Go Back  Bike Forums > Bike Forums > Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling
Largest handlebag you can recommend... that is compatible with aero bars?
Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling Do you enjoy centuries, double centuries, brevets, randonnees, and 24-hour time trials? Share ride reports, and exchange training, equipment, and nutrition information specific to long distance cycling. This isn't for tours, this is for endurance events cycling
Old 10-02-17, 11:40 AM
Flounce
Quoted: 181 Post(s)
For long rides and brevets, I used a medium size front bag (Lone Peaks Alta) mounted with a Klickfix mechanism to handlebars of my road bike, worked great:
Lone Peak H100 Alta Handlebar Bag ? TheTouringStore.com
Then I added aerobars, and could no longer use the front bag I had purchased. Other traditional boxy rando front bags (e.g. rack mounted) also appear to go above the level of the handlebars and therefore prevent use of aerobars (unless the aero bars are much tilted upwards at the front, which I don't do).
Something that uses cloth straps and hangs down below the handlebars would work, something like this (I think):
Outer Shell Adventure - Drawcord Handlebar Bag
But that bag is small.
Does anyone have suggestions for a front bag/handlebar bag compatible with aero bars? Looking for the one with the greatest capacity.
Flounce is offline
Old 10-02-17, 12:16 PM
OneIsAllYouNeed
Long-term wear tester
Bikes: Cycles Chinook travel/gravel/family tandem, KHS CX200 road/gravel, Voodoo Agwe fixie commuter, Gunnar Sport travel/road, Motobecane Boris fatbike
Quoted: 216 Post(s)
Liked 11 Times in 10 Posts
There was just a discussion of cheap handlebar bags in the commuter section:
https://www.bikeforums.net/commuting...le-bar-bag.htm
For good or bad, the results are pretty much what you're looking for.
OneIsAllYouNeed is offline
Old 10-02-17, 12:24 PM
ksryder
Bikes: yes
Quoted: 1045 Post(s)
Liked 287 Times in 172 Posts
Dunno if it has the "greatest" capacity, but this is pretty big. Doubles as a fanny pack. I have the smaller version for commuting, it's good for wallet, keys, etc.
https://northstbags.com/collections/pioneer-12-hip-pack
ksryder is offline
Old 10-02-17, 12:27 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1401 Post(s)
Liked 282 Times in 166 Posts
It depends on the distance between the tire and the handlebars. Rando bags often come in various heights so they can fill that distance appropriately.
Acorn bags come in various heights:
https://www.acornbags.com/
One question is can you mount a mini rack up front?
tyrion is online now
Old 10-02-17, 01:33 PM
Flounce
Quoted: 181 Post(s)
Thanks all, I will look at those.
As far as a mini rack is concerned, yes, the bike that I will be getting (not my current one) will be able to take a mini-rack. It's going to be steel frame and fork, Rodriguez or Gunnar or similar.
Flounce is offline
Old 10-02-17, 02:04 PM
1nterceptor
LET'S ROLL
1nterceptor's Avatar
Bikes: 2014 BMC Gran Fondo, 2013 Brompton S6L-X
Quoted: 297 Post(s)
Liked 21 Times in 18 Posts
I just started using a Revelate Sweet Roll bag on my folder(straight bars). Seems well made and good design.
Comes in S, M, L. How long is adjustable, depending on how much stuff you have:
https://www.google.com/search?q=reve...h=1094#imgrc=_
Bike Friday pakiT from BFold by 1nterceptor, on Flickr
One day: https://www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
1nterceptor is offline
Old 10-04-17, 07:32 PM
antimonysarah
antimonysarah's Avatar
Bikes: Nishiki Bel-Air, Brompton P6L, Seven Resolute SLX, Co-motion Divide, Xtracycle RFA
Quoted: 60 Post(s)
Liked 3 Times in 3 Posts
Emily at Dill Pickle Gear could probably do something custom if that's in your budget.
antimonysarah is offline
Likes For antimonysarah:
Old 10-04-17, 08:51 PM
unterhausen
Randomhead
Liked 164 Times in 132 Posts
With a traditional rando bag, it probably is ok, depending somewhat on your rack and the size of your bike/handlebar height. I made my rack fit close to the wheel -- maybe too close. I'm pretty sure I could get a aero bar over my Acorn large rando bag. No problem at all over the Acorn Boxy rando. The Large Rando has straps that hook on the side. I have a Boxy rando from the early days that has a single strap that hooks in the back. That's a pain in comparison.
