Happy about my worn out tire
Quoted: 1814 Post(s)
Liked 923 Times
Haven't replaced that tire yet, & rode it a few more times.
But meanwhile, another one is down to the cords, also without a flat. This a 25mm Sprinter. Running 23mm/25mm at about 60/70. Just a little squish during sprint-type efforts.
This tire is very uniform, as the cords are showing about 80% of the circumference.
Quoted: 1815 Post(s)
Liked 1,693 Times
Maybe all you guys who wear tires down to the casing should be buying lottery tickets. I have done this once by mistake and I am not bragging about it
Likes For alcjphil:
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Deal4Fuji:
minimalist cyclist
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,640 Times
You got me there - this was on my rainy day bike that was just being ridden on my close-by local loop so I was never that far away or group riding. I was curious to see how far I could go with it. Soon after this pic it went with a slow hiss, no loud sudden blowout.
Likes For noimagination:
Quoted: 822 Post(s)
Liked 1,955 Times
I ride a lot of steep grades. My risk management spidey intuition tells me the bike gods would frown upon me if I rode tires like those in the above pics.
Nothing like a face plant at 30 mph from a tread separating. I would never feel confident in the corners with those types of worn tires keeping me glued to the tarmac. Medical co-pays can be in the 10's of thousands; I'll fork out the $40-$50 bucks for a new tire.
Likes For CAT7RDR:
Quoted: 4717 Post(s)
Liked 1,882 Times
Last week I replaced the front and rear tires, and on the second ride a piece of glass cut a 5mm slice along the center of the rear tire. I was about 3 miles from home, so I just started to walk home. After a few hundred yards, the tire was still holding some air. It wasn't enough to ride on seated, but by shifting my weight onto the front tire. I was able to ride home at about 8mph.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I was pretty excited when I was finally able to actually wear out a set of tires, after losing my first three sets of tires to damage. But nothing like what's been posted, I rode them down till the wear indicators weren't visible and then replaced them. I think I might actually be close to wearing out the rear again, with no damage!
Liked 923 Times
To me it's a victory over tire cuts. I think there is less glass on the roads lately.
According to my somewhat far-fetched theory, the yahoos are suffering less angst with one of their own in the White House,
and are tossing fewer bottles.
Likes For woodcraft:
minimalist cyclist
Bikes: yes please
Liked 1,640 Times
Liked 10,646 Times
I'm riding this tire on flatland, 16-17 tops and no tight turns other than my turn-around points of my double dead end loop, which are too slow to matter. I'm also not standing on the pedals so my weight is probably 60% on the rear wheel and at the time I was 260 lbs, ( a slim 235 now ) Being a big guy I don't run really high tire pressure. On the negative side I'm on a 27" frame so I'm riding higher than most...still I just can't see a blowout in those circumstances ever putting me over the bars, but these cautionary comments will keep me from ever doing it again. Thanks
minimalist cyclist
Bikes: yes please
Liked 1,640 Times
I didn't say low pressure, I said not high (100+) like some people like. I use the hard pinch to judge, where I have to pinch hard to make an indention...usually around 85 - 90 on my pump gauge. For what it's worth those are Vittoria Ziffaro 27" x 1 1/8" tires
Quoted: 365 Post(s)
Liked 418 Times
I don't understand the comment about being big meaning you don't run high pressures in your tires. Generally speaking, the greater the weight borne by the tire, the higher the pressure required to mitigate against pinch flats and/or damage to the wheel rim when hitting bumps.
minimalist cyclist
Bikes: yes please
Liked 1,640 Times
You seem to have the impression my tires are running semi-flat when they're not. I'm pretty sure I'm running the best tire pressure for my size & weight based on the fact I rarely have flats. Also recent research that a lot of people over-inflate and may actually lose speed and efficiency by bouncing hard over road bumps & debris.
Quoted: 365 Post(s)
Liked 418 Times
You said "Being a big guy I don't run really high tire pressure", I am confused as to how being big means that you don't run high tire pressure since, all else being equal, a bigger rider generally runs their tires at a higher pressure than a smaller rider to get the same contact patch under load, and thus protect against pinch flats.
Quoted: 18353 Post(s)
Liked 4,502 Times
I have felt that thin rubber with good belting/protection may well reject glass and other flat causing stuff more than thick rubber...
So no need to change early. Of course, one can also pick up cumulative damage over time that impacts older tires.
Nonetheless, I'll wear until the rubber is mighty thin.
Liked 1,882 Times
(edit) Goatheads don't care about the thickness of your tread.
Liked 4,502 Times
Blackberries can be a pain, but generally not too bad as lone as one keeps off the shoulder edges.
Registered User
Quoted: 188 Post(s)
Liked 276 Times
Reminds me of a tire I used a few years ago. Specialized Armadillo, old scholl wire bead!
Thing was so stiff it would stand in the center of the room on its own. OK not really, but close.
I was training for a big mountain ride event so I spent a lot of time up in the mountains without many resources. I wanted a durable tire so I went with the 'dillo. Not sure how many miles exactly I did on that tire but used it all year and totaled 5,000+ miles. Most on that bike. The tire wore so much that it had a red band around the center of the tire when I was done with it (belt under the tread ?). I ran over rocks, thorns, tarantulas, whatever was there and never one flat.
Heavy tire but good training tire. Never a flat but once I swapped out the tire for the Conti couple weeks before the event, felt like I was flying. I loved that tire, super strong and durable, belt exposed and not one flat.
kenshireen
General Cycling Discussion
30
09-22-18 11:59 PM
PNW Noobish
10
07-07-13 08:56 AM
