WTB Shimano Hyperglide Hub w/ 126 spacing, 36h
Bikes: 1980 Peugeot PFN-10, 1989 Bridgestone MB-3, 1988 Univega Alpina Uno, 1974 Velosolex Saint Tropez, 1995 Trek 830, 1986 Lotus Odyssey, 1987 Schwinn Mirada, 1987 Raleigh Elkhorn
Quoted: 21 Post(s)
Liked 99 Times
Looking for an 80s shimano rear hub with 126 spacing that takes an HG cassette. It needs to have 36 holes.
Does anyone have one of these they’d be willing to part with?
thanks!
thanks!
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
Are you looking for a freewheel or freehub? I have a 105 but it is only 32H and a screw on freewheel type. Also it is missing the drive side seal. Otherwise, the cups and all are in great shape. If you can use it, you are welcome to it for shipping, $7.50 I think.
If the OP does not want this hub, it is up for grabs.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
Sorry, I just looked at the OP again and saw it is for hg freehub. Any body wants this hub, it yours.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Hyperglide started in 1989 IIRC, so you'll probably have the most luck searching for a hub from the late 80s or early 90s. Maybe 6401, 1055, or RX100 if you're looking for what was "road" at the time. If you're willing to respace a 130mm or 135mm 7-speed "MTB/hybrid" hub to 126mm by removing spacers and cutting down the axle (I've done this), that would help cast a wider net.
Likes For ThermionicScott:
Quoted: 21 Post(s)
Liked 99 Times
Quoted: 3811 Post(s)
Liked 6,717 Times
I might have something. I'll check the bin when I get home though I have an inkling that all I have are 32-hole hubs.
Edit: confirmed—the one I have is 32-hole. Sorry!
Likes For nlerner:
Quoted: 21 Post(s)
Liked 99 Times
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
I’ve got a 1055, but need to confirm number of holes.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Quoted: 753 Post(s)
Liked 737 Times
I think "Bikewagon" still has dual UG/HG freehub bodys on ebay for $13~ or so. 126 mm UG hubs seem to be easyier to find NOS or abandoned early in their service life than HG and it's pretty easy to swap in a new free hub body
Likes For bark_eater:
tantum vehi
Liked 992 Times
Sorry, also 32h
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Quoted: 21 Post(s)
Liked 99 Times
Thanks for the idea. That may have to be the route I go down.
Quoted: 21 Post(s)
Liked 99 Times
Liked 2,568 Times
I checked my stash, too. Almost all of my rear hubs are 32h. I've got an unused 36h RM50 shell with a Uniglide freehub stuck to it, and a used 36h Exage hub but the axle parts have been separated from it as well. (I'm sort of holding onto it in case I want to build another 36-spoke rear wheel for heavy loads...)
Here's what I'd do if I want to build up with new parts: Since "road" hubs in 36h seem to be rarer than "hybrid/MTB" hubs in 36h, I'd focus my search on the latter. "Exage" or "Acera" are good keywords. There's a seller in the UK who's pairing NOS 36h 7-speed HG rear hubs with nutted (?) front hubs: https://www.ebay.com/itm/402970734061 You would have to remove that 4mm axle spacer from the NDS and hacksaw 4mm off the axle, but once you've done that, it's ready to go! (If you're not comfortable cutting it, you could just buy a 137mm 10x1 QR axle and transfer all the hardware to it, too.)
If you're up for converting an UG hub to HG, here's the link to those HG freehub bodies from BikeWagon: https://www.ebay.com/p/26027203657 It's just a 10mm hex key to remove the old one and install the new one, but one caveat is that the old UG DS cone may not seal well against the dustcap on the HG freehub body, so you may want to go ahead and buy a Wheels Manufacturing CN-RO60 cone. https://wheelsmfg.com/hub-parts#rear_road (Spares are good to have, regardless!)
RUSA #7498
I have a 36 hole tri-color HG rear hub. There wasn't a skewer in it but I might be able to round one up. The spoke holes are a bit fugly but it spins as smooth as ever (I didn't open it up to inspect the internals but it is smooooth). Let me know if you want pics etc.
Quoted: 21 Post(s)
Liked 99 Times
thanks for looking out! Decided to just stick with a freewheel hub for this build and keep things simple