Saturday's 400k made me think about aero bars some more, and specifically the bag issue. Headwinds for the first half of the ride, pedaling down hills, the whole nor'easter experience
unterhausen is offline
Old 10-06-17, 07:40 AM
adamrice
mosquito rancher
adamrice's Avatar
Bikes: Bob Jackson 853 Arrowhead; Felt VR30
Quoted: 32 Post(s)
Liked 6 Times in 4 Posts
It's surprising there aren't some good off-the-peg options for this, since it seems like an obvious thing. Rob English had a custom bag made for his Trans Am Bike Race attempt. So a template exists, at least.
adamrice is offline
Old 10-06-17, 02:40 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2633 Post(s)
Liked 512 Times in 370 Posts
Originally Posted by adamrice View Post
It's surprising there aren't some good off-the-peg options for this, since it seems like an obvious thing. Rob English had a custom bag made for his Trans Am Bike Rice attempt. So a template exists, at least.
Reading through this thread, I had trouble visualizing how a handlebar bag could possibly work with aerobars. That is a really sweet solution.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-06-17, 03:28 PM
ksryder
Bikes: yes
Agreed - I had a vision for something like that using an old Dopp kit and some velcro straps (but I abandoned it because my needs changed) but I was also surprised something like that wasn't available off the rack. I guess the market for that is pretty limited, but still. That's pretty cool to see.
ksryder is offline
Old 10-07-17, 10:08 AM
unterhausen
Randomhead
that is pretty slick, and orange bikes are definitely faster. I remember when Rob dropped out, he rode out and then went back to his hotel. But I don't remember the issue. eta: Just read his race report, knee. Wise choice dropping out, what a lot of miles he did in such a short time. He seems to have mostly just filled the handlebar bag with food
Most randos use aero bars that sit above the handlebars, not quite so aero as the ones that Rob was using. So a lot of traditional randonneuring bags would fit underneath, because there is no handlebar involvement. I would be a little awkward opening the main compartment on the road, but I rarely do that anyway. I mostly just use the side and back pockets while I'm moving.
Old 10-07-17, 10:53 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6965 Post(s)
Liked 305 Times in 241 Posts
http://www.cyclofiend.com/working/im...-1P1010007.jpg
Stacking 2 stems, I have my Bar bag mount on its own stub bar on the lower stem..
fietsbob is online now
Old 10-07-17, 11:09 AM
Flounce
Quoted: 181 Post(s)
2 stems, Great idea !
Flounce is offline
Old 10-07-17, 01:29 PM
adamrice
mosquito rancher
adamrice's Avatar
Quoted: 32 Post(s)
Stacking 2 stems
That remind meóMinoura sells a headset spacer with a stub handlebar bracket in front, so you could even do this with a pretty low stack height.
adamrice is offline
Old 10-07-17, 02:41 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
SJS (UK) Cycles makes a T bracket 1 bolt , 27mm of spacer height. welded T is 7/8" tube.
Old 10-08-17, 06:13 AM
kingston
Jedi Master
kingston's Avatar
Bikes: http://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1266 Post(s)
Liked 102 Times in 83 Posts
I know a guy who straps a big seat bag to his aero bars attaching it to the aero bars instead of the seat rails and the steerer tube instead of the seatpost so what's usually the back of the bag is facing forward. It looks ridiculous.
kingston is offline
Old 10-16-17, 01:54 PM
Flounce
Quoted: 181 Post(s)
HA! I love it. I'm going to try it.
For some reason, this reminds me of how when my 2 year old asks me to change her diaper, I first fit the clean diaper on her head as a hat and laugh at her and she gets annoyed and pulls it off and tosses it across the room.
Flounce is offline
Old 01-13-20, 01:15 PM
adamrice
mosquito rancher
adamrice's Avatar
Quoted: 32 Post(s)
Just to update this thread, Apidura is making a "race" bag with sleeves specifically for fitting over aerobars.
adamrice is offline
Old 01-19-20, 06:18 AM
shelbyfv
Quoted: 1378 Post(s)
Liked 459 Times in 290 Posts
Wonder if OP ever got the new bike?
shelbyfv is offline
Alxbr
Touring
28
02-11-18 02:39 PM
Flounce
12
12-25-17 07:35 AM
Flounce
15
05-03-17 04:11 PM
TheReal Houdini
Touring
20
12-02-11 11:50 AM
cyclist2000
Touring
11
01-18-10 03:00 PM
