Zipp vs Roval Wheels
Old 10-09-18, 04:38 PM
lennyparis
lennyparis's Avatar
Bikes: 2017 Tarmac Pro, 2014 S-Works Tarmac, 2011 Trek Madone 6.2, 2014 Trek Madone 5.9 & 2009 Specialized Hardtail
Quoted: 28 Post(s)
if I wanted to swap Roval wheels from 2014 and 2016 with new zipps could I without issue?
dont want to have to keep making adjustments to bike to swap between wheels
if I do have to adjust what has to be tweaked?
lennyparis is offline
Old 10-09-18, 05:46 PM
Gr8day
Gr8day is offline
Old 10-09-18, 10:45 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
Probably not. It is just my guess. I started buying only Shimano wheels because I got tired of making adjustments every time I did a wheel change.
colnago62 is offline
Old 10-09-18, 11:09 PM
vtje
member
Bikes: 2016 Cervelo R3, 2021 Carbonda Gravel, 2019 Ibis HD4, 2016 Ibis Mojo HD3, 2016 Specialized Demo 8 II, 2015 Specialized P26
Quoted: 57 Post(s)
Liked 4 Times in 4 Posts
Disc or rim? What bike? Specialized used a proprietary SCS hub on Roval wheels for their early disc bikes. You would need to replace a hanger if that is the case.
If those are rim wheels, you should be able to switch them without any issues.
vtje is offline
Old 10-09-18, 11:59 PM
Bob Dopolina
Mr. Dopolina
Bob Dopolina's Avatar
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times in 41 Posts
^^^ This
If you are buying complete wheels it will be an issue. If you want to build wheels you can use a hub designed specifically for these bikes.
BDop Cycling Company Ltd.: bdopcycling.com, facebook, instagram
Bob Dopolina is offline
Old 10-10-18, 04:10 AM
lennyparis
lennyparis's Avatar
Quoted: 28 Post(s)
Rim brakes on rovals that are 2-4 years old
zipps would be new
so the hubs are different widths?
meaning I would have to adjust brake width?
anything else to adjust?
Old 10-10-18, 05:19 AM
Zaskar
Quoted: 479 Post(s)
Liked 277 Times in 156 Posts
Why would the width of the hub impact the brakes? If the rims are the same width, your brakes won't need any adjustment. If the hubs are different widths, you'll likely need adjust the derailleur.
Zaskar is offline
Old 10-10-18, 06:09 AM
Bob Dopolina
Mr. Dopolina
Quoted: 149 Post(s)
zipps would be new
The chainline on the hubs is different which means the der will need adjustment each time.
Adjusting brake pads is sop.
Old 10-10-18, 10:11 AM
vtje
member
Quoted: 57 Post(s)
The hub width is only different on Disc brake equipped bike/wheels.
Since you have rim brakes, there is no difference, you will be able to switch your wheels back and forth. The only (minor) thing might be rim width difference, affecting your brake cable length, but that is a very simple on-the-fly adjustment.
vtje is offline
Old 10-10-18, 12:29 PM
colnago62
Quoted: 741 Post(s)
I had two sets of Zipps, a pair of Shimano wheels and some Chris King wheelset. I had to make rear derailleur adjustments every time I changed wheels.
Old 10-10-18, 12:36 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times in 560 Posts
Sometimes you luck out. Sometimes you don't.
If full rim brake then you might have to adjust brakes depending on the rim widths. Most I know run the narrow width with the brake quick release cam closed and then the wide with it open.
The only other adjustment is shifting. You may need to make a small barrel adjustment on the rear derail. If the difference is large you may have a small issue with limits but doubtful.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 10-10-18, 06:17 PM
Bob Dopolina
Mr. Dopolina
Quoted: 149 Post(s)
I'm sorry but it's not that simple.
Disc brake hubs with 135 OLD use 44mm chainline. Road bikes with 130 OLD have 41,5mm chainline.
Shimano specifies 41.5mm chainline for hubs used with road groupsets. Using a 135OLD hub with 44mm chainline means the hub chainline is out of spec. This can result in chain rub, poor shifting or the chain getting caught on the shift pins on the back of the front chainrings.
This is what Specialized encountered with SCS bikes.
Old 10-10-18, 06:41 PM
vtje
member
Quoted: 57 Post(s)
Unless I am missing something, he is replacing rim break wheels with rim break wheels. How 135OLD (disc hub width) and it's chainline is relevant?
vtje is offline
Old 10-10-18, 08:21 PM
nycphotography
NYC
nycphotography's Avatar
Quoted: 1169 Post(s)
Liked 107 Times in 62 Posts
Even rim brake to rim brake, different wheels are different widths, and you may have to adjust the brakes. If I know I'm swapping wheels back and forth, I'll set both bikes up for the narrower wheels, then use the quick release to open the up a bit on whichever bike happens to have the wider wheels at the time.
But this does get tiresome after a while.
nycphotography is offline
Old 10-10-18, 09:11 PM
Bob Dopolina
Mr. Dopolina
Quoted: 149 Post(s)
Ah. I guess I missed that part. I scrolled back up and see it now.
If it is 130OLD road to 130 OLD road then it's a crap shoot. A little barrel adjuster magic may be in order.
imobilinpedalus
General Cycling Discussion
0
06-12-17 06:12 PM
dieselgoat
Bicycle Mechanics
10
07-16-15 05:26 AM
Diablito
Road Cycling
13
07-06-15 12:46 AM
George
Road Cycling
2
08-19-12 07:40 PM
tatfiend
Bicycle Mechanics
1
08-31-10 05:40 PM
