Knobby Tire Wearing Out Faster On Pavement
Quoted: 969 Post(s)
Liked 1,632 Times
Strange as it may seem it appears that my touring tires with the pronounced knobs is wearing out faster than when used on regular pavement. I have used Kenda and Continental touring tires on my local bike routes. Half of each route is well paved asphalt with the other half mostly torn up pavement. The torn up pavement is light gravel unless I have to go off road to avoid large pot holes. During inclement weather I stay mostly on the well paved roads. Oddly I have noticed more wear to the knobby areas of my tiers when used on the well paved roads then on the gravel. Any comments?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
you have to think in terms of friction and also the tire composition. there's a lot more friction (heat + surface contact) from pavement than on irregular surfaces. on top of that, the knobs are going to be made of a softer composite that's better for surface conformity/grip on irregularities while the smoother areas of tread are harder. which is better for longevity and maximum surface contact on pavement
Likes For thook:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4426 Post(s)
Liked 4,537 Times
Aggressive truck tires wear out faster than slicker highway style tires on pavement. I’m guessing that can apply to bicycle tires as well.
Likes For Hondo Gravel:
Quoted: 913 Post(s)
Liked 515 Times
Don't forget to factor in speed and braking differences while computing tread wear between gravel/broken road versus smooth (abrasive) roads.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
I ride my MTB to my local trails and have to cover sometimes a mile or two paved to get to the dirt. I've often wondered, is it better for me (for my tires) to ride on asphalt or concrete (i.e. road or sidewalk)? (If sidewalk, I would scrupulously yield to the very few pedestrians I would encounter)
Also, I recently noticed that the Schwalbe Hurricanes on my commuter, the right-side knobs are seriously ground down, but the left-side knobs are pristine. Evidence that my right-turns are always sharper than my left turns. 'murica!
Forum Moderator
Quoted: 3093 Post(s)
Liked 6,608 Times
Thread moved from Foo to General Cycling Discussion.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
Yeah pavement wrecks knobbies. Knobbies wear out faster on the rocky trails here in PHX than the softer trails around PDX also.
Likes For LesterOfPuppets:
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
Makes sense to me. Knobbies are noisier on pavement, I suppose that noise comes from higher wear. Wear else?
There are some here on the forum who carry a second set of wheels and tires with them.... They strap their knobby tires onto their backpack and then once they arrive at the trail, change out the slick tires and wheels in favor of the knobbies.
Quoted: 6199 Post(s)
Liked 4,816 Times
This almost deserves a "duh"!
Yes, you people running knobbies on pavement can be heard a long way away. Of course they are creating morefriction bumps to increase your rolling resistance and sapping you of energy you could better use to ride further or stronger. Essentially you are taking your own section of chip-seal road with you for the ride.
Personally I wouldn't use knobbies in anything but dirt, sand or mud. For gravel or broken up pavement I can see where some heavier tread pattern might be desired, but not to the extent of knobbies.
Last edited by Iride01; 08-17-21 at 04:47 PM. Reason: Friction might be technically incorrect. So I reworded it but might start another controversy in the process <grin>
Likes For Iride01:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
^This^ How could it be a surprise that soft, knobby mtb tires don't last as long on pavement? It seems so obvious.
Likes For cxwrench:
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
I get soaked faster when I spray myself with a hose compared to when I run thru a sprinkler.
Likes For msu2001la:
Quoted: 5224 Post(s)
Liked 3,585 Times
I like gravel but I don't like knobby tires
Likes For rumrunn6:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2588 Post(s)
Liked 5,649 Times
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
the knobbier it is, the faster it will wear out on pavement. Generally speaking, knobbies will wear down faster than slicks or semi-slicks regardless of terrain.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Any thoughts on asphalt vs concrete, which will grind down knobbies quicker?
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
