Tell me all about goatheads
Gunther20
This winter keeps dragging on and I'm getting closer to making plans to drive south for a weekend of real outside cycling and it got me thinking about whether I might find goatheads wherever I go.
To my knowledge, these little buggers do not exist in Minnesota. At least I haven’t seen one here anyway. My only encounter with one was while driving through western Kansas my daughter wanted to stop at a wheat field. I pulled into a farm driveway, she got out with bare feet, and promptly found one stuck to the bottom of her foot! So western Kansas, check. Tell me what other states they can be found in.
Also, are goatheads only an issue when they are actively growing or are they a year-round nuisance? Do you have to ride over the plants or can you pick up the thorns anywhere? Even on the road or on a trail?
Finally, what can be done to mitigate the issue? Are there certain tires, tire liners that have been proven effective? Yes I am already aware that a tubeless setup can be effective. I don’t need this thread to turn into a tube/tubeless argument, just want to gain a better understanding of goatheads.
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
Nevada, at least near reno. I don't ride over plants (road). But still pick them up from time to time. In my experience they need to be dry to do their job.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I lived in Albuquerque, and I believe that is the goat head epicenter. There is a bike path that parallels hwy 40 that has a gauntlet of four foot high goat head bushes. (usually goat heads come from a closer to the ground, yellow flowering vine), be there were at least four feet tall. There must have been thousands of those little devils on the ground. Fortunately, I lived less than a mile away. I knew that my tubes were toast. I just sprinted for as far as I could before I was riding on the rim. When riding off road, this is usually a good reason to stay on the main trail. On the road, cars are your allies. When it comes down to goat head thorn VS car tire, the car tire wins. When road riding in goat head country, it is an advantage to ride in the road were if a thorn is in the road, it gets flattened by a car tire, won't give you a flat. The way to do this is to ride with a rear mirror, and monitor cars back.
Quoted: 969 Post(s)
Liked 1,632 Times
Young GI stepped on a Goat Head in Ft Greely Alaska. Of course it had hitched a ride from West Texas in his gear bag. To be sure it was disposed of with extreme prejudice...
Quoted: 18381 Post(s)
Liked 4,512 Times
They've got them in Eastern Washington.
I haven't seen them in Eastern Oregon, but I wouldn't be surprised if they were around some.
You'll probably find them in semi-arid places across the USA. The same places you might find tumbleweed.
Liked 4,512 Times
Here is a map of where to avoid riding your bike!!!
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
There are a lot of good posts on this forum about goatheads. I think Stuart @cyccommute did the best one
https://www.bikeforums.net/20886140-post10.html
https://en.wikipedia.org/wiki/Tribulus_terrestris
The plant is a low dark green weed with little yellow flowers in season. The seed pod looks like a little skull with horns sticking out, thus the name. The spines are slivers about a quarter inch long and stick up like a caltrop. The hardened seed pods are there year round... true of most things in this half of the country where it only rains a few months out of the year, or even only a few times a year, and the small plants go to seed and die pretty quickly. They grow wherever the desert hardpan has been turned over by humans and yes they do get you on the road because they grow in pavement cracks. Actually maybe more common around suburbs because there's year round water supply.
I do tubeless, but all the kinds of tire armor can be effective too.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Disco Infiltrator
Liked 2,105 Times
Oh, and if all you know about this desert you learned from Westerns, goatheads are not cacti and not from tumbleweeds, a totally different weed.
https://en.wikipedia.org/wiki/Kali_tragus
Genesis 49:16-17
Genesis 49:16-17
Likes For spelger:
Quoted: 18883 Post(s)
Liked 10,646 Times
They're attached to ornery creatures.
Liked 10,646 Times
Beyond the Cascades. Rumor is there's a whole continent that way. I guess this explains why I've never seen them, I grew up in the north east and then once I moved out here Sherman Pass is as far east as I've ridden, usually no further than the Methow.
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
Had them in eastern Colorado. Haven't seen any in southeast Wyoming. And I ride lots of country roads and cow paths.
Likes For Inusuit:
Quoted: 347 Post(s)
Liked 418 Times
Usually they are more of a problem in the fall. Don’t ride over the plants!
On my commuter bike I use a ‘self-sealing’ inner tube which works fine since they make little holes in your tube.
Also resist the urge to pull them out of the tire if you see one stuck, wait until you get home unless you go flat.
Likes For billridesbikes:
Quoted: 10238 Post(s)
Liked 5,189 Times
Don’t know what Goat Heads are, but we have little prickly balls of doom in certain areas of Virginia. I grew up calling them chiggers, but they are tire killers for sure. Yorktown has a healthy population as well as ft. Monroe. Havnt seen them anywhere else where I usually ride. Avoid the grass and you are usually good.
