Use levers without the brake adjuster
Quoted: 112 Post(s)
Liked 8 Times
What will it take to use these first model Superbe levers without the ugly adjusters? Will I need an equivalent piece
in its place that will hold the brake cable in place?
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 5 Times
I'm guessing these - VeloBase.com - Component: SunTour BL-SB00-N, Superbe Pro
it sure is handy to have a brake adjustment somewhere.
if these are your brakes, there's a cable adjustment on the calipers - VeloBase.com - Component: SunTour BA-SB00-S, Superbe Pro
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Those adjusters fit onto threaded stubs that are pressed into the lever bodies. If you remove the adjusting barrels the stubs will still be there and there will be an annular space between them and the holes in the gum hoods. You'll still need a stop for the cable housing. Best to keep using these or get different levers that will not require as much tweaking.
Quoted: 939 Post(s)
Liked 5 Times
those are so handy, I'd definitely keep them
"part timer"
Bikes: 1975 Raleigh Gran Sport, 1978 Bertin C35, 1982 Trek 614, 1983 Trek 620, 1984 Nishiki Seral, 1995 Mercian Ko’M, 1998 Fisher HKEK, 2000 Rivendell RS, 2001 Heron Touring, 2016 Nobilette Custom
Quoted: 114 Post(s)
Liked 160 Times
Those Superbe levers were made by DiaCompe and are missing the little rubber covers for the adjusters. Good luck finding any, but if it helps, they should look like this:
