Wheel/hub question
Wheel/hub question
Hi all:
my 1987 Schwinn Super Sport came with a set of un-original wheels, Wolber Super Champion clinchers with no-name sealed hubs, no markings but a sticker that says “sealed bearings”. The front wheel has developed quite a bit of side-to-side slop in the year or so I’ve been riding this bike. I understand adjusting the cones on conventional hubs, but I have no experience with sealed bearing hubs. Is it worth trying to replace the bearings, or replacing the hubs? Or is it time for new wheels? How good are these Wolbers anyway?
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
Take a closer look. You might find the "sealed" bearings can be overhauled just like any other traditional bearing.
Quoted: 1143 Post(s)
Liked 1,740 Times
Sounds like you have Specialized hubs or maybe they are Sansin hubs. The Sansin are most likely cup and cone, the Specialized are press fit.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Hi all:
Huh? There are several thousand suppliers of hubs around the world. There are several thousand more if you include the ones that are no longer in business. There is no reason to think that the hub in question is a branded Specialized hub in particular.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 1,740 Times
“Sealed bearings” doesn’t necessarily mean that the bearings are cartridge bearings. Shimano hubs are usually marked as “sealed” and they are all loose bearing hubs. They do have labyrinth seals and rubber boots that seal them against the elements. Cartridge bearing hubs seldom develop any kind of play since the bearings are usually pressed into place and can’t really move side to side. The axle just can’t move.
Specialized hubs have no engraving, the branding on the seal covers comes off pretty easy.
For the op Wolbler Super Champion were about the best of the day.
Liked 4,218 Times
It’s unlikely, however, that an undescribed hub on an aftermarket wheel is from Specialized. Their footprint isn’t that large. It could be Sansin or Joytech or any of a few thousand...yes, thousand...other companies. Not that it matters. The main point is that if the bearing is loose, it is probably a cup and cone hub that just needs adjustment.
Stuart Black
Stuart Black
Liked 4,218 Times
Hi all:
But, again, cartridge bearings seldom fail in the manner you’ve described. Cup and cone bearings often have this problem, especially if the locknut isn’t tight enough.
Stuart Black
Stuart Black
Liked 1,740 Times
Yes, thousands currently when you include all of the Chinese companies making both OEM and aftermarket hubs. As for Specialized, they use different hubs on different levels of bikes. Some are those OEM Chinese hubs and some are branded as Specialized hubs with engraving. I’ve had a number of Specialized bikes and many of them had hubs branded as Specialized. Most often the front hub is a Specialized hub with a Shimano on the rear. A few had Specialized front and rear but that is rarer in my experience. Most of the Specialized hubs have been cartridge bearing hubs, but not all of them. The hubs, however, weren’t manufactured by Specialized. They are made by the same companies that make other OEM hubs.
Liked 4,218 Times
While it’s possible that the wheel is question is a “Specialized”, it’s just highly unlikely. Nor would it matter all that much.
Stuart Black
Stuart Black
Liked 1,740 Times
That’s about the only way that a “Specialized” wheel would be on any bike. Specialized has never really been into aftermarket wheels. Someone may have built a wheel with a Specialized branded hub but it would still be clearly marked. Specialized was an importer for a while but, to my knowledge, they didn’t import wheels. They were known for tires. Even if they did import wheels, they quickly transitioned from a parts importer to making bicycles.
Liked 4,218 Times
But, again, expecting a random wheel set to have a Specialized hub is a stretch.
Stuart Black
Stuart Black
Quoted: 18376 Post(s)
Liked 4,511 Times
The first step is to determine if this is some kind of "sealed cup and cone" setup. Or, a sealed cartridge bearing.
Virtually all of the sealed cartridge bearings are standard, and should be able to be simply pressed out, measured, and replaced with stock off-the-shelf bearings from your local industrial bearing supply store, or a quick internet search.
Bikes: Some Schwinns, Raleighs, Centurions, Crescent, Bianchi
Quoted: 248 Post(s)
Liked 289 Times
I have a set of Wolber Super Champion Gentleman 81 rims that came to me on a bike that I can't recall right now, but they are laced to Cycle Pro hubs that have a red label that says sealed bearings. I think Cycle Pro was made by Miche.
Quoted: 1361 Post(s)
Liked 423 Times
Whatever number is on the bearing (closely inspect the rubber seal for part number), enter it in Google and cross reference to other potential replacements. If unable to verify number, measure with precise calipers and then search sealed cartridge bearing supply houses / online. First check ebay and Amazon.
Also, various bearing grades and type of seal (or none at all) will be listed. You want at least one side sealed.
Depending on bearing grade, one can find pricing under $6 pair (sometimes free shipping from China!)
Servicing is a 10 minute ordeal. The hub housing is aluminum and much softer metal than the bearing. That makes it easy to pop the cartridge bearing out but use caution to avoid marring.
Lastly, if one doesn't want to measure or able to I.D. part number, take it to an auto parts store and they will match the bearing.
Quoted: 1163 Post(s)
Liked 442 Times
Hi all:
https://rover.ebay.com/rover/0/0/0?m...2F163495684766
Quoted: 2363 Post(s)
Liked 1,749 Times
I've seen quite a few no-name hubs with the "Sealed" decal on entry/mid level MTBs from BITD. So far they've all been "sealed" cup and cone, and have either nothing, Joytech or Sansin on the QR.
The Shimano "sealed" cup and cone hubs I've seen usually say "sealed mechanism"; I reckon it's to distinguish it from a cartridge-type sealed-bearing hub.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
Quoted: 3464 Post(s)
Liked 2,829 Times
Liked 1,749 Times
Anything on the QR skewer?
Look closely at that seal that says Japan. Does it have a brand elsewhere around it?
Liked 4,218 Times
They look like loose bearing cup and cone hubs. They even look like they are OEM (original equipment manufacturer) since they have the original retention system. The red lines in the picture below point to the cone and lock nut.
Untitled by Stuart Black, on Flickr
The lock nut will need a 17mm wrench to adjust it and the cones will likely need a 13mm cone wrench.
On a side note, that wheel retention system is far superior to the other wheel retention systems we are stuck with now.
Stuart Black
Stuart Black
Agreed about the wheel retention system, it's such a good idea I'm shocked nobody carried it on.
Thanks for the info! That's very helpful.
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
Why are you bringing up current produced generic Chinese hubs? Thats a 30+ year old rim and the odds of it having a modern generic hub are really small for obvious reasons.
Specialized hubs werent marked, the original post noted the hub isnt branded, and so it was suggested that maybe its a Specialized hub. It may be wrong, but it isnt some crazy comment to criticize either.
Take a breath man, take a breath.
Liked 4,218 Times
Nope. Not aggressive. I merely pointed out that Mr. 66’s assertions were wrong.
Of course some might say that you are “coming in aggressive yet again” since you are rather late to a discussion that has been settled and want to relitigate it. We can do that if you like.
Roypercy said
in his original post. Although I’ve shown that they were OEM wheels, we didn’t know that at the beginning of the discussion. We didn’t know that the hubs and wheels were 30+ years old. Unoriginal wheels could be be from just about any date with a nearly infinite combination of hub, spokes and rims, hence the inclusion of generic Chinese hubs.
Some Specialized hubs weren’t branded. Many have been. Specialized hasn’t had that large of a footprint in terms of individual components...as I’ve noted many times in this thread...so the possibility that the hubs were “Specialized brand” hubs based on zero information is very, very small.
My breathing is just fine. Perhaps you should mind your own breathing and take one before relitigating something that is settled.
...my 1987 Schwinn Super Sport came with a set of un-original wheels...
Stuart Black
Stuart Black