Quoted: 3376 Post(s)
Liked 5,526 Times
Likes For Shimagnolo:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
As a fellow Minnesotan, I was unaware when I first encountered them riding outside of Las Vegas some years ago. But the way I got into trouble was by riding off the shoulder onto an unpaved surface.
I've returned to that area many times since, almost always in January as a deep winter escape, and never had another goathead flat. I know they are also on the pavement, but not nearly so abundant.
Quoted: 2952 Post(s)
Liked 3,106 Times
Pretty much all of NorCal. Tubeless helps. And don’t pull them out till you get home.
Likes For caloso:
Quoted: 878 Post(s)
Liked 2,296 Times
Southern California is plagued with them. I would say 90% of my flats are from those nasty little things. Listen to caloso, leave them in until you get home! If they are stuck to your tire, they have already pierced the tube, in my experience. Down here the wind blows them onto the roadway so you don’t even have to go off-road.
Quoted: 8287 Post(s)
Liked 9,064 Times
When they dry out the wind blows them around and you can pick them up anywhere on the road. It's weird that we might not see any for months, then several people will get flats on one ride.
Likes For big john:
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3206 Post(s)
Liked 1,848 Times
I believe we have them here, but have never pulled one off a tire. Plenty stuck to my pants though.
Quoted: 590 Post(s)
Liked 445 Times
One time I pulled a dozen goatheads out of an mtb tire (25psi tubeless with Stan's sealant), when my front wheel went a few inches off the singletrack (and not a single one in my rear tire oddly enough), and every one sealed instantly when pulled out.
I've had MANY more flats on the road bike due to very small metal shards (some say its from steel belted tires), and the only place to get away from those is on the mtb single track, which brings us full circle back to the goatheads.
Quoted: 347 Post(s)
Liked 418 Times
t
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 925 Times
Goatheads are evil.
I spent maybe 10 hours early last fall weeding my street. Neighbors would drive by looking at me and wondering WTF?, I'm sure. I probably filled a dozen or so kitchen-size garbage bags with whole mats of the creeping plant, complete with yellow flowers and dozens to hundreds of the little green dingle-balls that dry out into the thorns. You have to get them before they start drying out, or the little dingle-balls (botany term) fall off too easily. I don't really know how many goatheads I got rid of, but I would guess 5-10,000. I think I reduced my chances of getting a flat in the first and last 0.3 miles of any ride, substantially. But once I'm past the stop sign, I'm on my own.
My workhorse bike has thorn-resistant tubes and Mr Tuffy tire liners, but they are very heavy. I've gone with sealant instead for my other two, and that means removable valve-core tubes are needed. Any Schrader valve will work. Presta valves with removable valve cores are less common, but available. Might as well put the sealant in before you have the flat, is my advice. I use Slime for butyl tubes, and Stan's for latex tubes.
Good luck with the goatheads!
Likes For Fredo76:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
As others have mentioned, these things pose the greatest risk in summer and early fall when they are mature and dry. In the springtime they are small and green and don't usually puncture. Likewise in late fall and winter when the ground is wet and they get soggy and kind of soft.
The plant that produces them, which we call a "puncture vine," grows flat along the ground, with a central hub that sends out numerous long, straight stems (like rays), each of which can have several branches spreading off it, with many tiny, sage green leaves among which the thorns are hidden. A mature plant can produce hundreds of thorns each season. I've seen them reach up to 10 or 12 feet in diameter (arms six feet long, going in every direction). They are not particularly hard to pull up, if you carefully watch where you're grabbing. They have only one long, narrow root going straight down from the center.
They are an opportunistic weed that grows where other green plants won't. They thrive in hard, dry, rocky ground and will even take root in pavement cracks and expansion joints. They love hot, dry environments, but will not grow well anywhere that gets plenty of water. They don't grow well anywhere that they have to compete for sunlight; even moderately healthy grass will choke them out.
When mountain biking in desert areas, there is of course a risk of running into them anywhere, however most knobby tires are thick enough to prevent a high risk of punctures. The individual thorns (like goat horns) are usually only about 5mm long at most, however they are very sharp and quite hard late in the season. When road biking, you have to watch for them alongside roads and paths, as the rays can reach several feet across the pavement. They are a real threat to bike tires with inner tubes. In Utah, I've suffered dozens of flats from them before switching to tubeless tires on most of my bikes. As shown in a picture above, they can be a nuisance when they gather in the soles of your shoes, as they can get tracked into the house and then sometimes fall out in the carpet. And they can be a real problem for dogs, getting stuck in their paws.
Quoted: 1612 Post(s)
Liked 2,595 Times
