Cold weather, Cold hands, help!
Quoted: 34 Post(s)
I’m a 55 year old, 6’3” male that lives in northern Utah looking for some good warm gloves. My hands are cold all the time but biking anything in the 40’s and below they turn to ice. I bike down into the 20’s. My circulation is terrible as I live with chronic neuropathy pain making it worse but cycling is my salvation.
Question, anyone with good leads to gloves that will help me and other tips?
Thanks so much guys!!
- Marty
- Marty
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Bar Mitts really help if you're willing to use them.
Bar Mitts - Ride in Comfort
I, like you, have very bad circulation in my hands. I biked for a few winters in bozeman, trying to buy bigger and warmer gloves every year. It never worked. Bar mitts and pogies allow you to use thinner gloves and still control your bike. I personally use dogwood designs pogies on my flat bar bike, as they're actually insulated a bit more than the bar mitts. The dogwood design pogies only come in one size, but the bar mitts come in multiple sizes. I have relatively large hands, but wear a medium glove because I hate having room at the ends of my fingers I bought medium bar mitts (Yes I own bar mitts AND dogwood designs pogies). I wish I had bought larges.
This site has a few different styles of pogies/bar mitts for you to peruse.
Accessories - Pogies - Fatbikes
If you're not willing to use them, buy windproof lobster gloves (2 fingers) and hope for the best. You'll be spending multiple hundreds of dollars for gloves warm enough if you have really bad circulation. (My own experience.) I bought $250 mittens on sale last summer for half off. I can wear them down to about 20 °F. With my pogies or bar mitts I can wear much thinner gloves down to -20 °F.
EDIT: Well, with my dogwood designs pogies I can wear thinner gloves down to -20, with the bar mitts my limit is ~5 °F.
I don't ride in cold temperatures anymore but when I did (down to freezing temp) I used ski gloves.
The first thought was some sort of heating pads which you could slip into your gloves.
Also maybe try to get something that covers your wrists. Particularly where the arteries run close to the skin ie where you take your pulse. This might help prevent air cooling the blood.
Or you could go nuts and get some electric gloves:
Heated Gloves, Electric Gloves, Battery Heated Gloves - The Warming Store
Definitely cover the wrists. When using the pogies on warm days my wrists are always VERY warm. (Which is slightly annoying, but better than the alternative.)
I debating heated gloves inside of the pogies, but they're not really necessary after the first 2 miles (you warm yourself up eventually.) I doubt heated gloves would do anything outside the pogie, as the wind would just blow any heat away.
Vain, But Lacking Talent
With a legitimate circulation problem, I'd also recommend electric gloves. It might be an extra hassle with more batteries to keep track of, but back in my motorcycling days, electric gloves had the huge advantage of not being super bulky and not requiring more mess on your bars and controls. I'm fine on the bike, but on a motorcycle, my large frame combined with a low resting heart rate meant almost nothing kept my hands warm. If I needed it on the bicycle, I would trade the hassle of batteries for the added flexibility and control of lighter electric gloves.
I'm somewhat the opposite of you. My hands are fine, but my feet go numb pretty quick sub 60 degrees. Make sure you have some sort of wind resistant shell on the outside. The electric gloves sound awesome if you could some how hook them up to a long enough lasting battery or even cooler hook them up to some sort of generator powered by your bike (got bored Bicycle Lights and Generators). I will probably get a bunch of glove warmers for when the weather gets cooler here and use those in my boots.
I just put a pair of the cheap magic gloves under some "winter" bike gloves, and my hands go from cold to toasty.
Bikes: Holding steady at N
Quoted: 19 Post(s)
+1 to Bar Mitts. I have Raynaud's and would not be able to ride in the winter without them. Everything else I tried failed.
Bikes: S-Works Tarmac, Nashbar CX, Trek 2200 trainer bike, Salsa Casseroll commuter, old school FS MTB
Quoted: 31 Post(s)
maybe some ski gloves or something really burly? In Utah you can probably find a well equipped outfitter.
Bikes: Fuji Sportif 1.3 C - 2014
Quoted: 5 Post(s)
What kind of gloves are you using now that aren't working? That would be helpful. Otherwise, we might just recommend something similar to what you have now.
GH
GH
Bikes: SuperSix, Nature Boy, Mattioli R1, Burley Tandem
Quoted: 23 Post(s)
I have a pair of giro 100 proof lobster gloves. I replaced the liners that came with it with a pair of warm wool gloves and I am good below 20 degrees (and I have cold hands). The key though, is just riding faster.
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
I've thought about using Bar Mitts, but I ride in the drops a lot and it doesn't seem like these mitts allow you enough room to ride use the drops. Am I wrong about this?
I struggle with this because I live in rolling hills. I work up a sweat and then freeze descending. Any tips? sorry for the hijack.
Quoted: 31 Post(s)
What are you wearing when you ride? I have a jacket that's made of windblocker material on the front only, so it breathes but keeps me from freezing from wind. You could also use the time honored trick of newspaper in your jersey, which blocks the wind and absorbs moisture. Bring some extra sheets in your pocket so you can swap them as they get saturated. I have also used plastic bags to make a wind proof layer, as well as a wetsuit in single digits and subzero weather. I am slowly acquiring actual cycling gear, which is much nicer.
You're correct. You can only ride in the bar mitts while on the shifters. You can, however, take your hands OUT of the bar mitts and ride on the drops no problem (except you won't have easy access to the brakes.)
Portland Fred
In addition to suggestions already made, I'd recommend chemical warmers. Also, keep your forearms warm -- that will help your fingers as well
just another gosling
Quoted: 3891 Post(s)
Liked 1,940 Times
+1 on the Giro gloves. Warmest cycling gloves I've ever used. Even good in rain.
Results matter
Results matter
Liked 1,940 Times
In terms of gloves, the same principle applies. Don't let your hands sweat, though cold weather gloves need to be windproof or almost.
Results matter
Results matter
@CafeVelo @Carbonfiberboy
I think my problem is that I don't have a good enough wicking base layer. I just bought a convertible wind breaker jacket/vest which has helped a lot! Now I just need to figure out something for the in between temps. I'm learning though just very slowly (moved to NC from Miami so its a huge learning curve).
pogies when below 40°
Quoted: 31 Post(s)
