Replace my seatpost
Replace my seatpost
Old 11-06-19, 12:11 PM
tomtomtom123
Quoted: 350 Post(s)
Liked 122 Times in 90 Posts
The setback problem got me thinking again about my brooks saddle with it's very short rails. It's still too far forward with it pushed all the way back. I measured my Thudbuster ST and it has around 12-13mm of setback. The specs says 11mm. I decided to try 3D printing a TPU insert for my Thudbuster ST with a different shape to increase the static unloaded setback. With the new shape, I measured an additional 10-11mm of setback, and a 3-4mm drop. Here is a GIF of the mockup in ABS plastic. I'll have the finished TPU part in a few weeks and will give it try.
tomtomtom123 is offline
Likes For tomtomtom123:
Old 11-06-19, 05:29 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4729 Post(s)
Liked 1,530 Times in 1,001 Posts
Have you looked at the IRD "Wayback" seatpost?
Wayback Seatpost ? Interloc Racing Design / IRD
Sy Reene is offline
Likes For Sy Reene:
Old 11-06-19, 05:45 PM
tomtomtom123
Quoted: 350 Post(s)
I have a folding bike with 33.9mm diameter seatpost, so the Wayback seatpost won't work, unless I get a telescoping seatpost and replace the top part with this. It's also got a single bolt, which might slip and is more difficult to fine tune, unless it's got serrated teeth? I also would lose my elastomer suspension.
Old 11-07-19, 06:12 PM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
It depends on design.
Campagnolo single bolt seatposts don't move given a firm tug on a standard 6mm hex key, although 1978-1997 they don't use serrations.
Campagnolo titanium and carbon fiber posts which followed used serrations - 1 degree at first which could be a bit low or high, then 1/2 degree which were presumably fine. Unfortunately, the cradles broke with time.
My Nitto S65 took a significant 16 NM to hold its adjustment. "Tight" with a standard length hex key didn't work, "tight" with a long one didn't work, and I bumped it up with a torque wrench until it held.
Drew Eckhardt is offline
Old 11-07-19, 06:34 PM
Drew Eckhardt
Quoted: 550 Post(s)
Originally Posted by rumrunn6
mine keeps slipping it's angle & a bike pro says any two-bolt post would hold the saddle at the angle I set. yesterday on a single ride I had ti stop twice to move it back in place
1. Put some assembly paste on the mating surfaces.
2. Make it _tight_. Many single bolt seatposts stay parked with a firm tug on a standard 6mm hex key. Some don't - I had to crank a Nitto S65 up to 16 NM to get it to hold. Usually a 6mm head goes with an 8mm bolt with a 30 NM recommended torque for class 8.8. A 6mm bolt (I didn't check threads) should get 16 NM for class 10.9 and 12 NM 8.8.
Old 11-07-19, 07:37 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
got the grand cru on. time will tell
Velo Orange Grand Cru Long Setback Seatpost MKII: 30.2mm Setback, 27.2mm
rumrunn6 is offline
Old 11-07-19, 07:57 PM
rumrunn6
rumrunn6's Avatar
Originally Posted by Drew Eckhardt
1. Put some assembly paste on the mating surfaces.2. Make it _tight_. Many single bolt seatposts stay parked with a firm tug on a standard 6mm hex key. Some don't
ridges are rounded. into recycling it goes
rumrunn6 is offline
Old 01-26-20, 03:48 AM
rumrunn6
rumrunn6's Avatar
meanwhile, cpl months later, took it for a ride. held firm & was glad the angle I chose was good. no mid-ride adjustments required
rumrunn6 is offline
Old 01-28-20, 12:07 PM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
My experience with inexpensive single-bolt posts is that both the clamping force and the weight of the rider might deform (bend) the bottom part of the clamp, which allows the top part of the clamp to bottom out on the bottom part before the seat rails are firmly clamped. This could be why you were tightening it so much that the bolts were breaking. The worn down ridges on the bottom part of the clamp and the head of the post would also require additional bolt torque.
Wilfred Laurier is offline
Old 01-28-20, 03:28 PM
rumrunn6
rumrunn6's Avatar
the single bolt never broke. or were you were referring to Drew Eckhardt?
rumrunn6 is offline
Old 01-29-20, 08:39 AM
Wilfred Laurier
Señor Member
Quoted: 649 Post(s)
I think so
