.
But the second part is just either bovine, equine, or Gallus gallus fecal matter depending on what flavor you prefer.
Correctly defined, black ice is formed on relatively dry roads, rendering it invisible to drivers. It occurs when the textures present in all pavements very slightly below the top of the road surface contain water or moisture, thereby presenting a dry surface to tires until that water or moisture freezes and expands; drivers then find they are riding above the road surface on a honeycombed invisible sheet of ice.
Tined concrete roads might have structure below the surface to trap water but the roads are usually made to channel water away from the surface so that hydroplaning is less of a problem
Additionally, on both surfaces, de-icer is used extensively throughout the US (and probably most places where it gets cold in winter) to prevent just this kind of problem. Even if de-icer isn’t used, road traffic creates lots of friction which would melt any “honeycombed [ice] structure” quickly. The car’s weight would be enough to crush it quickly if it even formed.
My issue with the usage of Black Ice!® is the dramatic overuse of it. It’s just ice.
Stuart Black
Stuart Black
Quoted: 356 Post(s)
Liked 323 Times
Ok. Whatever. A thin layer of ice is always visible, regardless of lighting and where it is. And ice cannot be white either. Got it. Thanks.
Edit:
I missed this the first time around:
I haven't heard up to 4, but 2 degree C. But that process is called "nucleation" and doesn't involve violating any physical laws.
https://en.wikipedia.org/wiki/Nucleation
Edit:
Quoted: 4227 Post(s)
Liked 2,488 Times
It's called black ice because it's very thin and much more difficult to see than regular ice...Black ice takes on an appearance of the road surface and that's what make it so dangerous, sometimes you can't see it until it's too late.
Likes For wolfchild:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
Black ice is the common phrase which meaning is widely understood in the US. If you have an issue with a common phrase, no matter if it is not accurate, that is more your deal than anyone else’s. Translucent or shiny ice might be better descriptors but you aren’t going to change common usage. You know look, Look, there are plenty of phrases I disagree with but it’s my deal, not anyone else’s you know what I mean? You know what I’m saying? Like can you dig it, man? Fur sure. Right on!
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 668 Post(s)
Liked 529 Times
Shouldn't it be ice of color?
coming out of the saddle and locking the handle bars straight helps. don't overcorrect if the bike gets squirrely, just try and ride it out.
If it is truly ice and I see it in time I walk or ride around it.
Likes For Pop N Wood:
What you call it really doesn't matter. It's semantics. The bottom line is that it is slick and depending on the lighting it can be invisible.
I am super cautious because it can hurt you: 25 years ago it put me on the ground with a badly torn rotator cuff. Surgery, 6 weeks with the arm immobilized, 6 weeks in a sling, and 6 weeks of physical therapy. Fortunately my surgeon was a specialist in sports medicine who worked with a lot of pro athletes, the rehab went well, and I got back about 95% range of motion.
And I agree - This time of year the wet leaves on the bike trails are just as treacherous.
Likes For MNebiker:
There is no opposite of Black Ice!®. There is no black ice. Ice is colorless like the water that forms it. Ice on plants isn’t called green ice. Ice that might form on a red rose isn’t called red ice. Ice on my white vehicle isn’t any more white than the ice that might form on my wife’s car is blue. It’s just ice...good ol’ plain colorless frozen water.
At noon on a fairly warm day I hit black ice that hadn't melted in the cold temperatures in the shade. If you had the sun on you it felt warm but in the shade it was still below freezing. Coming around a 160 degree left turn I luckily took the turn tightly and so was near the center of the road when I hit it and slid 10 or more feet across the road, slowly falling down when I struck dry pavement and was jerked upright and back on course without falling. If you think that you can tell when and where black ice might appear you're incorrect. Even the exhaust of a car can form black ice.
Likes For RiceAWay:
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Anyhoo, back to the OP, I would get a set of studded tires. It sucks to ride on them when it's dry and clear, but because you're commuting road conditions change during the course of the day and night. It's worth it's weight in gold if you can avoid calling on difficult-to-see-thin-layer-of-frozen-water-that-appears-black-to-the-eye-and-misnomerically-called-black-ice ice.
Last December I hit hard-to-see ice patch and went down before I even knew it. It happened so fast. One minute you're riding along on dry pavement, and then you find yourself in the middle of the stuff. Fortunately I was approaching a stop sign and so going relatively slowly. Actually, come to think of it, it might have hurt less if I'd been going faster.
Black Ice Matters
Black Ice matters. As does all Ice. It does, really!
Likes For prairiepedaler:
Quoted: 608 Post(s)
Liked 352 Times
There is a reason I have "that guy" on ignore. Don't engage him or we will get six more posts of him trying to prove himself right.
For what everyone else in the world calls black ice, studs as mentioned are your best friend. Once I went to studded tires I would never go back. The question is does Victoria's winter produce enough days where ice is a problem. When the roads are clear the studs really slow you down, so there is a trade off.
