Spicy
so the cog is used to take up the slack on the chain?.... why not just run a shorter chain (if that is the case)...
Quoted: 261 Post(s)
Liked 346 Times
I tried a shorter chain and it was too short. The bike has vertical dropouts and unless there is a perfect ratio, there will be no chain length that will work.
Whippersnapper
I'm not brave enough to use it on a fixed gear, but that's kind of cool. I've seen some pictures of old DIY tandems using floating chainrings to tension the sync chain, it apparently works pretty well.
Quoted: 261 Post(s)
Liked 346 Times
It is called a ghost ring and it tensions the chain. I used this on this bike because it has vertical dropouts and I can't adjust the rear wheel to tighten the chain. Also on a fixed gear you can't use a normal chain tensioner. If using this setup you probably want to use a brake because I tried to skid and the ghost ring popped out.
